AX100648
AX100648
    BELDEN
    EZ-MDVO UTP MODULE, CAT5E,
AX100648 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION AX100648 Modular Connectors - CAT5E EZ-MDVO Modular Jack - MDVO style For more Information please call 1-800-Belden1 General Description: CAT5E EZ-MDVO Modular Jack, RJ45, MDVO-style, Black Usage (Overall) Suitable Applications: IBDN System 1200, TIA Category 5e, ISO Class D, 1000BASE-T Related Parts: Compatible with Interface and MDVO Style Faceplates, Adapters, Boxes and Patch Panels, Physical Characteristics (Connectivity) Dimensions Dimensions: Height (in.) Width (in.) Depth (in.) 0.710 0.750 1.250 Materials Materials: Description Type Material Front Connection Lead Frame Copper Allow with 50u inch Gold over Nickel Rear Connection IDC Copper Allow with Nickel Plating Connector Body Plastic - UL940V-0 Color Color: Black Wiring Scheme Wiring Scheme: T568A/B Weight Weight: 0.013 lbs. Included Parts Included Parts: Center Stuffercap Coded A/B Packaging Packaging: Individually packaged in a plastic bag. Standard pack of 50 units. Mechanical Characteristics (Connectivity) Footprint/Type: MDVO-Style Plug / Jack Compatibility: RJ45, RJ11 Termination Interface: Termination Connection Durabilities Front Mated Connection 1,000 cycles Rear Gas Tight IDC Connection 20 terminations Connector/Hardware Retention: 20 lbs. Plug/Connector Retention: 11.250 lbs. Storage Temperature Range: -40°C To +70°C Installation Temperature Range: -10°C To +60°C Operating Temperature Range: -10°C To +60°C Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs Other Standards: FCC Part 68, Subpart F, IEC 60603-7 EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2006 MII Order #39 (China RoHS): EUP 50 Telecommunications Standards: Category 5e - TIA 568.B.2, Category 5 - ISO/IEC 11801:2002 Ed.2 Page 1 of 3 02-27-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION AX100648 Modular Connectors - CAT5E EZ-MDVO Modular Jack - MDVO style Safety Listing: ACA, Bi-national Standard Listed Suitability Suitability - Indoor: Yes - Indoor Transmission Characteristics (Connectivity) Mated Connection Table 1: Max. Min. Min. Min. Min. Frequency Max. Insertion Loss Insertion Loss NEXT NEXT FEXT FEXT (MHz) TIA* (dB) Belden** (dB) TIA* (dB) Belden** (dB) TIA* (dB) Belden** (dB) 1.000 0.100 0.100 65.000 77.000 65.000 67.000 4.000 0.100 0.100 65.000 72.300 63.100 65.000 8.000 0.100 0.100 64.900 66.200 57.000 58.900 10.000 0.100 0.100 63.000 64.300 55.100 57.000 16.000 0.100 0.100 58.900 60.200 51.000 52.900 20.000 0.100 0.100 57.000 58.300 49.100 51.000 25.000 0.100 0.100 55.000 56.300 47.100 49.000 31.250 0.110 0.100 53.100 54.400 45.200 47.100 62.500 0.160 0.120 47.100 48.400 39.200 41.100 100.000 0.200 0.160 43.000 44.300 35.100 37.000 160.000 0.210 40.200 Mated Connection Table - Footnote: 32.900 * TIA/EIA-568-B.2-2001 Category 5E Standard. ** Worst-case performance for a CAT5E mated connection using CAT5E modular plugs. Mated Connection Table 2: Min. Frequency Min. Return Loss Return Loss (MHz) TIA* (dB) Belden** (dB) 1.000 30.000 32.000 4.000 30.000 32.000 8.000 30.000 32.000 10.000 30.000 32.000 16.000 30.000 32.000 20.000 30.000 32.000 25.000 30.000 32.000 31.250 30.000 32.000 62.500 24.100 28.100 100.000 20.000 24.000 160.000 19.900 Dielectric Strength: 1,000 V RMS @ 60 Hz for 1 minute Current Rating: 1.500 A Insulation Resistance: 500 M-Ohm Minimum Max. Contact Resistance: 20 m-Ohm Termination Resistance: 2.5 m-Ohm Notes (Overall) Notes: Please See Installation Guide PX102753 Product Family Part Number List: Item Number Color AX100645 Gray AX100646 Almond AX100647 White AX100648 Black AX100649 Orange (TIA 606) AX100650 Red (TIA 606) AX100651 Yellow (TIA 606) AX100652 Green (TIA 606) AX100653 Blue (TIA 606) AX100654 Purple (TIA 606) AX100655 Brown (TIA 606) Put Ups and Colors: Item # Putup Ship Weight AX100648 1 EA 0.024 LB Color Notes Item Desc EZ-MDVO UTP MODULE, CAT5E, Page 2 of 3 02-27-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION AX100648 Modular Connectors - CAT5E EZ-MDVO Modular Jack - MDVO style Revision Number: 0 Revision Date: 04-26-2013 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 3 of 3 02-27-2017
AX100648 价格&库存
很抱歉,暂时无法提供与“AX100648”相匹配的价格&库存,您可以联系我们找货
