Part Number: CAT6+ UTP LSZH PATCH CORDS
CAT6+ Patch Cord, UTP, LSZH
Product Description
CAT6+ Copper Patch Cord, UTP, LSZH
Technical Specifications
Product Overview
Environmental Space:
Indoor Rated (Not Riser or Plenum)
Suitable Applications:
Horizontal and building cabling. Support current and future Category 6 and 5e applications, such as: 1000Base-T (Gigabit Ethernet), 100 Base-T, 10 Base-T, FDDI,
ATM
Physical Characteristics (Overall)
Conductor
AWG Stranding Material Nominal Diameter No. of Pairs
23
Solid
Copper
6.1 mm
4
Total Number of Pairs:
4
Conductor Size:
23 AWG
Insulation
Material
Polyethylene
Inner Jacket Material
Material
No inner Jacket
Outer Jacket Material
Material
Nominal Diameter
LSZH - Low Smoke Zero Halogen 6.1 mm
Wiring Scheme:
T568A/B-T568A/B
Packaging:
Individually packaged in a clear plastic bag.
Connectors
Materials
Description
Material
Type
Plug
Polycarbonate
RJ45
Boot
PVC
Snagless
Front Connection Phosphor Bronze with 50u inch Gold over Nickel Plating Blades
Construction and Dimensions
Cabling
Filler
Cross Web
Electrical Characteristics
Dielectric Strength:
2.5 kV DC
Current Rating:
1A
Insulation Resistance:
5000 MOhm*km
Max Contact Resistance:
20 mOhm
Voltage
Voltage Rating [V]
72 V DC
Performance Footnote1:
There is 1dB margin on NEXT and RL guaranteed compared to ISO/IEC 11801-1:2017
Performance Footnote2:
The performance data below 4Mhz or above 500Mhz are for information only.
Temperature Range
Installation Temp Range:
0°C To +50°C
Operating Temp Range:
-20°C to +60°C
Mechanical Characteristics
Min Bend Radius (Overall Cable):
25 mm
Plug /Jack Compatibility:
RJ45
Termination Interface
Termination
RJ45
Connection
Durabilities
Mated Connection 750 Cycles
Standards
ISO/IEC Compliance:
Data Category:
Category 6+
Telecommunications Standards:
ISO/IEC 11801-1:2017; EN 50173-1 Amd 1 Caregory 6; ANSI/TIA/EIA 568 C.2 Category 6
Applicable Environmental and Other Programs
EU RoHS Compliance Date
(yyyy-mm-dd):
2013-01-25
Suitability
Suitability - Indoor:
Yes
Part Number
Related Parts:
CAT6+ Modular Jacks, CAT6+ Patch Panels
Variants
Item #
Color
Length
C624100001M Black
1m
C624100002M Black
2m
C624100004M Black
4m
C624100005M Black
5m
C624100008M Black
8m
C624100010M Black
10 m
C6241000D5M Black
0.5 m
C6241001D5M Black
1.5 m
C624106001M Blue
1m
C624106002M Blue
2m
C624106003M Blue
3m
C624106004M Blue
4m
C624106005M Blue
5m
C624106008M Blue
8m
C624106010M Blue
10 m
C624106015M Blue
15 m
C624106016M Blue
16 m
C624106020M Blue
20 m
C624106022M Blue
22 m
C624106024M Blue
24 m
C624106025M Blue
25 m
C624106026M Blue
26 m
C624106027M Blue
27 m
C624106029M Blue
29 m
C624106030M Blue
30 m
C624106032M Blue
32 m
C624106050M Blue
50 m
C624106060M Blue
60 m
C624106062M Blue
62 m
C6241060D5M Blue
0.5 m
C6241061D5M Blue
1.5 m
C604106010
Blue
C604106010
Blue
C604106005
Blue
C604106004
Blue
C604106004
Blue
C604106003
Blue
C604106003
10 ft
4 ft
Blue
3 ft
C624108002M Gray
2m
C624108001M Gray
1m
C624108002M Gray
2m
C624108003M Gray
3m
C624108004M Gray
4m
C624108005M Gray
5m
C624108008M Gray
8m
C624108010M Gray
10 m
C624108012M Gray
12 m
C624108015M Gray
15 m
C624108020M Gray
20 m
C624108025M Gray
25 m
C624108030M Gray
30 m
C624108040M Gray
40 m
C624108050M Gray
50 m
C624108060M Gray
60 m
C6241080D5M Gray
0.5 m
C6241081D5M Gray
1.5 m
C6241082D5M Gray
2.5 m
C6241087D5M Gray
7.5 m
C604108005
Gray
C604108005
Gray
5 ft
C624108002M Gray
C604108010
Gray
C604108010
Gray
C604108015
Gray
C604108015
Gray
10 ft
15 ft
C624105001M Green
1m
C624105002M Green
2m
C624105003M Green
3m
C624105004M Green
4m
C624105005M Green
5m
C624105010M Green
10 m
C624105015M Green
15 m
C6241050D5M Green
0.5 m
C6241051D5M Green
1.5 m
C604105005
Green
C604105005
Green
C604105004
Green
C604105004
Green
C604105003
Green
C604105003
Green
5 ft
4 ft
3 ft
C624103001M Orange 1 m
C624103002M Orange 2 m
C624103003M Orange 3 m
C624103005M Orange 5 m
C624103010M Orange 10 m
C624102001M Red
1m
C624102002M Red
2m
C624102003M Red
3m
C624102004M Red
4m
C624102005M Red
5m
C624102010M Red
10 m
C6241020D5M Red
0.5 m
C6241021D5M Red
1.5 m
C624107001M Violet
1m
C624107002M Violet
2m
C624107003M Violet
3m
C624107005M Violet
5m
C624107010M Violet
10 m
C624107020M Violet
20 m
C624109001M White
1m
C624109002M White
2m
C624109003M White
3m
C624109005M White
5m
C624109010M White
10 m
C624109015M White
15 m
C624109020M White
20 m
C624109025M White
25 m
C624109030M White
30 m
C6241090D5M White
0.5 m
C6241091D5M White
1.5 m
C6241092D5M White
2.5 m
C624104001M Yellow
1m
C624104002M Yellow
2m
C624104003M Yellow
3m
C624104004M Yellow
4m
C624104005M Yellow
5m
C624104006M Yellow
6m
C624104010M Yellow
10 m
C624104015M Yellow
15 m
C624104025M Yellow
25 m
C624104050M Yellow
50 m
C6241040D5M Yellow
0.5 m
C6241041D5M Yellow
1.5 m
© 2019 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without
notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages
(including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract,
negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief
at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product
Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and
regulations based on their individual usage of the product.
很抱歉,暂时无法提供与“C624106003M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+90.95446
- 25+87.30961
- 100+83.67518
