9344 010500
    BELDEN
    CBL 1PR 12AWG SHLD
9344 010500 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9344 Multi-Conductor - 600V Tray Cable For more Information please call 1-800-Belden1 General Description: 12 AWG pairs stranded (37x27) tinned copper conductors, twisted pairs, overall Beldfoil® shield (100% coverage), PVC/Nylon insulation, PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material 1 12 37x27 TC - Tinned Copper Total Number of Conductors: 2 Insulation Insulation Material: Insulation Material PVC/Nylon - Polyvinyl Chloride/Nylon Outer Shield Outer Shield Material: Outer Shield Trade Name Type Outer Shield Material Beldfoil® Coverage (%) Tape Aluminum Foil-Polyester Tape 100 Outer Shield Drain Wire AWG: AWG Stranding Drain Wire Conductor Material 12 19x25 TC - Tinned Copper Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (in.) PVC - Polyvinyl Chloride .045 Outer Jacket Ripcord: Yes Overall Cable Overall Nominal Diameter: 0.384 in. Pair Pair Color Code Chart: Number Color 1 Black & Red Mechanical Characteristics (Overall) Wet Temperature Range: -30°C To +75°C Dry Temperature Range: -30°C To +90°C Bulk Cable Weight: 105 lbs/1000 ft. Max. Recommended Pulling Tension: 253 lbs. Min. Bend Radius/Minor Axis: 3.750 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: NPLF, TC EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 04/01/2005 EU Directive 2002/96/EC (WEEE): Yes Page 1 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9344 Multi-Conductor - 600V Tray Cable EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Other Specification: ICEA S-73-532, S-61-402 Flame Test UL Flame Test: UL1685 UL Loading CSA Flame Test: FT4 IEEE Flame Test: 1202 Suitability Suitability - Burial: Yes Sunlight Resistance: Yes Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Inductance: Inductance (µH/ft) .19 Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 56 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/ft) 106 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 1.65 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 1.56 Max. Operating Voltage - UL: Voltage 600 V RMS (NEC Type TC) 150 V RMS (NPLF) Max. Recommended Current: Current 30 Amps per conductor @ 25°C Notes (Overall) Notes: Alternate color coding available upon request. Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 9344 0101000 1,000 FT 115.000 LB BLACK C 2 #12 PVC/NYL SHLD PVC 9344 010500 500 FT 56.500 LB BLACK C 2 #12 PVC/NYL SHLD PVC Notes: C = CRATE REEL PUT-UP. Revision Number: 3 Revision Date: 08-07-2014 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 2 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9344 Multi-Conductor - 600V Tray Cable Page 3 of 3 08-26-2016
9344 010500 价格&库存
很抱歉,暂时无法提供与“9344 010500”相匹配的价格&库存,您可以联系我们找货
  • 500+105.58228500+13.21044
