AX101951
AX101951
    BELDEN
    GIGABIX CAT6+ PATCHCORD
AX101951 数据手册
1 COPPERMedia DATASheet GigaBIX PS6+ Patch Cords AX101945 GigaBIX PS6+ Patch Cord, BIX-BIX, 4 ft AX101951 GigaBIX PS6+ Patch Cord, BIX-8MOD, 4 ft GigaBIX PS6+ Patch Cords increase the proven versatility of the expanded GigaBIX Multi family of connectivity products. GigaBIX PS6+ Patch Cords allow for high-density connections, coupled with flexibility for cost-effective installation and administration. Plug-and-go installation and rearrangement of patch cords do not require any special tools or training. > Robust and installer-friendly plug design with proven contact reliability to reduce network operating costs GigaBIX PS6+ Patch Cords are 4-pair 23 AWG UTP GigaBIX-compatible cords that are used in GigaBIX Cross-Connect System in Belden IBDN System 2400 and System 4800LX, providing channel bandwidths of 250 MHz and 300 MHz respectively. The GigaBIX PS6+ Patch Cord and GigaBIX Connector provide a mated performance that exceeds Category 6 requirements. Applications GigaBIX PS6+ Patch Cords are available in two different configurations and in various lengths. BIX-BIX patch cord configurations are terminated with GigaBIX-compatible plugs at each end for easy cross-connection between equipment and distribution fields. BIX-8MOD patch cord configurations are terminated with a GigaBIX-compatible plug at one end and an 8-position modular plug on the other. They are available in T568A-ISDN or T568B-ALT wiring schemes. These cords are used to easily interconnect equipment directly into the distribution field. Technical specifications > Marked with pair identification (1 to 4) for easy orientation > Available in various sizes and lengths for greater installation flexibility > Horizontal distribution or equipment terminations in telecommunications rooms and equipment rooms > Interconnection terminations in consolidation points > See specifications for each component Qualifications > UL Listed as a Communications Circuit Accessory Configurations > BIX-BIX termination with straight-through wiring > BIX-8MOD termination with BIX to 8-pin T568A-ISDN or T568B-ALT > Available in 1.2, 1.8, 2.4, 3.0, 4.6, and 7.6 m (4, 6, 8, 10, 15 and 25 ft) lengths Cable Features & Benefits > GigaFlex PS6+ Patch Cable > Beyond Category 6 performance providing additional margin to support gigabit applications > UL Listed CMR > GigaBIX-compatible plug for high density installation and to reduce installation space requirements > Minimum bend radius: 6 mm (0.236 in.) > Nominal diameter: 5.6 mm (0.220 in.) > Black jacket > New and improved compact design to improve connector and plug accessibility 1-800-BELDEN-1 • www.belden.com 2 COPPERMedia DATASheet GigaBIX PS6+ Patch Cords Mechanical Characteristics GigaBIX Plug Electrical Characteristics Transmission Characteristics > Exceeds Category 6 standard requirements, extended to 650 MHz GigaBIX Plug > Dimensions (H x W x D): 11.4 x 25.1 x 38.5 mm (0.450 in. x 0.990 in x 1.515in) > Dielectric strength: 1,000 V RMS at 60 Hz for 1 minute > Housing: fire-retardant thermoplastic rated UL94V-0, clear > Voltage rating: 150 VAC maximum > Overmold: fire-retardant thermoplastic rated UL94V-0, black > Blade: copper alloy with tin plating over nickel > Gas-tight connection with BIX clips > Durability: 500 insertions Modular Plug > 8-position modular plug, FCC Part 68, Subpart F compliant > IEC 603-7 > UL Listed as a Recognized Component > Housing: fire retardant thermoplastic UL94V-0, clear > Performance of a worst-case 4-connector channel (100 m) using GigaBIX Patch Cords > Current rating: 1.5 A maximum > Insulation resistance: 100 MΩ minimum between clips > Contact resistance: 3 mΩ per contact Modular Plug > Multi Applications Multi Media Multi Configurations > Dielectric strength: 1,000 V RMS at 60 Hz for 1 minute > Voltage rating: 150 VAC maximum > Current rating: 1.5 A maximum > Insulation resistance: 100 MΩ minimum between clips > Contact resistance: 10 mΩ maximum > Durability: 1000 mating cycles > Contact material: phosphor bronze with 50 micro-inches gold over nickel 1-800-BELDEN-1 • www.belden.com 3 COPPERMedia DATASheet GigaBIX PS6+ Patch Cords Installation tips Packaging For More Information > Plan cross-connect or interconnect layout prior to ordering and installation > Individually packaged in clear plastic bags > Use BIX-BIX Patch Cords for cross-connect configurations, between equipment and distribution fields > Minimum ordering quantity: 10 For any other product information call: 1-800-BELDEN-1 or visit us at www.Belden.com > Ordering increments: 10 All information is subject to change without notice, since Belden reserves the right to change its products as progress in engineering and manufacturing methods or other circumstances may warrant. > Use BIX-8MOD Patch Cords for interconnect configurations, between the network equipment and the distribution field > Use appropriate patch cord management accessories Ordering Information *GigaBIX PS6+ Patch Cord, BIX-BIX LENGTH 1.2 1.8 2.4 3.0 4.6 7.6 m m m m m m UPC (4 ft) (6 ft) (8 ft) (10 ft) (15 ft) (25 ft) ORDERING NUMBER 628575117512 628575117529 628575117536 628575117543 628575117550 628575117567 NEW NEW NEW NEW NEW NEW AX101945 AX101946 AX101947 AX101948 AX101949 AX101950 *GigaBIX PS6+ Patch Cord, BIX-8MOD T568A-ISDN LENGTH 1.2 1.8 2.4 3.0 4.6 7.6 m m m m m m UPC (4 ft) (6 ft) (8 ft) (10 ft) (15 ft) (25 ft) ORDERING NUMBER 628575117574 628575117581 628575117598 628575117604 628575117611 628575117628 NEW NEW NEW NEW NEW NEW AX101951 AX101952 AX101953 AX101954 AX101955 AX101956 *GigaBIX PS6+ Patch Cord, BIX-8MOD T568B-ALT LENGTH 1.2 1.8 2.4 3.0 4.6 7.6 m m m m m m UPC (4 ft) (6 ft) (8 ft) (10 ft) (15 ft) (25 ft) ORDERING NUMBER 628575117635 628575117642 628575117659 628575117666 628575117673 628575117680 NEW NEW NEW NEW NEW NEW *Other colors may be ordered, contact Customer Service. 1-800-BELDEN-1 • www.belden.com AX101957 AX101958 AX101959 AX101960 AX101961 AX101962
AX101951 价格&库存
很抱歉,暂时无法提供与“AX101951”相匹配的价格&库存,您可以联系我们找货
AX101951
  • 1+302.800971+39.16559
