10GX62F 0041000
10GX62F 0041000
    BELDEN
    CAT6A 4PRB F/UTP CMR REEL
10GX62F 0041000 数据手册
Product: 10GX62F 10GX Category 6A Enhanced Cable, 4 Bonded-Pairs, F/UTP, CMR Product Description 10GX Category 6A Enhanced Premise Horizontal Cable (625MHz), 4 Bonded-Pairs, 23 AWG Solid Bare Copper Conductors, F/UTP - Foil Shielded, Riser-CMR, PVC Jacket Technical Specifications Product Overview Suitable Applications: Premise Horizontal Cable, Ethernet up to 10GBASE-T, Wi-Fi 6, Wi-Fi 5, Surveillance, HDBaseT, PoE++, PoE+, PoE, Noisy Environments Patent: This product has one or more applicable patents. More information on patents can be found at https://www.belden.com/resources/patents. Construction Details Conductor Size Stranding 23 AWG Solid Material Number of Pairs BC - Bare Copper 4 Insulation Material Color Code PO - Polyolefin White/Blue Stripe & Blue, White/Orange Stripe & Orange, White/Green Stripe & Green, White/Brown Stripe & Brown Bonded-Pair: Yes Inner Jacket Material Nom. Diameter Ripcord PVC - Polyvinyl Chloride 0.26 in (6.6 mm) Yes Outer Shield Shield Type Tape Material Coverage Bi-Laminate (Alum+Poly) 100% Drainwire Type 26 AWG (7x34) TC Outer Jacket Separator Material Nom. Diameter Ripcord Center Member (Patented X-Spline®) PVC - Polyvinyl Chloride 0.300 in (7.62 mm) Yes Overall Cable Diameter (Nominal): 0.300 in (7.62 mm) Electrical Characteristics Electricals Max. Conductor DCR Max. Capacitance Unbalance 82 Ohm/km 90 pF/100m Delay Frequency 100 MHz Max. Delay Max. Delay Skew Nom. Velocity of Prop. 537.6 ns/100m 45 ns/100m High Frequency 64% Max. Insertion Loss (Attenuation) Frequency [MHz] Min. PSNEXT [dB] Min. PSACR [dB] Min. ACRF (ELFEXT) [dB] Min. PSACRF (PSELFEXT) [dB] Min. RL (Return Loss) [dB] Max./Min. Input Impedance (unFitted) Max./Min. Fitted Impedance Min. PSANEXT [dB] Min. PSAACRF [dB] Min. TCL [dB] Min. ELTCTL [dB] 1 2.1 dB/100m 73.3 71.2 70.8 68.8 20.0 100 ± 15 Ohm 105 ± 10 Ohm 77.0 77.0 40.0 35.0 4 3.8 dB/100m 64.3 60.5 58.8 56.8 23.0 100 ± 15 Ohm 100 ± 15 Ohm 77.0 76.2 40.0 23.0 8 5.3 dB/100m 59.8 54.4 52.7 50.7 24.5 100 ± 15 Ohm 100 ± 15 Ohm 77.0 70.1 40.0 16.9 10 5.9 dB/100m 58.3 52.4 50.8 48.8 25.0 100 ± 15 Ohm 100 ± 15 Ohm 77.0 68.2 40.0 15.0 16 7.5 dB/100m 55.2 47.8 46.7 44.7 25.0 100 ± 15 Ohm 100 ± 15 Ohm 77.0 64.1 38.0 10.9 20 8.4 dB/100m 53.8 45.4 44.8 42.8 25.0 100 ± 15 Ohm 100 ± 15 Ohm 77.0 62.2 37.0 9.0 25 9.4 dB/100m 52.3 43.0 42.8 40.8 25.0 100 ± 15 Ohm 100 ± 15 Ohm 77.0 60.2 36.0 7.0 31.25 10.5 dB/100m 50.9 40.4 40.9 38.9 25.0 100 ± 15 Ohm 100 ± 10 Ohm 77.0 58.3 35.1 62.5 15.0 dB/100m 46.4 31.4 34.9 32.9 25.0 100 ± 15 Ohm 100 ± 10 Ohm 77.0 52.3 32.0 100 19.1 dB/100m 43.3 24.2 30.8 28.8 25.0 100 ± 15 Ohm 100 ± 10 Ohm 72.5 48.2 30.0 200 27.6 dB/100m 38.8 11.2 24.8 22.8 18.0 100 ± 22 Ohm 100 ± 10 Ohm 68.5 42.2 27.0 250 31.1 dB/100m 37.3 6.3 