7987P 1NDU1000
7987P 1NDU1000
    BELDEN
    4 PR #24 FEP FLRST
7987P 1NDU1000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7987P Multi-Conductor - 4-Pair UTP Cable for RGB Video For more Information please call 1-800-Belden1 General Description: NanoSkew™ 24 AWG twisted pairs solid bare copper conductors, FEP insulation, rip cord, Flamarrest® jacket. Usage (Overall) Suitable Applications: UTP Based Video Applications, Not for data transmission requiring TIA/EIA Category qualifications, RGB Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material 4 24 Solid BC - Bare Copper Total Number of Conductors: 8 Insulation Insulation Material: Insulation Material FEP - Fluorinated Ethylene Propylene Outer Shield Outer Shield Material: Outer Shield Material Unshielded Outer Jacket Outer Jacket Material: Outer Jacket Trade Name Outer Jacket Material Flamarrest® LS PVC - Low Smoke Polyvinyl Chloride Outer Jacket Ripcord: Yes Overall Cable Overall Nominal Diameter: 0.201 in. Pair Pair Color Code Chart: Number Color 1 White/Blue Stripe & Blue 2 White/Orange Stripe & Orange 3 White/Green Stripe & Green 4 White/Brown Stripe & Brown Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +75°C Bulk Cable Weight: 21 lbs/1000 ft. Max. Recommended Pulling Tension: 40 lbs. Min. Bend Radius/Minor Axis: 0.200 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMP CEC/C(UL) Specification: CMP EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes Page 1 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7987P Multi-Conductor - 4-Pair UTP Cable for RGB Video EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: NFPA 262 CSA Flame Test: FT6 Plenum/Non-Plenum Plenum (Y/N): Yes Non-Plenum Number: 7987R Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 100 Nominal Velocity of Propagation: VP (%) 70 Typical Delay Skew: Delay Skew (ns/ft) 0.007 Maximum Conductor DC Resistance: DCR @ 20°C (Ohm/100 m) 9 Max. Operating Voltage - UL: Voltage 300 V RMS Electrical Characteristics-Premise (Overall) Premise Cable Electrical Table 2: Freq. (MHz) Input (Unfitted) Imp. (Ohms) Fitted Impedance 1 100 ± 15 100 ± 15 4 100 ± 15 100 ± 15 8 100 ± 15 100 ± 15 10 100 ± 15 100 ± 15 16 100 ± 15 100 ± 15 20 100 ± 15 100 ± 15 25 100 ± 15 100 ± 15 31.25 100 ± 15 100 ± 15 62.5 100 ± 15 100 ± 15 100 100 ± 15 100 ± 15 Notes (Overall) Notes: Jacket sequentially marked at 2 ft. intervals. Put Ups and Colors: Item # Putup Ship Weight Color 7987P 1NDU1000 1,000 FT 22.000 LB MAROON 1ND 4 PR #24 FEP FLRST 7987P 1NDU1640 1,640 FT 36.080 LB MAROON 1ND 4 PR #24 FEP FLRST Revision Number: 3 Notes Item Desc Revision Date: 08-01-2013 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 2 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7987P Multi-Conductor - 4-Pair UTP Cable for RGB Video Page 3 of 3 08-26-2016
7987P 1NDU1000 价格&库存
很抱歉,暂时无法提供与“7987P 1NDU1000”相匹配的价格&库存,您可以联系我们找货
7987P 1NDU1000
  • 1000+11.854891000+1.53563
