DB6U-25
DB6U-25
    BELDEN
    DB RG6 F UNIV. 25 PACK
DB6U-25 数据手册
Product: DB6U-25 Double Bubble RG-6 "F" Coax Compression Connector Product Description Double Bubble RG6 Universal "F" type connector, fits standard, tri-shield and quad-shield coax cable. Compression design that molds the metal completely around the cable. 25 per Pack Technical Specifications Product Overview Suitable Applications: CCTV, Security Cameras, Video Physical Characteristics (Overall) Packaging: 25 Pack Number of Pieces: 1 Connectors Materials Material Nickel plated Brass Electrical Characteristics Impedance Nominal Characteristic Impedance 75 Ohm Return Loss (RL) Frequency [MHz] DC-1 GHz 30 dB Return Loss 1.07 VSWR DC-2 GHz 25 dB Return Loss 1.10 VSWR DC-3 GHz 24 dB Return Loss 1.16 VSWR Mechanical Characteristics Footprint/Type: Coax Connector Interface Type: F Gender: Male - plug Connector Series Name: Double Bubble Locking: No Tool Compatibility: CPLCRBC-BR (compression), PS59/6/RGB (strip) Termination Type: Compression Cable Center Conductor Diameter Limits: .0399 - .0418 inch Cable Dielectric Diameter Limits: .180 - .193 inch Cable Outer Jacket Diameter Limits: .265 - .305 inch Standards RG Type: 6 Series Type: 6 Applicable Environmental and Other Programs EU CE Mark: Yes Suitability Suitability - Indoor: Yes Related Part Numbers Variants Item # Color UPC DB6U-25 No Color 845671004878 Patent: This product has one or more applicable patents. More information on patents can be found at https://www.belden.com/patents. History Update and Revision: Revision Number: 0.109 Revision Date: 11-09-2022 © 2022 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product.
DB6U-25 价格&库存
很抱歉,暂时无法提供与“DB6U-25”相匹配的价格&库存,您可以联系我们找货
