9232 0101000
9232 0101000
    BELDEN
    75 OHM TRIAX
9232 0101000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9232 Coax - RG-11/U Type For more Information please call 1-800-Belden1 General Description: 15 AWG stranded (19x27) .064" bare copper conductor, foam HDPE insulation, paper tape separator, bare copper braid shields (90% and 80% coverage), CSPE - Chlorosulphonated Polyethylene jacket. Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material Dia. (in.) 1 15 19x27 BC - Bare Copper .064 Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Dia. (in.) Gas-injected FHDPE - Foam High Density Polyethylene .312 Inner Shield Inner Shield Material: Type Inner Shield Material Coverage (%) Braid BC - Bare Copper 90 Inner Jacket Inner Jacket Material: Inner Jacket Material Nom. Dia. (in.) PE - Polyethylene .391 Outer Shield Outer Shield Material: Type Outer Shield Material Coverage (%) Braid BC - Bare Copper 80.000 Outer Shield Separator Material: Paper Tape Outer Jacket Outer Jacket Material: Outer Jacket Material CSPE - Chlorosulphonated Polyethylene Overall Cable Overall Nominal Diameter: 0.520 in. Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +75°C UL Temperature Rating: 60°C Non-UL Temperature Rating: 75°C Bulk Cable Weight: 135 lbs/1000 ft. Max. Recommended Pulling Tension: 239 lbs. Min. Bend Radius/Minor Axis: 5.250 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs AWM Specification: UL Style 1641 (30 V 60°C) EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: No EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9232 Coax - RG-11/U Type EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes RG Type: 11/U Flame Test UL Flame Test: VW-1 Other Flame Test: UL2556 Suitability Suitability - Indoor: Yes Suitability - Outdoor: Yes Suitability - Burial: Yes Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 75 Nom. Inductance: Inductance (µH/ft) 0.097 Nom. Capacitance Conductor to Shield: Capacitance (pF/ft) 17.3 Nominal Velocity of Propagation: VP (%) 78 Nominal Delay: Delay (ns/ft) 1.30 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 3.1 Nom. Inner Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 1.6 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 1.6 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 1.000 0.100 3.600 0.300 10.000 0.500 71.500 1.200 135.000 1.800 270.000 2.600 360.000 3.100 540.000 3.900 720.000 4.700 750.000 4.800 1000.000 5.700 Max. Operating Voltage - UL: Voltage 30 V RMS Max. Operating Voltage - Non-UL: Voltage Page 2 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9232 Coax - RG-11/U Type 300 V RMS Other Electrical Characteristic 1: Nominal Capacitance 1st Shield to 2nd Shield: 205 pf/ft. Other Electrical Characteristic 2: Nominal Voltage Breakdown: 20K V RMS Minimum Return Loss: Description Freq. (MHz) Start Freq. (MHz) Stop Freq. (MHz) Min. RL (dB) 5 450 21 Sweep Test Sweep Testing: 100% sweep tested 5 MHz to 450 MHz. Misc. Information (Overall) Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 9232 0101000 1,000 FT 141.000 LB BLACK C 75 OHM TRIAX 9232 010500 500 FT 75.500 LB BLACK C 75 OHM TRIAX Notes: C = CRATE REEL PUT-UP. Revision Number: 10 Revision Date: 08-12-2013 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 3 of 3 01-05-2017
9232 0101000 价格&库存
很抱歉,暂时无法提供与“9232 0101000”相匹配的价格&库存,您可以联系我们找货
