FS6US
FS6US
    BELDEN
    连接器
FS6US 数据手册
Product Bulletin PB 474 Belden SLM Universal Compression System One tool compresses a full line of F–Conn 360º compression connectors. Provides professional installers the ability to create field–customized cable installations from start to finish Cable Pro Linear Compliant Compression Tool • Made of solid steel is crafted to be both durable and lightweight • Self–adjusting plunger head provides a one–step, one–tool system • Utilizes True 360º compression technology • Includes four interchangeable tips to compress a variety of connectors • Works with Belden's full line of F–Conn (FS & RG Series) Compression Connectors F–Conn Universal Compression Connectors • F, RCA & BNC • Right angle, splice, and speaker • One–piece and multi–piece connectors • Available in nickle (FS) or gold (RG) F–Conn Plenum and Security CCTV Connectors • Available in F, RCA and BNC for a variety of plenum cable sizes • Custom engineered plenum connectors provide an easy to install, precise fit on the cable • Plenum and Security (CCTV) Connectors are available for SLM and DB Systems • Security Connectors are designed for CCTV coaxial cable with copper braiding and a solid copper center conductor • For ease of installation use the Cable Pro FIT–59 or FIT–6 Insertion/Removal Tool F–Conn RGB/Mini Coax Connectors • Available in two sizes: • RG15 (22–24 AWG), purple • RG1 (25–26 AWG), orange • F, RCA and BNC connector types • Multi–piece RGB connectors are for solid center wire or stranded cable • One–piece RGB connectors are for solid center conductor wire only • RGB F pin–type connector for RG15 (22–24AWG wire) • Stringent testing standards demonstrate superior return loss numbers on all our RGB/Mini Coax Connectors F–Conn Standalone Splice (Female) Compression Connectors • Can be used with our patented Wall Plate System • F, RCA and BNC for RG59, RG6 and RGB/mini coax cables • Splices are offered in nickel (FS) or gold (RG) • By utilizing a standalone female splice, installers are able to directly connect two wires, eliminating a coupler or splice barrel F–Conn Right Angle Connectors • Designed to allow for adequate cable bend radius when space is limited • Great solution for flush mounts, TV rack mounts, plasma/ LCD televisions and dome security camera installations • Features a positive stop design to help guide the cable into the connector and prevent it from being over– compressed • F, RCA and BNC are available for RG59, RG6 and RGB/ Mini Coax cables F–Conn Speaker Connectors • Fits 12, 14 and 16 AWG cable • Screw–on tips (spade, banana and pin type) enable quick connector format conversion • Speaker binding post is designed to work with the speaker connector line •  Works with Belden’s Wall Plate System and corresponding modular speaker installations SLM Starter Kit Includes • Cable Pro Linear Compliant Compression Tool (CPLCCT-SLM) and adapter tips • Cable Pro Cable Strip Tool (PS59/6/RGB) with extra blade cartridges • Variety of F, BNC, RCA, Right Angle and Splice connectors for RG59, RG6 and RGB/Mini Coax cables SLM Tech Express Tool Kit Includes • Cable Pro Linear Compliant Compression Tool (CPLCCT-SLM) and adapter tips • Cable Pro Cable Strip Tool (PSA59/6) for RG59 and RG6 with extra blade cartridge Part Number Description Linear Compliant Compression Tool Linear Compliant Compression Tool (SLM) CPLCCT-SLM Linear Compliant Compression Tool LMTIP-S Silver Adapter Tip For F-Conn’s Silver/Nickel Connectors LMTIP-G Gold Adapter Tip For F-Conn’s Gold Connectors LMTIP-WP Wall Plate Adapter Tip For F-Conn’s Splice Connectors LMTIP-RA Right Angle Adapter Tip For F-Conn’s Right Angle Connectors LMTIP-KIT Kit Includes Holder + 5 Tips — G, S, RA, WP, IEC Part Number Nickel Part Number Gold Connector Size