Part Number: 6541PA
Security & Sound, 2 Pair 22 AWG BC, Individually Shielded, Plenum
Product Description
Security, Pro Audio & Intercom Cable, 2 Pair 22 AWG stranded (7x30) bare copper pairs with FEP insulation, Individually Beldfoil® shielded, Plenum, PVDF
jacket with ripcord.
Technical Specifications
Product Overview
Environmental Space:
Indoor - Plenum
Physical Characteristics (Overall)
Conductor
AWG Stranding
22
7x30
Material
Nominal Diameter No. of Pairs
BC - Bare Copper 0.029 in
Conductor Count:
4
Total Number of Pairs:
2
AWG Size:
22
2
Insulation
Material
Material Trade Name Nominal Diameter Nominal Wall Thickness
FEP - Fluorinated Ethylene Propylene Teflon®
0.049 in
0.01 in
Color Chart
Number
Color
1
Black & Red
2
Black & White
Inner Shield Material
Type
Material
Material Trade Name Coverage [%] Drainwire Material
Tape Aluminum Foil-Polyester Tape Beldfoil®
100 %
Drainwire AWG
TC - Tinned Copper 24
TC - Tinned Copper
Outer Shield Material
Material
Unshielded
Outer Jacket Material
Material
Nominal Diameter Nominal Wall Thickness Ripcord
PVDF - Fluorocopolymer 0.214 in
0.015 in
Construction and Dimensions
Stranding
Lay Length
1.375 in
Twists
6.9 twist/ft
Electrical Characteristics
Conductor DCR
Individual Pair Nominal Shield DCR Nominal Conductor DCR
Yes
15.3 Ohm/1000ft
16.4 Ohm/1000ft
Capacitance
Nom. Capacitance Conductor to Conductor Nom. Capacitance Conductor to Other Conductor to Shield
27.5 pF/ft
49.5 pF/ft
Inductance
Nominal Inductance
0.18 µH/ft
Impedance
Nominal Characteristic Impedance
50 Ohm
Delay
Nominal Velocity of Propagation (VP) [%]
69 %
Current
Max. Recommended Current [A]
2.2 Amps per conductor @ 25°C
Voltage
UL Voltage Rating
300V RMS
Temperature Range
UL Temp Rating:
75°C
Operating Temp Range:
-20°C To +150°C
Mechanical Characteristics
Bulk Cable Weight:
23.7 lbs/1000ft
Max Recommended Pulling Tension:
47.4 lbs
Min Bend Radius/Minor Axis:
2.1 in
Standards
NEC Articles:
800
NEC/(UL) Specification:
CMP
CEC/C(UL) Specification:
CMP
Applicable Environmental and Other Programs
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2003/96/EC (BFR):
Yes
EU Directive 2011/65/EU (ROHS II):
Yes
EU Directive 2012/19/EU (WEEE):
Yes
EU Directive Compliance:
EU Directive 2003/11/EC (BFR)
EU CE Mark:
Yes
EU RoHS Compliance Date (yyyy-mm-dd): 2005-04-01
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
Flammability, LS0H, Toxicity Testing
C(UL) Flammability:
FT6
UL Flammability:
NFPA 262
Part Number
Plenum (Y/N):
Yes
Variants
Item #
6541PA 0081000
Color
Footnote
GRAY C
6541PA 008U1000 GRAY
Footnote:
C - CRATE REEL PUT-UP.
Product Notes
Notes:
Teflon« is a registered trademark of E. I. duPont de Nemours and Co. used under license by Belden, Inc.
© 2018 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without
notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages
(including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract,
negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS(Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be instock at Belden facilities and in our Distributor's
inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden's knowledge,
information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product
itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for
determining the applicability of legislation and regulations based on their individual usage of the product.
Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC.
很抱歉,暂时无法提供与“6541PA 008U1000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 5000+13.849035000+1.79146
