Product Datasheet
P/N 46477 Rev. 1A
Page 1 of 2
Date 22-03-2000
H125 CU PVC
Application
Drop coaxial cable used in HFC / CATV broadband communication networks or SATV
Key features
All copper conductor material
Coaxial cable fit for standard connector usage
Test methods in accordance with European standard EN 50117-1.
Designed according the European Standard EN 50117 operating at frequencies between
5 MHz and 2150 MHz and the International Standard IEC 1196.
Construction & Dimensions
1
1
2
3.1
3.2
4
2
3.1
3.2
Inner conductor
Dielectric
Foil
Braid
Sheath
4
Solid soft annealed copper
Gas injected PE
Copper
Annealed copper
PVC according the European Standard HD 624.
1. Inner conductor diameter:
2. Dielectric diameter:
3. Outer conductor diameter screen:
4. Sheath diameter:
1.0 mm ± 0.02 mm
4.8 mm ± 0.15 mm
5.24 mm ± 0.2 mm
6.8 mm ± 0.2 mm
Mechanical characteristics
Adhesion of dielectric:
Tensile strength of sheath:
Elongation of sheath at break:
Crush resistance of cable:
Storage temperature:
Operating temperature:
Minimum installation temperature:
Maximum tensile strength of cable:
Minimum static bend radius:
Total weight:
7.8 – 78 N at 25 mm
≥ 12.5 N/mm2
≥ 150 %
< 1% (load of 700N)
-40°C to +70°C
-40°C to +70°C
-5 °C
55 N
70 mm
46 g/m
Belden Wire & Cable B.V.
Product Datasheet
P/N 46477 Rev. 1A
Page 2 of 2
Date 22-03-2000
H125 CU PVC
Electrical characteristics
75 ± 3 Ω
> 40 dB
≤ 41 Ω/km
≤ 23 Ω/km
≤ 18 Ω/km
55 pF/m ± 2 pF/m
0.81 ± 0.02
> 104 MΩ.km
2 kVdc
≥ 85 dB
≥ 23 dB*
≥ 23 dB*
≥ 20 dB*
≥ 18 dB*
*Max. 3 peak values 4 dB lower than specified.
Mean characteristic impedance:
Regularity of impedance:
DC loop resistance:
DC resistance inner conductor:
DC resistance outer conductor:
Capacitance:
Velocity ratio:
Insulation resistance:
Voltage test of dielectric:
Screening efficiency 30-1000 MHz:
Return loss at
5-30 MHz:
30-470 MHz:
470-862 MHz:
862-2400 MHz:
Attenuation at
5 MHz:
50 MHz:
100 MHz:
200 MHz:
400 MHz:
600 MHz:
Nominal
1.3 dB/100m
4.2 dB/100m
6.0 dB/100m
8.6 dB/100m
12.4 dB/100m
15.4 dB/100m
Attenuation at
800 MHz:
1000 MHz:
1350 MHz:
1750 MHz:
2150 MHz:
2400 MHz:
Nominal
18.0 dB/100m
20.4 dB/100m
24.1 dB/100m
27.9 dB/100m
31.4 dB/100m
33.5 dB/100m
Maximum attenuation is 0.5 dB/100m higher.
Ordering information
MARKING
Standard text
Inkjet printing
BELDEN VENLO HOLLAND YYYY H125
Metermarking:
Yes
YYYY:
Year of production.
PACKAGING
Belden code
46477 xxxx 172
46477 xxxx 011
46477 xxxx 240
xxxx:
Delivery length
100 m ± 2%
250 m ± 2%
500 m ± 2%
Color code
Remark
Carton box
Non returnable reel
Non returnable reel
Other marking or color on request.
很抱歉,暂时无法提供与“H125A00.00100”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 100+17.58799100+2.28260
- 200+15.75954200+2.04530