Connector Type Color Band Required Adapter Tip F–Conn Universal Connectors F-Conn Universal Connectors FS59U RG59U RG59 Universal F Red LMTIP-S/G FS59RCAU RG59RCAU RG59 Universal RCA Red LMTIP-S/G FS59BNCU RG59BNCU RG59 Universal BNC Red - FS6U RG6U RG6 Universal F Green LMTIP-S/G FS6RCAU RG6RCAU RG6 Universal RCA Green LMTIP-S/G FS6BNCU RG6BNCU RG6 Universal BNC Green - Part Number Nickel Part Number Gold Connector Size Connector Type Color Band RGB 22-24 AWG F, 1-Piece Solid Center Conductor Purple LMTIP-S Required Adapter Tip F–Conn RGB/Mini Coaxial Connectors FS15 RGB/Mini Coaxial Connectors - FS15RCA RG15RCA RGB 22-24 AWG RCA, 1-Piece Solid Center Conductor Purple LMTIP-S FSRCA15RGB RGRCA15RGB RGB 22-24 AWG RCA, Multi-Piece Solid Center Conductor Purple LMTIP-S FS15BNC RG15BNC RGB 22-24 AWG BNC, 1-Piece Solid Center Conductor Purple - FSBNC15RGB RGBNC15RGB RGB 22-24 AWG BNC, Multi-Piece Solid Center Conductor Purple - FS1RCA RG1RCA RGB 24-26 AWG RCA, 1-Piece Solid Center Conductor Orange LMTIP-S FSRCA1RGB RGRCA1RGB RGB 24-26 AWG RCA, Multi-Piece Solid Center Conductor Orange LMTIP-S FS1BNC RG1BNC RGB 24-26 AWG BNC, 1-Piece Solid Center Conductor Orange - FSBNC1RGB RGBNC1RGB RGB 24-26 AWG BNC, Multi-Piece Solid Center Conductor Orange - Part Number Nickel Part Number Gold Connector Size Connector Type Color Tip Required F–Conn Standalone Splice (Female) Connectors Standalone Splice (Female) Connectors 2 FS15RCASST RG15RCASST RGB 22–24 AWG RCA, Female Splice Connector Purple LMTIP-WP FS15BNCSST RG15BNCSST RGB 22–24 AWG BNC, Female Splice Connector Purple NONE FS1RCASST RG1RCASST RGB 24–26 AWG RCA, Female Splice Connector Orange LMTIP-WP FS1BNCSST RG1BNCSST RGB 24–26 AWG BNC, Female Splice Connector Orange NONE FS59US RG59US RG59 F, Universal Female Splice Connector Red LMTIP-WP FS59RCAUS RG59RCAUS RG59 RCA, Universal Female Splice Connector Red LMTIP-WP FS59BNCUS RG59BNCUS RG59 BNC, Universal Female Splice Connector Red NONE FS6US RG6US RG6 F, Universal Female Splice Connector Green LMTIP-WP FS6RCAUS RG6RCAUS RG6 RCA, Universal Female Splice Connector Green LMTIP-WP FS6BNCUS RG6BNCUS RG6 BNC, Universal Female Splice Connector Green NONE Part Number Nickel Required Adapter Tip Description F–Conn Speaker Connectors F–Conn Speaker Connectors RGSPU 4 Speaker Connectors* LMTIP-G RGSPURA 4 Right Angle Speaker Connectors* LMTIP-RA RGSBPOST Female Speaker Binding Post 2 Pack** LMTIP-G * Each 4 pack includes 12, 14, and 16 AWG Sleeves – (4)Red / (6)Black Colored Rings **Each 2 pack includes 2 posts, (1) Red screw nut and (1) Black screw nut also (2) Red 12 AWG, (2) Green 14 AWG, and (2) Yellow 16 AWG Sleeves. (Requires module clip to fit Wall Plate System) Part Number Nickel Connector Size Connector Type Color Band Required Adapter Tip F–Conn Plenum and Security CCTV Connectors Plenum and Security CCTV Connectors FS59RCASL RG59 RCA, Security (CCTV) Red FS59BNCSL RG59 BNC, Security (CCTV) Red NONE FS59PL RG59 F, Plenum Size 1 Red LMTIP-S FS59PL2 RG59 F, Plenum Size 2 Red LMTIP-S FS59PL4 RG59 F, Plenum Size 4 Red LMTIP-S FS59RCAPL RG59 RCA, Plenum Size 1 Red LMTIP-S FS59RCAPL2 RG59 RCA, Plenum Size 2 Red LMTIP-S FS59RCAPL3 RG59 RCA, Plenum Size 3 Red LMTIP-S FS59BNCPL RG59 BNC, Plenum Size 1 Red NONE FS59BNCPL2 RG59 BNC, Plenum Size 2 Red NONE FS59BNCPL3 RG59 BNC, Plenum Size 3 Red NONE FS59BNCPL4 RG59 BNC, Plenum Size 4 Red NONE FS6PL RG6 F, Plenum Size 1 Green LMTIP-S FS6PL2 RG6 F, Plenum Size 2 Green LMTIP-S FS6RCAPL RG6 RCA, Plenum Size 1 Green LMTIP-S FS6RCAPL2 RG6 RCA, Plenum Size 2 Green LMTIP-S FS6BNCPL RG6 BNC, Plenum Size 1 Green NONE FS6BNCPL2 RG6 BNC, Plenum Size 2 Green NONE Part Number Nickel Connector Size Connector Type Color Band Required Adapter Tip Purple LMTIP-RA LMTIP-S F–Conn Right Angle Compression Connectors