9231 008500
9231 008500
    BELDEN
    #20 PE DBL BRD PVC
9231 008500 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9231 Coax - RG-59/U Type For more Information please call 1-800-Belden1 General Description: 20 AWG solid .031" bare copper conductor, polyethylene insulation, tinned copper braid shields (95% coverage), PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material Dia. (in.) 1 20 Solid BC - Bare Copper .031 Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Dia. (in.) PE - Polyethylene .198 Outer Shield Outer Shield Material: Layer # Type Outer Shield Material Coverage (%) 1 Braid TC - Tinned Copper 95.000 2 Braid TC - Tinned Copper 95.000 Outer Jacket Outer Jacket Material: Outer Jacket Material PVCNC - Polyvinyl Chloride Non-Contaminating Overall Cable Overall Nominal Diameter: 0.305 in. Mechanical Characteristics (Overall) Operating Temperature Range: -40°C To +60°C UL Temperature Rating: 60°C Bulk Cable Weight: 71 lbs/1000 ft. Max. Recommended Pulling Tension: 168 lbs. Min. Bend Radius/Minor Axis: 3 in. Min. Bend Radius (Continuous Flexing): 6 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMH CEC/C(UL) Specification: CMH EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 10/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes RG Type: 59/U Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9231 Coax - RG-59/U Type Flame Test UL Flame Test: UL1685 UL Loading, VW-1 Suitability Suitability - Indoor: Yes Suitability - Outdoor: Yes Suitability - Aerial: Yes - When supported by a messenger wire Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 75 Nom. Inductance: Inductance (µH/ft) 0.118 Nom. Capacitance Conductor to Shield: Capacitance (pF/ft) 21 Nominal Velocity of Propagation: VP (%) 66 Nominal Delay: Delay (ns/ft) 1.54 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 9.9 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 1.1 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 1 0.3 3.6 0.5 10 0.8 71.5 2.0 135 3.5 270 4.3 360 5.0 540 6.2 720 7.2 750 7.4 1000 9.1 Max. Operating Voltage - UL: Voltage 300 V RMS Max. Operating Voltage - Non-UL: Voltage 1700 V RMS Other Electrical Characteristic 1: Impedance tested in accordance with ASTM D-4566 paragraph 43.2, option 2 using a 75 Ohm fixed bridge and termination. 75 +/- 1.5 Ohms Other Electrical Characteristic 2: Return Loss tested in accordance with ASTM D-4566 paragraph 45.3, using a 75 ohm fixed bridge and termination. 720A Series is available by special request. Minimum Return Loss: Start Freq. (MHz) Stop Freq. (MHz) Min. RL (dB) 5 216 27 217 850 23 Sweep Test Sweep Testing: 100% sweep tested. 5 Mhz to 850 MHz. Page 2 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9231 Coax - RG-59/U Type Notes (Overall) Notes: Non-Plenum versions comply with Telcordia Specification GR-139-CORE. Put Ups and Colors: Item # Putup Ship Weight 9231 1 EA 5.773 LB Color Notes 9231 0081000 1,000 FT 76.000 LB GRAY C 9231 008500 500 FT 39.000 LB GRAY Item Desc 0985 S4742 104/70 M #20 PE DBL BRD PVC #20 PE DBL BRD PVC Notes: C = CRATE REEL PUT-UP. Revision Number: 2 Revision Date: 08-24-2012 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 01-05-2017
9231 008500 价格&库存
很抱歉,暂时无法提供与“9231 008500”相匹配的价格&库存,您可以联系我们找货
