9265 010500
9265 010500
    BELDEN
    1 SH PR#22,1 75 OHM COAX
9265 010500 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9265 Composite - ENG, EFP and CCTV Cable For more Information please call 1-800-Belden1 General Description: 22 AWG stranded (7x30) conductors, foam polyethylene insulation (coax) and PVC (Pairs) insulation, coax w/BC braid shield (95% coverage), (1) twisted pair w/Beldfoil® shield, 22 AWG drain wire, PVC jacket. Coax Physical Characteristics Conductor AWG: # Coax AWG Stranding Conductor Material Dia. (in.) 1 22 7x30 BC - Bare Copper 0.030 Insulation Insulation Material: Insulation Material Dia. (in.) FPE - Foam Polyethylene 0.146 Inner Shield Inner Shield Material: Type Inner Shield Material % Coverage (%) Braid BC - Bare Copper 95 Applicable Specifications and Agency Compliance Applicable Standards & Environmental Programs EU CE Mark: No RG Type: 59/U Electrical Characteristics Nom. Characteristic Impedance: Impedance (Ohm) 75 Nom. Inductance: Inductance (µH/ft) 0.090 Nom. Capacitance Conductor to Shield: Capacitance (pF/ft) 17.300 Nominal Velocity of Propagation: VP (%) 78.000 Nominal Delay: Delay (ns/ft) 1.300 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 15.000 Nom. Inner Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 2.600 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 1.000 0.300 5.000 0.700 10.000 1.000 50.000 2.100 100.000 3.000 Other Electrical Characteristic 1: Coax Nominal Voltage Breakdown Jacket (Shield to Ground) = 22kV RMS Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9265 Composite - ENG, EFP and CCTV Cable Twisted Pair Physical Characteristics Conductor AWG: # Pairs AWG Stranding Conductor Material Dia. (in.) 1 22 7x30 TC - Tinned Copper 0.030 Insulation Insulation Material: Insulation Material Dia. (in.) PVC - Polyvinyl Chloride 0.054 Inner Shield Inner Shield Material: Inner Shield Trade Name Type Inner Shield Material Beldfoil® (Z-Fold®) Coverage (%) Tape Aluminum Foil-Polyester Tape 100 Inner Shield Drain Wire AWG: AWG Stranding Dia. (in.) Conductor Material 22 7x30 0.030 TC - Tinned Copper Inner Jacket Inner Jacket Color Code Chart: Number Color 1 Black 2 Red Electrical Characteristics Nom. Characteristic Impedance: Impedance (Ohm) 35 Nom. Capacitance Conductor to Shield: Capacitance (pF/ft) 95.500 Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 51.000 Nominal Velocity of Propagation: VP (%) 58.000 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 11.000 Other Electrical Characteristic 1: Twisted Pair Nominal Voltage Breakdown Jacket (Shield to Ground) = 19kV RMS Physical Characteristics (Overall) Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Overall Cable Overall Nominal Diameter: 0.470 in. Mechanical Characteristics (Overall) Operating Temperature Range: -40°C To +60°C Non-UL Temperature Rating: 60°C Bulk Cable Weight: 58.000 lbs/1000 ft. Max. Recommended Pulling Tension: 68.000 lbs. Min. Bend Radius/Minor Axis: 2.500 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CL2 AWM Specification: UL Style 20006 EU Directive 2011/65/EU (ROHS II): Yes Page 2 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9265 Composite - ENG, EFP and CCTV Cable EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 04/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: UL1685 UL Loading Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Max. Operating Voltage - UL: Voltage 30 V RMS Notes (Overall) Notes: Simaese Type Construction. Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 9265 0101000 1,000 FT 62.000 LB BLACK C 1 SH PR#22,1 75 OHM COAX 9265 010500 500 FT 32.500 LB BLACK C 1 SH PR#22,1 75 OHM COAX Notes: C = CRATE REEL PUT-UP. Revision Number: 0 Revision Date: 08-23-2012 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 3 of 3 01-05-2017
9265 010500 价格&库存
很抱歉,暂时无法提供与“9265 010500”相匹配的价格&库存,您可以联系我们找货
  • 500+31.76454500+4.10802