F-Conn Right Angle Compression Connectors FSRCA15RA RGB 22–24 AWG RCA, Multi-Piece Right Angle FSBNC15RA RGB 22–24 AWG BNC, Multi-Piece Right Angle Purple LMTIP-RA FSRCA1RA RGB 25–26 AWG RCA, Multi-Piece Right Angle Orange LMTIP-RA FSBNC1RA RGB 25–26 AWG BNC, Multi-Piece Right Angle Orange LMTIP-RA FS59URA RG59 F, Universal Right Angle Red LMTIP-RA FSRCA59URA RG59 RCA, Universal Right Angle Red LMTIP-RA FSBNC59URA RG59 BNC, Universal Right Angle Red LMTIP-RA FS6URA RG6 F, Universal Right Angle Green LMTIP-RA FSRCA6URA RG6 RCA, Universal Right Angle Green LMTIP-RA FSBNC6URA RG6 BNC, Universal Right Angle Green LMTIP-RA 3 Belden Cable to F–Conn Connector Cross Reference Chart F–Conn Universal Compression Connectors FS "Nickel" Belden Cable Series 25–26 AWG Connector 1277P, 1277R, FS1BNC 1278R, 1279P, FS1RCA 1279R, 1280P, FSBNC1RGB* 1280R, FSRCA1RGB* 1281R–S3–S5–S6, FS1BNCSST* 1282S3–S5–S6, FS1RCASST* 1283S3–S5, FSBNC1RA* HC2648R, HC2650R RG "Gold" Series Center Conductor RG1BNC RG1RCA RGBNC1RGB* RGRCA1RGB* RG1BNCSST* RG1RCASST* F–Conn Plenum Compression Connectors Dielectric Outer Jacket .015–.025 .065–.078 .095–.110 RG "Gold" Series Center Conductor RG15BNC RG15RCA RGBNC15RGB* RGRCA15RGB* RG15BNCSST* RG15RCASST* .015–.025 Dielectric .095–.105 Outer Jacket .145–.160 *Multi–Piece Connectors for Stranded or Solid Center Conductors FS "Nickel" Series FS "Nickel" Splices Belden Cable RG59 Connector 1505A–F–S3–S5– FS59U FS59US S6, 1186A, 8221, FS59BNCU FS59BNCUS 8263, 9100, 9104, FS59RCAU FS59RCAUS 9104P, 9110, 9167, FS59URA 9244, 9259, 9275, FSBNC59URA 82108, 543945 FSRCA59URA Belden Cable RG6 Connector 1152A, 1189A, 1189AP, 1190A, 1530A, 1532A 1613A, 1614A, 1694A, 1840A, 1843A, 1829A 3092A, 3093A, 3131A, 533945, 5339B5, 5339G5, 5339W5, 5399B5, 6339Q8, 7710A, 7711A, 7712A 7713A, 7915A, 7916A, 9058, 9062, 9066, 9077, 9116, 9116R, 9118, 9248, 9290, 82120 FS "Nickel" Series RG "Gold" Series FS6U FS6US FS6BNCU FS6BNCUS FS6RCAU FS6RCAUS FS6URA FSBNC6URA FSRCA6URA RG "Gold" Series Outer Jacket .147–.157 .190–.220 Center Conductor Dielectric RG59 Plenum 82259, 543945 649948, 6439C8 1506A RG59 Plenum 82241 88241 RG59 Plenum 1506A, 89108 643948, 649948 FS59PL2 FS59BNCPL2 .0317–.0339 .130–.137 FS59RCAPL2 .190–.220 Size 2 Connector Size 3 Connector FS59BNCPL3 .0210–.0240 .130–.137 FS59RCAPL3 .190–.220 Size 4 Connector FS59PL4 FS59BNCPL4 .0317–.0339 .134–.141 FS59RCAPL4 Center Belden Cable Description Conductor RG6 Plenum Size 2 Connector 1695A, 1189AP, 82120, 87120, 89120, 89248 1530AP, 1695A, FS6PL2 9116P, 543945, FS6BNCPL2 .0339–.0418 633938, 633948 FS6RCAPL2 639948, 82248, 86120/633 .190–.220 Dielectric Outer Jacket .165–.172 .220–.250 Outer Jacket Outer Jacket Security/CCTV Compression Connectors Center Belden Cable Description Conductor RG59 Security/CCTV Connector 1426A, 8212, 8221, 9240, FS59BNCSL .0317–.0339 9265, 9659, FS59RCASL 5439W5, 543945, 549945 Dielectric Outer Jacket .137–.148 .232–.248 RG6U RG6BNCU RG6RCAU RG6US RG6BNCUS RG6RCAUS Belden Customer Support 1.800.685.9452 © Copyright 2012, Belden Inc. Center Conductor Dielectric RG59U RG59BNCU RG59RCAU .0317–.0339 .144–.157 .232–.273 RG59US RG59BNCUS RG59RCAUS FS "Nickel" Splices Dielectric FS59RCAPL *Multi–Piece Connectors for Stranded or Solid Center Conductors FS "Nickel" Belden Cable Series 22–24 AWG Connector 1164B*, 1167B*, FS15 1406B*, 1407B*, FS15BNC 1417B*, 1418B*, FS15RCA 1855A–S3–S5 FSBNC15RGB* 7787A, 7788A, FSRCA15RGB* 7789A, 7790A, FS15BNCSST* 7791A, 7792A FS15RCASST* 7794A, 7796A, FSBNC15RA* 8218*, 573945, 673948 Center Belden Cable Description Conductor RG59 Plenum Size 1 Connector 8279 FS59PL FS59BNCPL .0317–.0339 .0339–.0418 .180–.193 .265–.305 www.belden.com PB474
FS6US 价格&库存
很抱歉,暂时无法提供与“FS6US”相匹配的价格&库存,您可以联系我们找货
FS6US
    • 1+26.552421+3.33268
    库存:23
