MachFlex 375 SY Cables
Armored (SY) PVC Control Cables
Galvanized Steel Wire Braid (GSWB) Excellent Mechanical Protection
Applications
Designed for applications which are installed in occasional flexing and fixed locations. Cable
applications include precision control sensors, multi axis control machines, temperature
controllers, control panels, machine cutting tools, auxiliary equipment, motor speed control,
production machinery and many more.
General Reference Standards
DIN VDE 0295, IEC 60228, BS6360
DIN EN 50290-2-22, DIN VDE 0207-363-4-1
IEC 60227-5, VDE 0281
DIN VDE 0482-332-1-2, DIN EN 60332-1-2, IEC 60332-1-2
RoHS & REACH Directives
Construction and Performance
1.
Conductor Material
Stranded bare copper (DIN VDE 0295 Class 5)
2.
Insulation Material & Color
PVC (polyvinyl chloride). A) Up to 5 cores: color-coded. From 6 cores: Belden
MachFlex Color code. B) G = with GN-YE protective conductor; X = without
protective conductor.
3.
Braid Shield Material
GSWB (Galvanized Steel Wire Braid)
4.
Jacket / Sheath Material
5.
Flame Retardancy
6.
Voltage Rating (Uo/U)
Up to 1.5 mm2: 300 / 500 V
From 2.5 mm2: 450 / 750 V
7.
Oil Resistant
DIN EN 50290-2-22 (TM54)
8.
Temperature Range
-5 °C TO +70 °C (Occasional movement)
-40 °C TO +80 °C (Fixed installation)
9.
Bending Radius
20 x OD (Occasional movement)
6 x OD (Fixed installation)
10.
Other Properties
Good UV resistance, chemical resistance & flexibility
MachFlex 375 SY Armored (SY) PVC Control Cables
GALVANLIZED STEEL WIRE BRAID SHIELD (GSWB) CABLE WITH (G) PROTECTIVE GROUND
5
4
3
2
1
Conductor 0.50 mm2
No. of
Cores
3
4
5
7
12
Nom. Overall
Diameter (mm)
7.7
8.3
8.8
9.5
11.9
14.5
1 = Conductor
2 = Insulation
3 = Inner Sheath
4 = Galvanized Steel Wire Braid Shield
5 = Outer Sheath
Conductor 0.75 mm2
Copper Weight
(kg/km)
14.40
19.20
24.00
33.60
58.00
96.70
EMEA
Part Code
C3GASY
C4GASY
C5GASY
C7GASY
C12GASY
C20GASY
APAC
Part Code
C3G0.5SY
C4G0.5SY
C5G0.5SY
C7G0.5SY
C12G0.5SY
C20G0.5SY
Conductor 1.00 mm2
No. of
Cores
3
4
5
7
12
Nom. Overall
Diameter (mm)
8.3
8.9
9.5
10.2
12.9
15.9
Copper Weight
(kg/km)
21.60
28.80
36.00
50.00
86.00
143.30
EMEA
APAC
Part Code
Part Code
C3GBSY C3G0.75SY
C4GBSY C4G0.75SY
C5GBSY
C5G0.75SY
C7GBSY
C7G0.75SY
C12GBSY C12G0.75SY
C20GBSY C20G0.75SY
Conductor 1.50 mm2
No. of Nom. Overall
Copper Weight
Cores Diameter (mm)
(kg/km)
3
8.7
28.80
4
9.4
38.40
5
10.1
48.00
7
10.8
67.00
12
14.0
115.00
192.00
Conductor 2.50 mm2
EMEA
Part Code
C3GCSY
C4GCSY
C5GCSY
C7GCSY
C12GCSY
C20GCSY
APAC
Part Code
