9258 0101000
9258 0101000
    BELDEN
    RG-8X TYPE COAX
9258 0101000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9258 Coax - RG-8X Type For more Information please call 1-800-Belden1 General Description: RG-8X type, 16 AWG stranded (19x29) .058" bare copper conductor, gas-injected FPE insulation, bare copper braid shield (95% coverage), PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material Dia. (in.) 1 16 19x29 BC - Bare Copper .058 Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Dia. (in.) Gas-injected FPE - Foam Polyethylene .155 Outer Shield Outer Shield Material: Type Outer Shield Material Coverage (%) Braid BC - Bare Copper 95 Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Overall Cable Overall Nominal Diameter: 0.242 in. Mechanical Characteristics (Overall) Operating Temperature Range: -40°C To +80°C UL Temperature Rating: 80°C (UL AWM Style 1354) Bulk Cable Weight: 37 lbs/1000 ft. Max. Recommended Pulling Tension: 75 lbs. Min. Bend Radius/Minor Axis: 2.500 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CM CEC/C(UL) Specification: CM AWM Specification: UL Style 1354 (30 V 80°C) EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: No EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes RG Type: 8/X Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9258 Coax - RG-8X Type Flame Test UL Flame Test: UL1685 UL Loading Suitability Suitability - Indoor: Yes Suitability - Outdoor: Yes Suitability - Aerial: Yes Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 50 Nom. Inductance: Inductance (µH/ft) .065 Nom. Capacitance Conductor to Shield: Capacitance (pF/ft) 24.8 Nominal Velocity of Propagation: VP (%) 82 Nominal Delay: Delay (ns/ft) 1.2 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 4.3 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 3.3 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 1 .3 10 .9 50 2.1 100 3.1 200 4.5 400 6.6 700 9.1 900 10.7 1000 11.2 Max. Power Rating: Freq. (MHz) Rating (W) 10 1000 50 370 100 250 200 190 400 110 700 75 1000 60 Max. Operating Voltage - UL: Voltage 300 V RMS Put Ups and Colors: Item # Putup Ship Weight Color 9258 0091000 1,000 FT 40.000 LB WHITE RG-8X TYPE COAX 9258 010U1000 1,000 FT 39.000 LB BLACK RG-8X TYPE COAX 9258 010U500 500 FT 20.000 LB BLACK 9258 0101000 1,000 FT 40.000 LB BLACK Page 2 of 3 Notes Item Desc RG-8X TYPE COAX C RG-8X TYPE COAX 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9258 Coax - RG-8X Type 9258 010500 500 FT 20.000 LB BLACK C RG-8X TYPE COAX Notes: C = CRATE REEL PUT-UP. Revision Number: 1 Revision Date: 09-20-2012 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 3 of 3 01-05-2017
9258 0101000 价格&库存
很抱歉,暂时无法提供与“9258 0101000”相匹配的价格&库存,您可以联系我们找货
  • 1000+18.392471000+2.37935
