1030A.00305
1030A.00305
    BELDEN
    BELDEN - 1030A.00305 - Multipair Cable, 300V Power Limited Tray, Screened, 1 Pair, 16 AWG, 305 ft, 9...
1030A.00305 数据手册
Part Number: 1030A 300V, (1 pr) 16 AWG (7x24) BC, PVC/PVC, Foil Shld, PLTC-ER, CMG Product Description One 16 AWG pair stranded (7x24) bare copper conductors, PVC insulation, twisted pair, overall Beldfoil® shield (100% coverage), PVC jacket. Technical Specifications Physical Characteristics (Overall) Conductor AWG Stranding 16 7x24 Material No. of Pairs BC - Bare Copper 1 Conductor Count: 2 Total Number of Pairs: 1 Total Number of Triads: N/A Conductor Size: 16 AWG Insulation Material Nominal Wall Thickness PVC - Polyvinyl Chloride 0.017 in Color Chart Number 1 Color Black & White Outer Shield Material Type Material Material Trade Name Coverage [%] Drainwire Material Tape Aluminum/Polyester Beldfoil® 100 % Drainwire AWG Drainwire Construction n x D TC - Tinned Copper 18 7x26 mm Outer Jacket Material Material Nominal Diameter Nominal Wall Thickness Ripcord PVC - Polyvinyl Chloride 0.259 in 0.037 in Yes 0.259 in Construction and Dimensions Stranding Twists 4 twist/ft LEGEND: BELDEN 1030A E34972 1PR16 SHIELDED (UL) CMG 105C OR PLTC OR ITC SUN RES OR AWM 2464 80C 300V OR C(UL) CMG ----FT4 IEEE 1202 (2 FT, 7 DIGIT SEQUENTIAL NUMBER) FEET Print Legend: Electrical Characteristics Conductor DCR Nominal Conductor DCR Nominal Outer Shield DCR 3.7 Ohm/1000ft 5.1 Ohm/1000ft Capacitance Nom. Capacitance Conductor to Conductor Nom. Capacitance Conductor to Other Conductor to Shield 61 pF/ft 114 pF/ft Shielding: Foil(s) or Copper Tape(s) Inductance Nominal Inductance 0.19 µH/ft Current Max. Recommended Current [A] 11 Amps per conductor @ 25°C Voltage UL Voltage Rating 300 V RMS Temperature Range UL Temp Rating: 105°C Operating Temp Range: -30°C To +105°C Mechanical Characteristics Bulk Cable Weight: 42.3 lbs/1000ft Max Recommended Pulling Tension: 40 lbs Min Bend Radius/Minor Axis: 2.6 in Standards NEC/(UL) Specification: ITC, PLTC CEC/C(UL) Specification: CMG UL AWM Style: UL Style 2464 (300 V 80°C) Applicable Environmental and Other Programs EU Directive 2000/53/EC (ELV): Yes EU Directive 2003/96/EC (BFR): Yes EU Directive 2011/65/EU (ROHS II): Yes EU Directive 2012/19/EU (WEEE): Yes EU Directive Compliance: EU Directive 2003/11/EC (BFR) EU CE Mark: Yes EU RoHS Compliance Date (yyyy-mm-dd): 2005-04-01 CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Suitability Suitability - Sunlight Resistance: Yes Flammability, LS0H, Toxicity Testing UL Flammability: UL1685 FT4 Loading CSA Flammability: FT4 IEEE Flammability: 1202 UL voltage rating: 300 V RMS Plenum/Non-Plenum Plenum (Y/N): No Part Number Variants Item # Color 1030A.00305 Black 1030A 0101000 Black Footnote C 1030A 01010000 Black CZ 1030A 0105000 CZ Black 1030A 01020000 Black 1030A 0061000 Blue, Light C 1030A 00610000 Blue, Light C 1030A 0065000 Blue, Light Footnote: C - CRATE REEL PUT-UP. Footnote: Z - FINAL PUT-UP MAY VARY (= OR -) 10% FOR SPOOLS OR REELS AND (+ OR -) 5% FOR UNREEL CARTONS FROM LENGTH SHOWN. Patent: https://www.belden.com/resources/patents © 2018 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product.
1030A.00305 价格&库存
很抱歉,暂时无法提供与“1030A.00305”相匹配的价格&库存,您可以联系我们找货
