9262 0081000
9262 0081000
    BELDEN
    12#20,1#22,PVC,FPE S 1=1000'
9262 0081000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9262 Composite - Cables for TV Cameras and CCTV For more Information please call 1-800-Belden1 General Description: 13 conductor (1 coax, 12 cond), remote control and video cable, foam polyethylene (coax) and PVC (cond) insulation, coax: BC braid (95% coverage), overall TC braid (80% coverage), overall PVC jacket. Coax Physical Characteristics Conductor AWG: # Coax AWG Stranding Conductor Material Dia. (in.) 1 22 7x30 TC - Tinned Copper .031 Insulation Insulation Material: Insulation Material Dia. (in.) FPE - Foam Polyethylene .146 Inner Shield Inner Shield Material: Type Inner Shield Material % Coverage (%) Braid BC - Bare Copper 95 Inner Jacket Inner Jacket Material: Inner Jacket Material Nom. Dia. (in.) PVC - Polyvinyl Chloride .208 Electrical Characteristics Nom. Characteristic Impedance: Impedance (Ohm) 75 Nom. Capacitance Conductor to Shield: Capacitance (pF/ft) 17.3 Nominal Velocity of Propagation: VP (%) 78 Nominal Delay: Delay (ns/ft) 1.3 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 14.4 Nom. Inner Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 2.55 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) .5 .2 1 .29 5 .67 10 .95 100 3.1 200 4.4 400 6.3 Max. Operating Voltage - UL: 300 V RMS Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9262 Composite - Cables for TV Cameras and CCTV Twisted Pair Physical Characteristics Individual Shield Multi Conductor Physical Characteristics Conductor AWG: # Conductors AWG Stranding Conductor Material Dia. (in.) 12 20 7x28 TC - Tinned Copper 0.038 Insulation Insulation Material: Insulation Material Dia. (in.) PVC - Polyvinyl Chloride .070 Electrical Characteristics Max. Operating Voltage - UL: Voltage Voltage 300 V RMS 300 V RMS Physical Characteristics (Overall) Outer Shield Outer Shield Material: Type Outer Shield Material Coverage (%) Braid TC - Tinned Copper 80 Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Overall Cable Overall Nominal Diameter: 0.460 in. Mechanical Characteristics (Overall) Operating Temperature Range: -30°C To +75°C UL Temperature Rating: 75°C Bulk Cable Weight: 150 lbs/1000 ft. Max. Recommended Pulling Tension: 305 lbs. Min. Bend Radius/Minor Axis: 4.750 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CL2X AWM Specification: UL Style 1007 (singles), UL Style 1354 (Coax), UL Style 2594 (Overall) EU Directive 2011/65/EU (ROHS II): Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 04/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Max. Operating Voltage - UL: Voltage 300 V RMS Put Ups and Colors: Page 2 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9262 Composite - Cables for TV Cameras and CCTV Item # Putup Ship Weight Color 9262 008100 100 FT 16.700 LB GRAY 9262 0081000 1,000 FT 157.000 LB GRAY Notes Item Desc 12#20,1#22,PVC,FPE S PVC C 12#20,1#22,PVC,FPE S PVC Notes: C = CRATE REEL PUT-UP. Revision Number: 0 Revision Date: 08-22-2012 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 3 of 3 01-05-2017
9262 0081000 价格&库存
很抱歉,暂时无法提供与“9262 0081000”相匹配的价格&库存,您可以联系我们找货
  • 305+211.23654305+26.48720
  • 610+184.83198610+23.17630
