AX104183
AX104183
    BELDEN
    CAT5E JACK KCONN RED (DARK)
AX104183 数据手册
Part Number: CAT5E KEYCONNECT JACKS CAT5E Modular Jack, RJ45, KeyConnect Style Product Description CAT5E KeyConnect Jacks are available in several colors. Technical Specifications Product Overview Environmental Space: Indoor Suitable Applications: IBDN System 1200, TIA Category 5E, ISO Class D, 1000 BASE-T Physical Characteristics (Overall) Height: 0.88 in Width: 0.64 in Depth: 1.29 in Wiring Scheme: T568A/B Packaging: Individually packaged in a plastic bag. Standard pack of 50 units. Weight: 0.014 lbs Connectors Materials Description Material Type Front Connection Copper Alloy with 50 µ inch Gold over Nickel Lead Frame Rear Connection Copper Alloy with Nickel Plating Connector Body IDC Plastic - UL940V-0 Electrical Characteristics Dielectric Strength: 1,000V RMS @ 60 Hz for 1 minute Current Rating: 1.500 A Insulation Resistance: 500 M-Ohm Minimum Max Contact Resistance: 20 mOhm Termination Resistance: 2.5 mOhm Temperature Range Installation Temp Range: -10°C to +60°C Storage Temp Range: -40°C to +70°C Operating Temp Range: -10°C to +60°C Mechanical Characteristics Footprint/Type: KeyConnect Tool Compatibility: Belden 110 Connecting Tool, MediaFlex Termination Station Plug /Jack Compatibility: RJ45, RJ11 Termination Front Connection: Mated Connection Termination Front Connection Durability: 1,000 cycles Termination Rear Connection: Gas Tight IDC Connection Termination Rear Connection Durability: 20 terminations Connector/Hardware Retention: 20 lbs Plug/Connector Retention: 11.250 lbs Standards Data Category: Category 5e Telecommunications Standards: Category 5 - ISO/IEC 11801:2002 Ed.2 Other Standards: FCC Part 68, Subpart F, IEC 60603-7 Third Party Performance Verification: ETL - Verified Category 5e Applicable Environmental and Other Programs EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (yyyy-mm-dd): 2006-07-01 MII Order #39 (China RoHS): EUP 50 Flammability, LS0H, Toxicity Testing Safety Listing: ACA, c(UL)us Listed Part Number Related Parts: Compatible with KeyConnect Faceplates, Adapters, Boxes and Patch Panels Variants Item # Color Packaging Wiring Scheme AX101308-B24 Almond Bulk Pack (24) T568A/B AX101308 Single Pack Almond T568A/B AX101310-B24 Black Bulk Pack (24) T568A/B AX101310 Single Pack Black T568A/B AX104186-B24 Blue Bulk Pack (24) T568A/B AX104186 Single Pack Blue T568A/B AX104188-B24 Brown Bulk Pack (24) T568A/B AX104188 Single Pack Brown T568A/B AX101309-B24 Electric White Bulk Pack (24) T568A/B AX101309 Electric White Single Pack T568A/B AX101307-B24 Gray Bulk Pack (24) T568A/B AX101307 Single Pack Gray T568A/B AX104185-B24 Green Bulk Pack (24) T568A/B AX104185 Single Pack Green T568A/B AX103079-B24 Ivory Bulk Pack (24) T568A/B AX103079 Single Pack Ivory T568A/B AX104182-B24 Orange Bulk Pack (24) T568A/B AX104182 Single Pack Orange T568A/B AX104187-B24 Purple Bulk Pack (24) T568A/B AX104187 Single Pack Purple T568A/B AX104183-B24 Red Bulk Pack (24) T568A/B AX104183 Red Single Pack T568A/B AX101315 TIA Blue Single Pack T568A/B AX101317 TIA Brown Single Pack T568A/B AX101314 TIA Green Single Pack T568A/B AX101311 TIA Orange Single Pack T568A/B AX101316 TIA Purple Single Pack T568A/B AX101312 TIA Red Single Pack T568A/B AX101313 TIA Yellow Single Pack T568A/B AX104184-B24 Yellow Bulk Pack (24) T568A/B AX104184 Single Pack Yellow T568A/B Product Notes Included Parts: 1 T-Bar Notes: Please see Installation Guide PX103329 © 2019 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product.
AX104183 价格&库存
很抱歉,暂时无法提供与“AX104183”相匹配的价格&库存,您可以联系我们找货
