10GXW13 0101000
10GXW13 0101000
    BELDEN
    BELDEN - 10GXW13 0101000 - UNSHLD NTWRK CABLE, 4PAIR, 23AWG, 1000FT
10GXW13 0101000 数据手册
Product: 10GXW13 10GXW (0.250”) Category 6A Cable, 4 Pair, U/UTP, CMP Product Description 10GXW (0.250" Diameter) Category 6A Premise Horizontal Cable (500MHz), 4 Pair, 23 AWG Solid Bare Copper Conductors, U/UTP, Plenum-CMP, Flamarrest® PVC-LS Jacket Technical Specifications Product Overview Suitable Applications: Premise Horizontal Cable, Ethernet 10GBASE-T, Wi-Fi 6, Wi-Fi 5, In-Building Wireless, In-Building Small Cells, Mobile RAN, PoE++, PoE+, PoE, HDBaseT Patent: This product has one or more applicable patents. More information on patents can be found at https://www.belden.com/resources/patents. Construction Details Conductor AWG Stranding 23 Solid Material Number of Pairs BC - Bare Copper 4 Insulation Material Color Code FEP - Fluorinated Ethylene Propylene White & Blue, White & Orange, White & Green, White & Brown Bonded-Pair: No Outer Jacket Material Separator Material Material Material Trade Name Nom. Diameter Ripcord Center Member (Patented X-Spline®), EquiBlock™ Barrier Technology PVC - Polyvinyl Chloride Flamarrest® 0.250 in Yes Electrical Characteristics Electricals Max. Conductor DCR Max. DCR Unbalance Max. DCR Unbalanced Between Pairs [%] Max. Capacitance Unbalance Nom. Mutual Capacitance 82 Ohm/km 3.0% 5.0% Delay Max. Delay Max. Delay Skew Nom. Velocity of Propagation (VP) [%] 537.6 ns/100m 45 ns/100m 69% Voltage UL Voltage Rating 300 V (CMP) Mechanical Characteristics Temperature UL Rating. 105°C Operating Installation Storage -20°C To +75°C 0°C To +50°C -20°C To +75°C Bend Radius Stationary Min. 45 pF/100m 17 pF/ft 1 in Max. Pull Tension: 25 lbs Bulk Cable Weight: 37 lbs/1000ft Standards and Compliance Environmental Suitability: Plenum, Indoor Flammability / Fire Resistance: NFPA 262, UL 910 (Plenum), FT6, FT6 NEC / UL Compliance: Article 800, CMP;CMP-LP (0.5A);CL3P-LP (0.5A) CEC / C(UL) Compliance: CMP ICEA Compliance: S-116-732-2013 IEEE Compliance: IEEE 802.3bt Type 1, Type 2, Type 3, Type 4 NEMA Compliance: ANSI/NEMA WC-66 Data Category: Category 6A TIA/EIA Compliance: ANSI/TIA-568.2-D Category 6A European Directive Compliance: EU CE Mark, EU Directive 2015/863/EU, EU Directive 2011/65/EU (ROHS II), EU Directive 2012/19/EU (WEEE), REACH: 2020-01-16 APAC Compliance: China RoHS II (GB/T 26572-2011) Other Standard Compliance(s): Verified Channel/Category 6A Product Notes Notes: Electrical values are expected performance based on cable testing and representative performance within a typical Belden system. Print Includes Descending Footage/Meter Markings from Max. Put-Up Length to 0. History Update and Revision: Revision Number: 0.46 Revision Date: 03-16-2021 © 2021 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product.
10GXW13 0101000 价格&库存
很抱歉,暂时无法提供与“10GXW13 0101000”相匹配的价格&库存,您可以联系我们找货
10GXW13 0101000
  • 1000+9.714321000+1.25393
  • 2000+9.655582000+1.24635
库存:1000
