5504FE.00305
5504FE.00305
    BELDEN
    BELDEN - 5504FE.00305 - Multicore Cable, Screened, 6 Core, 22 AWG, 1000 ft, 305 m
5504FE.00305 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 5504FE Multi-Conductor - Commercial Applications For more Information please call 1-800-Belden1 General Description: Security & Alarm Cable, Riser-CMR, 6-22 AWG stranded bare copper conductors with polyolefin insulation, Beldfoil® shield and PVC jacket with ripcord Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 6 22 7x30 BC - Bare Copper Total Number of Conductors: 6 Insulation Insulation Material: Insulation Material Wall Thickness (in.) PP - Polypropylene 0.008 Outer Shield Outer Shield Material: Outer Shield Trade Name Type Outer Shield Material Beldfoil® Coverage (%) Tape Aluminum Foil-Polyester Tape w/Shorting Fold 100 Outer Shield Drain Wire AWG: AWG Stranding Drain Wire Conductor Material 24 Solid TC - Tinned Copper Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (in.) PVC - Polyvinyl Chloride 0.017 Outer Jacket Ripcord: Yes Overall Cable Overall Cabling Lay Length & Direction: Length (in.) Direction Twists (twist/ft) 2.750 Left Hand 4.400 Overall Cabling Color Code Chart: Color Black Red White Green Brown Blue Overall Nominal Diameter: 0.172 in. Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +75°C UL Temperature Rating: 75°C Bulk Cable Weight: 27.200 lbs/1000 ft. Max. Recommended Pulling Tension: 60.100 lbs. Min. Bend Radius/Minor Axis: 1.625 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMR NEC Articles: 800 Page 1 of 3 05-02-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 5504FE Multi-Conductor - Commercial Applications CEC/C(UL) Specification: CMG EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 04/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: UL1666 Vertical Shaft CSA Flame Test: FT4 Suitability Suitability - Indoor: Yes Plenum/Non-Plenum Plenum (Y/N): No Plenum Number: 6504FE Surface Printing (Overall) Electrical Characteristics (Overall) Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 22.500 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/ft) 40.500 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 16.4 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 15.3 Max. Operating Voltage - UL: Voltage 300 V RMS Max. Recommended Current: Description Current 10C Temperature ris 2 Amps per conductor @ 25°C ambient Put Ups and Colors: Item # Putup Ship Weight Color 5504FE 008U1000 1,000 FT 23.000 LB GRAY 5504FE 008U500 500 FT 12.500 LB GRAY 5504FE 0081000 1,000 FT 29.000 LB GRAY Notes Item Desc 6 #22 PP FS FRPVC 6 #22 PP FS FRPVC C 6 #22 PP FS FRPVC Notes: C = CRATE REEL PUT-UP. Revision Number: 4 Revision Date: 08-09-2013 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the Page 2 of 3 05-02-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 5504FE Multi-Conductor - Commercial Applications Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC. Page 3 of 3 05-02-2016
5504FE.00305 价格&库存
很抱歉,暂时无法提供与“5504FE.00305”相匹配的价格&库存,您可以联系我们找货
