AX100344
AX100344
    BELDEN
    PS5 BIX DVO OUTLET,FLUSH
AX100344 数据手册
1 COPPERMedia DATASheet PS5E BIX DVO Outlet PS5E DVO Workstation Outlets are available in 1, 2 and 4-port configurations in both flush and surface mount styles. The workstation outlets are robust and installer-friendly products by design, combining punch-down connectors with standard modular jacks. The outlet’s unique completely enclosed housing protects the connectors and allows the wires to be front-terminated on BIX Insulation Displacement Connectors (IDC). The snap-on cover plate allows easy access and eliminates visible mounting screw. PS5E BIX DVO Outlets (for SF only) PS5E DVO Workstation Outlets offer headroom over the ANSI/TIA/EIA-568-B for Category 5e Cabling standard. Applications > Telecommunications outlets in the work areas. Technical specifications > Dimensions (H x W x D): 89 x 51 x 32 mm (3.5 x 2.0 x 1.25 in.). > Materials: Housing and cover: fire-retardant plastic, UL94V-0, gray, almond, white or black Connector module: printed circuit board, modular jacks and IDC connectors IDC Connector: Features & Benefits > Exceeds Category 5e performance providing additional margin to support emerging gigabit applications > Available in T568A-ISDN and T568B-ALT wiring patterns for simple wire termination according to the standard color-code sequence (Blue, Orange, Green, Brown) > Robust and installer-friendly design to reduce installation and operating costs IDC clip material: phosphor bronze with tin plating over nickel Housing material: fire-retardant plastic, UL94V-0 Quiet front, with fully recessed clips Housing color: blue for T568A-ISDN or orange for T568B-ALT. Modular Jack: > Fully enclosed connector module in plastic housing for better protection Contact material: phosphore bronze with 50 micro-inches gold over nickel. > Front-access wire termination for trouble-free installation, testing and maintenance > Snap-on cover mechanism eliminating visible mounting screws > Color coding and service identification labeling option at each port using icons to facilitate identification and ease network management > Available in surface and flush-mounted versions, in 1, 2 and 4-port configurations for greater installation flexibility. 1-800-BELDEN-1 • www.belden.com 2 COPPERMedia DATASheet PS5E BIX DVO Outlet Mechanical Characteristics Electrical Characteristics Packaging > IDC Termination Interface: > Dielectric strength: 1,000 V RMS at 60 Hz for 1 minute > Individually packaged in a clear plastic bag, including mounting screws (surface mount includes double-sided tape) Gas-tight connection – insulation slicing of 22, 24 and 26 AWG (0.64, 0.5 and 0.4 mm) plastic insulated solid copper conductors > Current rating: 1.5 A maximum > Insulation resistance: 200 MΩ minimum > Contact resistance: 1 mΩ per contact. Durability: 200 insertions of any combination of wire gauge 4-pair printed circuit board mounted IDC connector type Compatible with the BIX Connecting Tool (sold separately). Modular Jack: 8-pin connector, FCC part 68, Subpart F compliant Durability: 1000 mating cycles. > Standard shipping carton of 50 units > Surface mount includes double-side tape. Installation tips > Verify clearence space and select the oppropriate electrical box or mounting frame prior to installing > Mount the outlet housing on the wall prior to termination > Label each port carefully for future reference and ease of administration > Use different colored icons to ease identification and location of users, areas or types of service For More Information For any other product information call: 1-800-BELDEN-1 or visit us at www.Belden.com All information is subject to change without notice, since Belden reserves the right to change its products as progress in engineering and manufacturing methods or other circumstances may warrant. > Unlatch the cover by inserting and twisting a flat screwdriver in the opening at the bottom or the side of the cover. Ordering Information PS5E BIX DVO Outlet DETAIL 1-port 2-port 4-port 1-port 2-port 4-port 1-port 2-port 4-port 1-port 2-port COLOR ORDERING NUMBER ORDERING NUMBER Gray Gray Gray Almond Almond Almond White White White Black Black SURFACE AX100382 AX100390 AX100398 AX100383 AX100391 AX100399 AX100384 AX100392 AX100400 AX100385 AX100393 FLUSH AX100334 AX100342 AX100350 AX100335 AX100343 AX100351 AX100336 AX100344 AX100352 AX100337 AX100345 1-800-BELDEN-1 • www.belden.com
AX100344 价格&库存
很抱歉,暂时无法提供与“AX100344”相匹配的价格&库存,您可以联系我们找货