C3G1.0SY
C4G1.0SY
C5G1.0SY
C7G1.0SY
C12G1.0SY
C20G1.0SY
No. of Nom. Overall
Copper Weight
Cores Diameter (mm)
(kg/km)
3
9.3
43.00
4
10.0
58.00
5
10.8
72.00
7
11.6
101.00
12
15.1
173.00
288.30
Conductor 4.00 mm2
EMEA
Part Code
C3GDSY
C4GDSY
C5GDSY
C7GDSY
C12GDSY
C20GDSY
APAC
Part Code
C3G1.5SY
C4G1.5SY
C5G1.5SY
C7G1.5SY
C12G1.5SY
C20G1.5SY
No. of Nom. Overall
Copper Weight
Cores Diameter (mm)
(kg/km)
3
12.6
72.00
4
13.9
96.00
5
15.1
120.00
7
16.4
168.00
9
19.9
216.00
12
21.4
288.00
Conductor 6.00 mm2
EMEA
Part Code
C3GESY
C4GESY
C5GESY
C7GESY
C9GESY
C12GESY
APAC
Part Code
C3G2.5SY
C4G2.5SY
C5G2.5SY
C7G2.5SY
C9G2.5SY
C12G2.5SY
No. of Nom. Overall
Copper Weight
Cores Diameter (mm)
(kg/km)
3
14.4
115.00
4
15.7
154.00
5
17.1
192.00
7
18.6
269.00
9
22.7
345.90
12
24.5
461.00
Conductor 10.00 mm2
EMEA
Part Code
C3GFSY
APAC
Part Code
C3G4SY
C4GFSY
C5GFSY
C7GFSY
C9GFSY
C12GFSY
C4G4SY
C5G4SY
C7G4SY
C9G4SY
C12G4SY
No. of
Cores
3
4
5
7
9
EMEA
Part Code
C3GGSY
C4GGSY
C5GGSY
C7GGSY
C9GGSY
APAC
Part Code
C3G6SY
C4G6SY
C5G6SY
C7G6SY
C9G6SY
No. of
Cores
3
4
5
7
9
EMEA
Part Code
C3GHSY
C4GHSY
C5GHSY
C7GHSY
C9GHSY
APAC
Part Code
C3G10SY
C4G10SY
C5G10SY
C7G10SY
C9G10SY
EMEA
Part Code
C3GJSY
C4GJSY
C5GJSY
APAC
Part Code
C3G25SY
C4G25SY
C5G25SY
Nom. Overall
Diameter (mm)
15.9
17.4
19.0
20.7
25.4
Copper Weight
(kg/km)
172.80
230.00
288.00
403.00
518.10
Conductor 16.00 mm2
No. of
Cores
3
4
5
Nom. Overall
Diameter (mm)
23.0
25.3
27.9
Copper Weight
(kg/km)
460.50
614.00
768.00
Nom. Overall
Diameter (mm)
18.6
20.4
22.3
24.4
30.0
Copper Weight
(kg/km)
288.00
384.00
480.00
672.00
864.00
Conductor 25.00 mm2
EMEA
Part Code
C3GISY
C4GISY
C5GISY
APAC
Part Code
C3G16SY
C4G16SY
C5G16SY
No. of
Cores
3
4
5
Nom. Overall
Diameter (mm)
25.9
28.6
31.2
• Putup length & tolerance of the cables will vary depending on the construction of the cable
• MOQ will vary depending on the construction of the cable & provided at the time of quotation
• Cable requested outside the above design criteria can be reviewed and quoted
Copper Weight
(kg/km)
720.00
960.00
1,200.00
GALVANLIZED STEEL WIRE BRAID SHIELD (GSWB) CABLE WITHOUT(G) PROTECTIVE GROUND
5
4
3
2
1
Conductor 0.50 mm2
No. of
Cores
3
4
5
7
12
Nom. Overall
Diameter (mm)
7.7
8.3
8.8
9.5
11.9
14.5
1 = Conductor
2 = Insulation
3 = Inner Sheath
5 = Outer Sheath
Conductor 0.75 mm2
Copper Weight
(kg/km)
14.40
19.20
24.00
33.60
58.00
96.70
EMEA
Part Code
C3XASY
C4XASY
C5XASY
C7XASY
C12XASY
C20XASY
APAC
Part Code
C3X0.5SY
C4X0.5SY
C5X0.5SY
C7X0.5SY
C12X0.5SY
