5GBCY-KC50
5GBCY-KC50
    BELDEN
    BELDEN - 5GBCY-KC50 - Multicore Cable, Screened, 5 Core, 0.75 mm², 164 ft, 50 m
5GBCY-KC50 数据手册
MachFlex 350 CY Cables Shielded (CY) PVC Control Cables Tinned Copper Braid Shield (TCB) Excellent Noise Immunity Applications Designed for applications which are installed in occasional flexing and fixed locations. Cable applications include precision control sensors, multi axis control machines, temperature controllers, control panels, machine cutting tools, auxiliary equipment, motor speed control, production machinery and many more. General Reference Standards • • • • DIN VDE 0295, IEC 60228, BS6360 DIN EN 50290-2-22, DIN VDE 0207-363-4-1 DIN VDE 0482-332-1-2, DIN EN 60332-1-2, IEC 60332-1-2 RoHS & REACH & CE Directives Construction and Performance 1. Conductor Material Stranded bare copper (DIN VDE 0295 Class 5) 2. Insulation Material & Color Insulation Material & Color PVC (polyvinyl chloride). A) All black color with number coding = without protective conductor. B) Black color with number coding plus 1 green & yellow = with protective conductor. 3. Braid Shield Material Tinned Copper Braid Shield 4. Jacket / Sheath Material PVC (polyvinyl chloride) 5. Flame Retardancy VDE 0482-332-1-2, DIN EN 60332-1-2, IEC 60332-1-2 6. Voltage Rating (Uo/U) 300 / 500 V 7. Oil Resistant DIN EN 50290-2-22 (TM54) 8. Temperature Range -30 °C TO +70 °C (Occasional movement) -40 °C TO +80 °C (Fixed installation) 9. Bending Radius 20 x OD (Occasional movement) 6 x OD (Fixed installation) 10. Other Properties Good UV resistance, chemical resistance & flexibility MachFlex 350 CY Shielded (CY) PVC Control Cables TINNED COPPER BRAID SHIELDED CABLE WITH (G) PROTECTIVE GROUND 5 4 3 2 1 Conductor 0.50 mm2 No. of Cores 3 4 5 7 12 20 Nom. Overall Diameter (mm) 7.2 7.7 8.3 9.1 11.4 13.7 1 = Conductor 2 = Insulation 3 = Inner Sheath 4 = Tinned Copper Braid Shielded 5 = Outer Sheath Conductor 0.75 mm2 Copper Weight (kg/km) 45.08 53.90 64.68 78.40 135.73 226.25 EMEA Part Code 3GACY 4GACY 5GACY 7GACY 12GACY 20GACY APAC Part Code 3G0.5CY 4G0.5CY 5G0.5CY 7G0.5CY 12G0.5CY 20G0.5CY Conductor 1.00 mm2 No. of Cores 3 4 5 7 12 20 Nom. Overall Diameter (mm) 7.7 8.3 9.2 9.9 12.4 15.0 Copper Weight (kg/km) 55.86 62.72 75.46 99.96 173.46 289.10 EMEA Part Code 3GBCY 4GBCY 5GBCY 7GBCY 12GBCY 20GBCY APAC Part Code 3G0.75CY 4G0.75CY 5G0.75CY 7G0.75CY 12G0.75CY 20G0.75CY Conductor 1.50 mm2 No. of Nom. Overall Copper Weight Cores Diameter (mm) (kg/km) 3 8.2 63.70 4 9.1 76.44 5 9.8 87.22 7 10.5 110.74 12 13.3 184.34 20 16.1 307.23 Conductor 2.50 mm2 EMEA Part Code 3GCCY 4GCCY 5GCCY 7GCCY 12GCCY 20GCCY APAC Part Code 3G1.0CY 4G1.0CY 