22.8 20.8 17.3 100 ± 32 Ohm 100 ± 10 Ohm 66.5 40.2 26.0 300 34.3 dB/100m 36.1 1.9 21.3 19.3 16.8 100 ± 32 Ohm 100 ± 10 Ohm 65.3 38.7 25.2 350 37.2 dB/100m 35.1 -2.1 19.9 17.9 16.3 100 ± 32 Ohm 100 ± 10 Ohm 64.3 37.3 24.6 400 40.1 dB/100m 34.3 18.8 16.8 15.9 100 ± 32 Ohm 100 ± 10 Ohm 63.5 36.2 24.0 450 42.7 dB/100m 33.5 17.7 15.7 15.5 100 ± 32 Ohm 100 ± 10 Ohm 62.7 35.1 23.5 500 45.3 dB/100m 32.8 16.8 14.8 15.2 100 ± 32 Ohm 100 ± 10 Ohm 62.0 34.2 23.0 550 47.7 dB/100m 32.2 14.9 14.0 14.9 100 ± 32 Ohm 100 ± 10 Ohm 62.4 34.4 600 50.1 dB/100m 31.6 13.2 14.7 100 ± 32 Ohm 100 ± 10 Ohm 61.8 33.6 625 51.2 dB/100m 31.4 12.9 14.5 100 ± 32 Ohm 100 ± 10 Ohm 61.6 33.3 750 56.7 dB/100m 30.2 11.3 14.0 100 ± 32 Ohm 100 ± 10 Ohm 60.4 31.7 860 61.2 dB/100m 29.3 10.1 13.6 100 ± 32 Ohm 100 ± 10 Ohm 59.5 30.5 Voltage UL Voltage Rating 300 V (CMR) Mechanical Characteristics Temperature UL Temperature Operating 75°C Installation Storage -20°C To +75°C 0°C To +50°C -20°C To +75°C Bend Radius Stationary Min. Installation Min. 1.2 in (30 mm) 3.0 in (76 mm) Max. Pull Tension: 40 lbs (18 kg) Bulk Cable Weight: 39 lbs/1000ft Standards and Compliance Environmental Suitability: Riser, Indoor Sustainability: Product Lens™, Environmental Product Declaration (EPD) Available Flammability / Reaction to UL 1666 Riser, FT4, FT4, IEC 60332-1-2 Fire: CPR Compliance: CPR Euroclass: Eca NEC / UL Compliance: Article 800, CMR CEC / C(UL) Compliance: CMR ICEA Compliance: S-116-732-2013 IEEE Compliance: IEEE 802.3bt Type 1, Type 2, Type 3, Type 4 NEMA Compliance: ANSI/NEMA WC-66 Data Category: Category 6A TIA/EIA Compliance: ANSI/TIA-568.2-D Category 6A ISO/IEC Compliance: ISO/IEC 11801-1, IEC 61156-5 European Directive Compliance: EU CE Mark, EU Directive 2015/863/EU (RoHS 2 amendment), REACH, EU Directive 2011/65/EU (RoHS 2), EU Directive 2012/19/EU (WEEE), REACH: 2020-01-16 APAC Compliance: China RoHS II (GB/T 26572-2011) Other Standard Compliance(s): Verified Channel/Category 6A Plenum Number: 10GX63F Product Notes Electrical values are expected performance based on cable testing and representative performance within a typical Belden system. Values above 625 MHz are for Engineering Information Only. Print Includes Descending Footage/Meter Markings from Max. Put-Up Length to 0. Notes: History Update and Revision: Revision Number: 0.444 Revision Date: 12-15-2021 Variants Item # Color Putup Type Length UPC 10GX62F 0101000 Black Reel 1,000 ft 612825102465 10GX62F 0061000 Blue Reel 1,000 ft 612825102434 10GX62F 0081000 Gray Reel 1,000 ft 612825102441 10GX62F 0021000 Red Reel 1,000 ft 612825102410 10GX62F 0091000 White Reel 1,000 ft 612825102458 10GX62F 0041000 Yellow Reel 1,000 ft 612825102427 © 2022 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product.
10GX62F 0041000 价格&库存
很抱歉,暂时无法提供与“10GX62F 0041000”相匹配的价格&库存,您可以联系我们找货
