70040.00100
70040.00100
    BELDEN
    BELDEN - 70040.00100 - Multicore Cable, Screened, 2 Core, 24 AWG, 0.22 mm², 328 ft, 100 m
70040.00100 数据手册
Part Number: 70040 MICROPHONECABLE 1PR AWG24 Product Description MICROPHONECABLE 1PR AWG24/0.22mm² Technical Specifications Product Overview Environmental Space: Indoor Suitable Applications: Microphone cable Physical Characteristics (Overall) Conductor AWG Stranding 24 32x38 Material Construction n x D BOFC - Bare Oxygen free Copper 32x0.10 mm Conductor Count: 2 Total Number of Pairs: 1 Insulation Type Material Nominal Diameter Diameter +/- Tolerance Insulation Polyethylene 1.45 mm 0.05 mm Color Chart Number Color Wire 1 Red Wire 2 Blue Color Chart 2 Color Black Red (like RAL 3001) Yellow (like RAL 1003) Green (like RAL 6029) Blue (like RAL 5005) Gray (like RAL 7000) Color Chart2, Table Note: Possible color of outerjacket Outer Shield Material Type Material Min. Coverage [%] Serve BC - Bare Copper 90 % Outer Jacket Material Material Nominal Diameter Diameter +/- Tolerance Flexible PVC with matte finish 6.10 mm Construction and Dimensions Cabling 0.20 mm Description Filler 2 fillers + 2 wires twisted Cotton yarn (2x) Electrical Characteristics Conductor DCR Max. Conductor DCR 78 Ohm/km Capacitance Nom. Capacitance Conductor to Conductor Nom. Capacitance Conductor to Shield 60 pF/m 110 pF/m Temperature Range Storage Temp Range: -15°C To +60°C Operating Temp Range (Fixed Install): -5°C To +60°C Mechanical Characteristics Min Bend Radius During Installation: 61 mm Applicable Environmental and Other Programs EU RoHS Compliance Date (yyyy-mm-dd): 2018-03-23 Part Number Variants Item # Color Length 70040.00100 Black 100 m 70040.00500 Black 500 m 70040.001000 Black 1,000 m History Update and Revision: Revision Number: 0.122 Revision Date: 08-22-2019 © 2019 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product.
70040.00100 价格&库存
很抱歉,暂时无法提供与“70040.00100”相匹配的价格&库存,您可以联系我们找货