5G1.0CY 7G1.0CY 12G1.0CY 20G1.0CY No. of Nom. Overall Copper Weight Cores Diameter (mm) (kg/km) 3 9.0 77.42 4 9.7 95.06 5 10.5 113.68 7 11.3 146.02 12 14.4 274.40 20 17.5 457.33 Conductor 4.00 mm2 EMEA Part Code 3GDCY 4GDCY 5GDCY 7GDCY 12GDCY 20GDCY APAC Part Code 3G1.5CY 4G1.5CY 5G1.5CY 7G1.5CY 12G1.5CY 20G1.5CY No. of Nom. Overall Copper Weight Cores Diameter (mm) (kg/km) 3 11.0 143.08 4 11.9 163.66 5 12.9 196.00 7 14.0 282.24 12 18.2 467.75 20 22.7 779.58 Conductor 6.00 mm2 EMEA Part Code 3GECY 4GECY 5GECY 7GECY 12GECY 20GECY APAC Part Code 3G2.5CY 4G2.5CY 5G2.5CY 7G2.5CY 12G2.5CY 20G2.5CY No. of Nom. Overall Copper Weight Cores Diameter (mm) (kg/km) 3 12.6 174.20 4 13.7 232.26 5 14.9 274.40 7 16.2 384.16 9 20.0 493.92 12 21.5 658.56 Conductor 10.00 mm2 EMEA Part Code 3GFCY 4GFCY 5GFCY 7GFCY 9GFCY 12GFCY APAC Part Code 3G4CY No. of Cores 3 4 5 7 9 EMEA Part Code 3GGCY 4GGCY 5GGCY 7GGCY 9GGCY APAC Part Code 3G6CY 4G6CY 5G6CY 7G6CY 9G6CY No. of Cores 3 4 5 7 9 EMEA Part Code 3GHCY 4GHCY 5GHCY 7GHCY 9GHCY APAC Part Code 3G10CY 4G10CY 5G10CY 7G10CY 9G10CY EMEA Part Code 3GJCY 4GJCY 5GJCY 7GJCY APAC Part Code 3G25CY 4G25CY 5G25CY 7G25CY Nom. Overall Diameter (mm) 14.6 16.0 17.5 19.1 23.6 Copper Weight (kg/km) 233.73 311.64 432.18 519.40 667.80 Conductor 16.00 mm2 No. of Cores 3 4 5 7 Nom. Overall Diameter (mm) 21.5 23.6 26.0 28.5 Copper Weight (kg/km) 594.86 787.92 916.30 1,282.82 Nom. Overall Diameter (mm) 17.8 19.8 21.7 23.8 29.2 Copper Weight (kg/km) 355.15 507.64 583.10 780.08 1,004.24 4G4CY 5G4CY 7G4CY 9G4CY 12G4CY Conductor 25.00 mm2 EMEA Part Code 3GICY 4GICY 5GICY 7GICY APAC Part Code 3G16CY 4G16CY 5G16CY 7G16CY No. of Cores 3 4 5 7 Nom. Overall Diameter (mm) 25.9 28.6 31.5 34.2 • Putup length & tolerance of the cables will vary depending on the construction of the cable • MOQ will vary depending on the construction of the cable & provided at the time of quotation • Cable requested outside the above design criteria can be reviewed and quoted Copper Weight (kg/km) 853.33 1,137.78 1,372.00 1,920.80 MachFlex 350 CY Shielded (CY) PVC Control Cables TINNED COPPER BRAID SHIELDED CABLE WITHOUT (G) PROTECTIVE GROUND 5 4 3 2 1 Conductor 0.50 mm2 No. of Cores 3 4 5 7 12 20 Nom. Overall Diameter (mm) 7.2 7.7 8.3 9.1 11.4 13.7 1 = Conductor 2 = Insulation 3 = Inner Sheath 4 = Tinned Copper Braid Shielded 5 = Outer Sheath Conductor 0.75 mm2 Copper Weight (kg/km) 45.08 53.90 64.68 78.40 135.73 226.25 EMEA Part Code 3XACY 4XACY 5XACY 7XACY 12XACY 20XACY APAC Part Code 3X0.5CY 4X0.5CY 5X0.5CY 7X0.5CY 12X0.5CY 20X0.5CY Conductor 1.00 mm2 No. of Cores 3 4 5 7 12 20 Nom. Overall Diameter (mm) 7.7 8.3 9.2 9.9 12.4 15.0 Copper