9182NH.00305
9182NH.00305
    BELDEN
    BELDEN - 9182NH.00305 - Twinaxial Cable, Datalene® Insulated, 22 AWG, Black, 1000 ft, 304.8 m
9182NH.00305 数据手册
TECHNICAL DATA SHEET 9182NH code version date page 9182NH 5 2007-02-15 1/2 APPLICATION Twinaxial instrumentation and computer cable for data transmission applications. CONSTRUCTION 1 2 3 7 4 5 6 1. 2. 3. 4. 5. 6. 7. Conductor Insulation Material Diameter over insulation Colour of insulation Filler (2x) Material Diameter Colour Foil (Duofoil®) Material Thickness Drainwire Foil Material Thickness Sheath Material Colour Nominal thickness Nominal diameter AWG22 (19xAWG34) tinned Cu Foamed high density Polyethylene 3.45 ± 0.10 mm Black and yellow Foamed fibrillated Polypropylene 2.92 mm White Aluminium/Polyester/Aluminium 9 / 23 / 9 µm AWG22 (19xAWG34) tinned Cu Polyester 23 µm FRNC (UV stabilised) Black 0.89 mm 8.80 mm REQUIREMENTS AND TEST METHODS Electrical: Nominal resistance conductor @ 20 °C Nominal resistance shield @ 20 °C Nominal capacitance conductor to conductor Nominal capacitance conductor to shield Nominal impedance Nominal velocity of propagation Nominal delay Nominal inductance Nominal attenuation @ 1 MHz Nominal attenuation @ 5 MHz Nominal attenuation @ 10 MHz 45.9 Ω/km 20.7 Ω/km 28.9 pF/m 54.1 pF/m 150 Ω 78 % 4.3 ns/m 0.96 µH/m 1.31 dB/100m 2.79 dB/100m 3.94 dB/100m  Belden Wire & Cable B.V. All rights are reserved. Reproduction in whole or in part is prohibited without the written consent of the copyright owner TECHNICAL DATA SHEET 9182NH Nominal attenuation @ 20 MHz Nominal attenuation @ 50 MHz Nominal attenuation @ 100 MHz Nominal attenuation @ 200 MHz Nominal attenuation @ 400 MHz Testvoltage conductor-conductor Testvoltage conductor-screen Voltage rating code version date page 9182NH 5 2007-02-15 2/2 5.58 dB/100m 8.86 dB/100m 14.11 dB/100m 20.34 dB/100m 28.87 dB/100m 2500 VDC, 3 seconds 2500 VDC, 3 seconds 300 V RMS Mechanical and physical: Flame resistance Oil resistance Radiation resistance Application specification Halogen content according to IEC754-1 Corrosivity of fire gasses according to IEC754-2 Conductivity pH value Temperature range installing Temperature range operating (moving installation) Temperature range operating (fixed installation) Temperature range storage Minimum bending radius IEC 60332-3C ASTMD741 IEC544 (CERN) BS 7655 section 6.1 table 1, LTS 3 zero ≤ 100 µS/cm ≥ 3.5 -15 to +80 ˚C -15 to +80 ˚C -45 to +80 ˚C -45 to +80 ˚C 10 x cable diameter PACKAGING On non-returnable reels (E 500) with a nominal length of 305m (-0, +10%) or on nonreturnable reels (E 560) with a nominal length of 500m (-0, +10%) or on non-returnable reels (E 600) with a nominal length of 1000m (-0, +10%). Each reel is labelled with the following data: Belden Logo. Belden code number. Item description. Length on the reel. Date of manufacture. CE-marking. Belden CDT believes this product to be in compliance with the environmental regulations EU RoHS (Directive 2002/95/EC, 27 January 2003); this is valid for all material produced after the RoHS compliant date for this product.  Belden Wire & Cable B.V. All rights are reserved. Reproduction in whole or in part is prohibited without the written consent of the copyright owner
9182NH.00305 价格&库存
很抱歉,暂时无法提供与“9182NH.00305”相匹配的价格&库存,您可以联系我们找货
