9207 0101000
    BELDEN
    TWINAX 20AWG 100 OHM
9207 0101000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9207 Twinax - Twinaxial Cable For more Information please call 1-800-Belden1 General Description: 20 AWG stranded (7x28) one tinned copper conductor, one bare copper conductor, polyethylene insulation, polyethylene inner jacket, Duofoil® (100% coverage) plus a tinned copper braid shield (85% coverage), PVC outer jacket. Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material Dia. (in.) 1 20 7x28 TC - Tinned Copper .037 BC - Bare Copper Total Number of Conductors: 2 Insulation Insulation Material: Insulation Material Wall Thickness (in.) PE - Polyethylene 0.024 Inner Jacket Inner Jacket Material: Inner Jacket Material Nom Wall (in.) Nom. Dia. (in.) PE - Polyethylene 0.035 0.236 Outer Shield Outer Shield Material: Layer # Outer Shield Trade Name Type Outer Shield Material 1 Duofoil® Coverage (%) Tape Aluminum Foil-Polyester Tape-Aluminum Foil 100 2 Braid TC - Tinned Copper 85 Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (in.) PVC - Polyvinyl Chloride 0.031 Overall Cable Overall Nominal Diameter: 0.330 in. Pair Pair Color Code Chart: Number Color 1 Natural (bare copper conductor) 2 Natural (tinned copper conductor) Mechanical Characteristics (Overall) Operating Temperature Range: -30°C To +75°C Bulk Cable Weight: 63 lbs/1000 ft. Max. Recommended Pulling Tension: 112 lbs. Min. Bend Radius/Minor Axis: 3.500 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CL2, CMG CEC/C(UL) Specification: CMG EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes Page 1 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9207 Twinax - Twinaxial Cable EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Customer Part Number Reference Specification: IBM P/N 7362211 Flame Test UL Flame Test: UL1685 FT4 Loading CSA Flame Test: FT4 Suitability Suitability - Indoor: Yes Suitability - Outdoor: Yes Plenum/Non-Plenum Plenum (Y/N): No Plenum Number: 89207 Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 100 Nom. Inductance: Inductance (µH/ft) 0.155 Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 14.5 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/ft) 23.0 Nominal Velocity of Propagation: VP (%) 66 Nominal Delay: Delay (ns/ft) 1.54 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 9.5 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 1.74 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 1 0.3 10 1.2 50 2.8 100 4.1 200 6.4 400 10.2 Max. Operating Voltage - UL: Voltage 300 V RMS Max. Operating Voltage - Non-UL: Voltage 600 V RMS Put Ups and Colors: Page 2 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9207 Twinax - Twinaxial Cable Item # Putup Ship Weight Color 9207 010U500 500 FT 33.000 LB BLACK Notes Item Desc 9207 010100 100 FT 7.100 LB BLACK 9207 0101000 1,000 FT 68.000 LB BLACK C 100 OHM TWINAX 9207 0101640 1,640 FT 111.520 LB BLACK C 100 OHM TWINAX 9207 0103280 3,280 FT 219.760 LB BLACK C 100 OHM TWINAX 9207 010500 500 FT 34.500 LB BLACK C 100 OHM TWINAX 9207 0105000 5,000 FT 350.000 LB BLACK C 100 OHM TWINAX 100 OHM TWINAX 100 OHM TWINAX Notes: C = CRATE REEL PUT-UP. Revision Number: 2 Revision Date: 09-26-2012 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 08-26-2016
9207 0101000 价格&库存
很抱歉,暂时无法提供与“9207 0101000”相匹配的价格&库存,您可以联系我们找货