Weight (kg/km) 55.86 62.72 75.46 99.96 173.46 289.10 EMEA Part Code 3XBCY 4XBCY 5XBCY 7XBCY 12XBCY 20XBCY APAC Part Code 3X0.75CY 4X0.75CY 5X0.75CY 7X0.75CY 12X0.75CY 20X0.75CY Conductor 1.50 mm2 No. of Nom. Overall Copper Weight Cores Diameter (mm) (kg/km) 3 8.2 63.70 4 9.1 76.44 5 9.8 87.22 7 10.5 110.74 12 13.3 184.34 20 16.1 307.23 Conductor 2.50 mm2 EMEA Part Code 3XCCY 4XCCY 5XCCY 7XCCY 12XCCY 20XCCY APAC Part Code 3X1.0CY 4X1.0CY 5X1.0CY 7X1.0CY 12X1.0CY 20X1.0CY No. of Nom. Overall Copper Weight Cores Diameter (mm) (kg/km) 3 9.0 77.42 4 9.7 95.06 5 10.5 113.68 7 11.3 146.02 12 14.4 274.40 20 17.5 457.33 Conductor 4.00 mm2 EMEA Part Code 3XDCY 4XDCY 5XDCY 7XDCY 12XDCY 20XDCY APAC Part Code 3X1.5CY 4X1.5CY 5X1.5CY 7X1.5CY 12X1.5CY 20X1.5CY No. of Nom. Overall Copper Weight Cores Diameter (mm) (kg/km) 3 11.0 143.08 4 11.9 163.66 5 12.9 196.00 7 14.0 282.24 12 18.2 467.75 20 22.7 779.58 Conductor 6.00 mm2 EMEA Part Code 3XECY 4XECY 5XECY 7XECY 12XECY 20XECY APAC Part Code 3X2.5CY 4X2.5CY 5X2.5CY 7X2.5CY 12X2.5CY 20X2.5CY No. of Nom. Overall Copper Weight Cores Diameter (mm) (kg/km) 3 12.6 174.20 4 13.7 232.26 5 14.9 274.40 7 16.2 384.16 9 20.0 493.92 12 21.5 658.56 Conductor 10.00 mm2 EMEA Part Code 3XFCY 4XFCY 5XFCY 7XFCY 9XFCY 12XFCY APAC Part Code 3X4CY 4X4CY 5X4CY 7X4CY 9X4CY 12X4CY No. of Cores 3 4 5 7 9 EMEA Part Code 3XGCY 4XGCY 5XGCY 7XGCY 9XGCY APAC Part Code 3X6CY 4X6CY 5X6CY 7X6CY 9X6CY No. of Cores 3 4 5 7 9 EMEA Part Code 3XHCY 4XHCY 5XHCY 7XHCY 9XHCY APAC Part Code 3X10CY 4X10CY 5X10CY 7X10CY 9X10CY EMEA Part Code 3XJCY 4XJCY 5XJCY 7XJCY APAC Part Code 3X25CY 4X25CY 5X25CY 7X25CY Nom. Overall Diameter (mm) 14.6 16.0 17.5 19.1 23.6 Copper Weight (kg/km) 233.73 311.64 432.18 519.40 667.80 Conductor 16.00 mm2 No. of Cores 3 4 5 7 Nom. Overall Diameter (mm) 21.5 23.6 26.0 28.5 Copper Weight (kg/km) 594.86 787.92 916.30 1,282.82 Nom. Overall Diameter (mm) 17.8 19.8 21.7 23.8 29.2 Copper Weight (kg/km) 355.15 507.64 583.10 780.08 1,004.24 Conductor 25.00 mm2 EMEA Part Code 3XICY 4XICY 5XICY 7XICY APAC Part Code 3X16CY 4X16CY 5X16CY 7X16CY No. of Cores 3 4 5 7 Nom. Overall Diameter (mm) 25.9 28.6 31.5 34.2 • Putup length & tolerance of the cables will vary depending on the construction of the cable • MOQ will vary depending on the construction of the cable & provided at the time of quotation • Cable requested outside the above design criteria can be reviewed and quoted Copper Weight (kg/km) 853.33 1,137.78 1,372.00 1,920.80
5GBCY-KC50 价格&库存
很抱歉,暂时无法提供与“5GBCY-KC50”相匹配的价格&库存,您可以联系我们找货
5GBCY-KC50
  • 1+12.350921+1.59330
  • 25+10.2486425+1.32210
  • 50+9.1099050+1.17520
  • 100+8.05876100+1.03960
库存:137
