9891 0061000
9891 0061000
    BELDEN
    4PR1#20,3#22 SH PVC
9891 0061000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9891 Multi-Conductor - 10 Base 5 Transceiver For more Information please call 1-800-Belden1 General Description: 20 and 22 AWG stranded tinned copper conductors, foam HDPE (22 AWG) and PVC (20 AWG) insulation, twisted pairs, tinned copper braid shield (95% coverage) drain wire, PVC jacket. Usage (Overall) Suitable Applications: IEEE 802.3 Transceiver Cable Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material Dia. (in.) 3 22 7x30 TC - Tinned Copper 0.030 1 20 7x28 TC - Tinned Copper 0.038 Total Number of Conductors: 8 Insulation Insulation Material: Insulation Trade Name Insulation Material Datalene® Wall Thickness (in.) AWG FHDPE - Foam High Density Polyethylene 0.017 22 PVC - Polyvinyl Chloride 20 0.012 Inner Shield Inner Shield Material: Layer # Inner Shield Trade Name Type 1 Beldfoil® (Z-Fold®) Inner Shield Material Coverage (%) Tape (each pair) Aluminum Foil-Polyester Tape 100.000 Outer Shield Outer Shield Material: Type Outer Shield Material Coverage (%) Braid TC - Tinned Copper 95 Outer Shield Drain Wire AWG: AWG Stranding Drain Wire Conductor Material 22 7x30 TC - Tinned Copper Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (in.) PVC - Polyvinyl Chloride 0.032 Overall Cable Overall Nominal Diameter: 0.316 in. Pair Pair Color Code Chart: Number Color 78 Ohm Black & White 78 Ohm Yellow & Orange 78 Ohm Blue & Green Power Pair Gray & Purple Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +80°C UL Temperature Rating: 80°C (UL AWM Style 2919) Bulk Cable Weight: 65 lbs/1000 ft. Max. Recommended Pulling Tension: 160 lbs. Min. Bend Radius/Minor Axis: 3.250 in. Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9891 Multi-Conductor - 10 Base 5 Transceiver Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CM NEC Articles: 800 CEC/C(UL) Specification: CM AWM Specification: UL Style 2919 (30 V 80°C) IEEE Specification: IEEE802.3 EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 04/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: UL1685 UL Loading CSA Flame Test: FT1 Suitability Suitability - Indoor: Yes Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Description Impedance (Ohm) Tolerance (Ohms) 22AWG pairs 78.000 ±5 Nom. Capacitance Conductor to Conductor: Description Capacitance (pF/ft) 22AWG pairs 16.700 Nom. Capacitance Cond. to Other Conductor & Shield: Description Capacitance (pF/ft) 22AWG pairs 29.500 Nominal Velocity of Propagation: Description VP (%) 22AWG pairs 78.000 Nominal Delay: Description Delay (ns/ft) 22AWG pairs 1.300 Nom. Conductor DC Resistance: Description DCR @ 20°C (Ohm/1000 ft) 22 AWG 14.7 20 AWG 9.5 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 1.8 Max. Operating Voltage - UL: Voltage Description 300 V RMS UL type CM 30 V RMS UL AWM Style 2919 Max. Recommended Current: Description Current 22 awg (10C Temperature Rise) 2 amps per conductor @ 25C ambient 20 awg (10C Temperature Rise) 2.5 amps per conductor @ 25C ambient Put Ups and Colors: Page 2 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9891 Multi-Conductor - 10 Base 5 Transceiver Item # Putup Ship Weight Color 9891 006100 100 FT 7.300 LB BLUE, LIGHT Notes Item Desc 9891 0061000 1,000 FT 69.000 LB BLUE, LIGHT C 4PR1#20,3#22 SH PVC 9891 006500 500 FT 35.500 LB BLUE, LIGHT C 4PR1#20,3#22 SH PVC 9891 0065000 5,000 FT 360.000 LB BLUE, LIGHT CZ 4PR1#20,3#22 SH PVC 4PR1#20,3#22 SH PVC Notes: C = CRATE REEL PUT-UP. Z = FINAL PUT-UP LENGTH MAY VARY (+ OR -) 10% FOR SPOOLS OR REELS AND(+ OR -) 5% FOR UNREEL CARTONS FROM LENGTH SHOWN. Revision Number: 3 Revision Date: 08-06-2013 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 01-05-2017
9891 0061000 价格&库存
很抱歉,暂时无法提供与“9891 0061000”相匹配的价格&库存,您可以联系我们找货