C20X0.5SY
Conductor 1.00 mm2
No. of
Cores
3
4
5
7
12
Nom. Overall
Diameter (mm)
8.3
8.9
9.5
10.2
12.9
15.9
Copper Weight
(kg/km)
21.60
28.80
36.00
50.00
86.00
143.30
EMEA
Part Code
C3XBSY
C4XBSY
C5XBSY
C7XBSY
C12XBSY
C20XBSY
APAC
Part Code
C3X0.75SY
C4X0.75SY
C5X0.75SY
C7X0.75SY
C12X0.75SY
C20X0.75SY
Conductor 1.50 mm2
No. of Nom. Overall
Copper Weight
Cores Diameter (mm)
(kg/km)
3
8.7
28.80
4
9.4
38.40
5
10.1
48.00
7
10.8
67.00
12
14.0
115.00
192.00
Conductor 2.50 mm2
EMEA
Part Code
C3XCSY
C4XCSY
C5XCSY
C7XCSY
C12XCSY
C20XCSY
APAC
Part Code
C3X1.0SY
C4X1.0SY
C5X1.0SY
C7X1.0SY
C12X1.0SY
C20X1.0SY
No. of Nom. Overall
Copper Weight
Cores Diameter (mm)
(kg/km)
3
9.3
43.00
4
10.0
58.00
5
10.8
72.00
7
11.6
101.00
12
15.1
173.00
288.30
Conductor 4.00 mm2
EMEA
Part Code
C3XDSY
C4XDSY
C5XDSY
C7XDSY
C12XDSY
C20XDSY
APAC
Part Code
C3X1.5SY
C4X1.5SY
C5X1.5SY
C7X1.5SY
C12X1.5SY
C20X1.5SY
No. of Nom. Overall
Copper Weight
Cores Diameter (mm)
(kg/km)
3
12.6
72.00
4
13.9
96.00
5
15.1
120.00
7
16.4
168.00
9
19.9
216.00
12
21.4
288.00
Conductor 6.00 mm2
EMEA
Part Code
C3XESY
C4XESY
C5XESY
C7XESY
C9XESY
C12XESY
APAC
Part Code
C3X2.5SY
C4X2.5SY
C5X2.5SY
C7X2.5SY
C9X2.5SY
C12X2.5SY
No. of Nom. Overall
Copper Weight
Cores Diameter (mm)
(kg/km)
3
14.4
115.00
4
15.7
154.00
5
17.1
192.00
7
18.6
269.00
9
22.7
345.90
12
24.5
461.00
Conductor 10.00 mm2
EMEA
Part Code
C3XFSY
C4XFSY
C5XFSY
C7XFSY
C9XFSY
C12XFSY
APAC
Part Code
C3X4SY
C4X4SY
C5X4SY
C7X4SY
C9X4SY
C12X4SY
No. of
Cores
3
4
5
7
9
EMEA
Part Code
C3XGSY
C4XGSY
C5XGSY
C7XGSY
C9XGSY
APAC
Part Code
C3X6SY
C4X6SY
C5X6SY
C7X6SY
C9X6SY
No. of
Cores
3
4
5
7
9
EMEA
Part Code
C3XHSY
C4XHSY
C5XHSY
C7XHSY
C9XHSY
APAC
Part Code
C3X10SY
C4X10SY
C5X10SY
C7X10SY
C9X10SY
EMEA
Part Code
C3XJSY
C4XJSY
C5XJSY
APAC
Part Code
C3X25SY
C4X25SY
C5X25SY
Nom. Overall
Diameter (mm)
15.9
17.4
19.0
20.7
25.4
Copper Weight
(kg/km)
172.80
230.00
288.00
403.00
518.10
Conductor 16.00 mm2
No. of
Cores
3
4
5
Nom. Overall
Diameter (mm)
23.0
25.3
27.9
Copper Weight
(kg/km)
460.50
614.00
768.00
Nom. Overall
Diameter (mm)
18.6
20.4
22.3
24.4
30.0
Copper Weight
(kg/km)
288.00
384.00
480.00
672.00
864.00
Conductor 25.00 mm2
EMEA
Part Code
C3XISY
C4XISY
C5XISY
APAC
Part Code
C3X16SY
C4X16SY
C5X16SY
No. of
Cores
3
4
5
Nom. Overall
Diameter (mm)
25.9
28.6
31.2
Copper Weight
(kg/km)
720.00
960.00
1,200.00
很抱歉,暂时无法提供与“C5GESY-K100”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+25.139821+3.24310
- 25+20.7600625+2.67810
- 50+18.5701850+2.39560
- 100+16.38030100+2.11310
