FP3LDST003M
FP3LDST003M
    BELDEN
    FXPC OM3 LC_DX ST 3M
FP3LDST003M 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION FP3LDST003M Cable Assemblies - FP - FX PATCH CORD For more Information please call 1-800-Belden1 General Description: FX PATCH CORD, OM3, LC DUPLEX - ST, 3 M, OFNR, DUPLEX ZIP 2.0 MM, A-TO-B, AQUA JACKET Usage (Overall) Suitable Applications: Data Centers, Main Equipment Rooms,Telecommunications Rooms and Work Area Related Parts: FiberExpress Adapter Strips, FiberExpress Manager Modules and FiberExpress Ultra Frames and Cassettes. Workstation Oultlets Multi Conductor Physical Characteristics Overall Cabling Overall Cabling Fillers: Refer to cable Technical Specifications Overall Diameter Overall Nominal Diameter: 0.078 x 0.156 in. Physical Characteristics (Connectivity) Fiber Type Fiber Type: 50 Micron (OM3) Materials Materials: Description Type Material Connector at end 1 LC-Duplex Plastic Ferrules at end 1 1.25mm Metal Ferrules at end 2 Zirconia-Ceramic Boots at both ends Aqua Zirconia-Ceramic Connector at end 2 ST 2.5mm Color Rubber Aqua Wiring Scheme Wiring Scheme: TIA/EIA 568-C.3 Weight Weight: 0.128 lbs. Packaging Packaging: Individually packaged. Mechanical Characteristics (Connectivity) Storage Temperature Range: -40°C To +75°C Operating Temperature Range: -40°C To +75°C Environmental/Mechanical Characteristics: Test (Method) TIA 568-D.3 Belden Thermal Cycling (FOTP-3) n/a -40 to 75°C cycling for 7 days Temperature Life (FOTP-4) 60°C for 4 days 85°C for 7 days Humidity (FOTP-5) 90-95% at 40°C for 4 days 95% @ 75°C for 7 days Durability (FOTP-21) 500 cycles 6 x 200 cycles (3 Elevations) Cable Retention (FOTP-6) 5.0 kg @ 0 deg. 1.94 kg @90 deg. Flex (FOTP-1) 0.5 kg @ 90° to -90° for 100 cycles 0.9 kg @ 90° to -90° for 100 cycles Twist (FOTP-36) 1.5 kg for 10 cycles 1.5 kg for 10 cycles Overall Length Tolerances: Range Tolerance Range Sx & Dx Patchcord Sx & Dx Patchcord MPO Trunk Tolerance Range MPO Trunk Multi-Fiber Cable Assembly Multi-Fiber Cable Assembly Tolerance 0 to 2 meters +0.2 / -0 meter 0 to 2 meters +0.2 / -0 meter 0 to 2 meters 2.1 to 5.0 meters +0.3 / -0 meter 2.1 to 5.0 meters +0.3 / -0 meter 2.1 to 5.0 meters +0.3 / -0 meter 5.1 to 40 meters +0.4 / -0 meter 5.1 to 20 meters +0.4 / -0 meter +0.4 / -0 meter 5.1 to 20 meters Page 1 of 2 +0.2 / -0 meter 04-18-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION FP3LDST003M Cable Assemblies - FP - FX PATCH CORD Over 40.1 meters + 1.0% / -0% Over 20.1 meters + 1.0% / -0% Over 20.1 meters + 1.3 / -0 meter Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs UL Rating: Riser EU Directive 2011/65/EU (ROHS II): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2013 MII Order #39 (China RoHS): EUP 50 Safety Listing: ACA, Bi-national Standard Listed Suitability Suitability - Indoor: Yes Transmission Characteristics (Connectivity) Optical Connector Performance: Description OM1 (62.5 µm) OM2 (50 µm) OM3 (50 µm) OM4 (50 µm) OS2 (Singlemode) UPC OS2 (Singlemode) APC Maximum IL (dB) SingleFiber Connector LC - SC - ST 0.25 dB 0.25 dB 0.25 dB 0.15 dB 0.35 dB 0.35 dB Typical RL (dB) SingleFiber connector LC - SC - ST -30 dB -30 dB -30 dB -30 dB -55 dB -65 dB Maximum IL (dB) MultiFiber Connector MPO 0.5 dB 0.5 dB 0.35 dB 0.2 dB - 0.75 dB Typical RL (dB) MultiFiber Connector MPO -30 dB -30 dB -30 dB -30 dB - -60 dB Electrical Characteristics (Overall) Notes (Overall) Product Family Put Ups and Colors: Item # Putup Ship Weight FP3LDST003M 1 EA 0.065 KG Revision Number: 0 Color Notes Item Desc FXPC OM3 LC_DX ST 3M Revision Date: 07-23-2015 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Page 2 of 2 04-18-2017
FP3LDST003M 价格&库存
很抱歉,暂时无法提供与“FP3LDST003M”相匹配的价格&库存,您可以联系我们找货
FP3LDST003M
  • 1+364.115321+47.16567
