Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
9975 Hook-up/Lead - UL AWM Style 1061
For more Information
please call
1-800-Belden1
General Description:
Tinned copper conductor, semi-rigid PVC insulation (solid conductors suitable for wire wrap applications).
Physical Characteristics (Overall)
Conductor
AWG:
# Conductors AWG Stranding Conductor Material
1
24
Solid
TC - Tinned Copper
Total Number of Conductors:
1
Insulation
Insulation Material:
Insulation Material
Wall Thickness (in.)
PVC - Polyvinyl Chloride .010
Overall Insulation
Overall Cable
Overall Nominal Diameter:
0.040 in.
Mechanical Characteristics (Overall)
Operating Temperature Range:
-20°C To +80°C
Bulk Cable Weight:
2 lbs/1000 ft.
Min. Bend Radius/Minor Axis:
0.313 in.
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
UL Rating:
300 V RMS, 80°C
CSA Rating:
300 V RMS, 80°C
CSA Type:
AWM I, A/B
EU Directive 2011/65/EU (ROHS II):
Yes
EU CE Mark:
Yes
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
10/01/2005
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
Flame Test
UL Flame Test:
VW-1
CSA Flame Test:
FT1
Plenum/Non-Plenum
Plenum (Y/N):
No
Electrical Characteristics (Overall)
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/1000 ft)
24.250
Max. Operating Voltage - UL:
Voltage
Page 1 of 2
08-26-2016
300 VRMS
Max. Recommended Current:
Description
Current
Single conductor @ 25C ambient (35C temperature rise) 3.5 amps
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
Notes
Item Desc
9975 0011000
1,000 FT
2.000 LB
BROWN
P
24 SOL PVC BRN
9975 002100
100 FT
0.200 LB
RED
9975 0021000
1,000 FT
2.000 LB
RED
P
24 SOL PVC RED
9975 0025000
5,000 FT
10.000 LB
RED
P
#24 SOL PVC RED
9975 0031000
1,000 FT
2.000 LB
ORANGE
P
24 SOL PVC ORG
9975 0041000
1,000 FT
2.000 LB
YELLOW
P
24 SOL PVC YEL
9975 0051000
1,000 FT
2.000 LB
GREEN, DARK
P
24 SOL PVC GRN
9975 0071000
1,000 FT
2.000 LB
VIOLET
P
24 SOL PVC VIO
9975 0081000
1,000 FT
2.000 LB
GRAY
P
24 SOL PVC GRY
9975 0091000
1,000 FT
2.000 LB
WHITE
P
24 SOL PVC WHT
9975 010100
100 FT
0.200 LB
BLACK
9975 0101000
1,000 FT
2.000 LB
BLACK
P
24 SOL PVC BLK
9975 0105000
5,000 FT
10.000 LB
BLACK
P
#24 SOL PVC BLK
9975 0131000
1,000 FT
2.000 LB
BLUE, DARK
P
24 SOL PVC DBLU
24 SOL PVC RED
24 SOL PVC BLK
Notes:
P = STRIPE COLORS ON STOCK SOLID COLORS. STRIPING ADDER OF $8.00/M' FOR1 OR 2 STRIPES. 10000' MINIMUM ORDER FOR COLOR COMBINATION.PUT-UP WILL BE
SUBJECT TO TWO PIECES (+ OR -) 10% PER SPOOL
Revision Number: 1
Revision Date: 04-23-2013
© 2016 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU).
Page 2 of 2
08-26-2016
很抱歉,暂时无法提供与“9975 0031000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1000+3.747781000+0.48073
- 国内价格 香港价格
- 305+4.01715305+0.51528
- 610+3.49739610+0.44861
