11872A 0101000
11872A 0101000
    BELDEN
    CBL 4PR 23AWG BONDED-PAIR C6
11872A 0101000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 11872A Multi-Conductor - Category 6 DataTuff® Twisted Pair Cable For more Information please call 1-800-Belden1 General Description: 23 AWG Bonded-Pair solid bare copper conductors, polyolefin insulation, PVC inner jacket, rip cord, industrial grade PVC outer jacket. Sequential marking at two foot intervals. Usage (Overall) Suitable Applications: Industrial Ethernet Cable, Harsh Environments, 350 MHz Enhanced Category 6, Gigabit Ethernet, 100BaseTX, 100BaseVG ANYLAN, 155ATM, 622ATM, NTSC/PAL Component or Composite Video, AES/EBU Digital Audio, AES51, RS-422, RJ-45 Compatible Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material Dia. (in.) 4 23 Solid BC - Bare Copper .022 Total Number of Conductors: 8 Insulation Insulation Material: Insulation Material Wall Thickness (in.) Dia. (in.) PO - Polyolefin .009 .038 Inner Jacket Inner Jacket Material: Inner Jacket Material Nom. Dia. (in.) PVC - Polyvinyl Chloride .365 x .165 Inner Jacket Ripcord: Yes Outer Shield Outer Shield Material: Outer Shield Material Unshielded Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (in.) PVC - Polyvinyl Chloride .035 Outer Jacket Ripcord: Yes Overall Cable Overall Nominal Diameter: 0.475 x 0.265 in. Pair Pair Color Code Chart: Number Color 1 White/Blue Stripe & Blue 2 White/Orange Stripe & Orange 3 White/Green Stripe & Green 4 White/Brown Stripe & Brown Mechanical Characteristics (Overall) Installation Temperature Range: -10°C To +75°C Operating Temperature Range: -25°C To +75°C Bulk Cable Weight: 59 lbs/1000 ft. Max. Recommended Pulling Tension: 45 lbs. Min. Bend Radius/Minor Axis: 0.100 in. Page 1 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 11872A Multi-Conductor - Category 6 DataTuff® Twisted Pair Cable Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CM, UL444 CEC/C(UL) Specification: CM EU Directive 2011/65/EU (ROHS II): Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: UL1666 Riser CSA Flame Test: FT1 Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Mutual Capacitance: Capacitance (pF/ft) 15.0 Maximum Capacitance Unbalance (pF/100 m): 49.2 Nominal Velocity of Propagation: VP (%) 70 Maximum Delay: Delay (ns/100 m) 510 @ 100MHz Max. Delay Skew: Delay Skew (ns/100 m) 25 Maximum Conductor DC Resistance: DCR @ 20°C (Ohm/100 m) 9 Max. Operating Voltage - UL: Voltage 300 V RMS Maximum DCR Unbalanced: DCR Unbalance @ 20°C (%) 3 Electrical Characteristics-Premise (Overall) Premise Cable Electrical Table 1: Freq. (MHz) Max. Attenuation (dB/100 m) Min. NEXT (dB) Min. PSNEXT (dB) Min. ACR (dB) Min. PSACR (dB) Min RL (dB) 1 1.900 74.3 72.3 72.4 70.4 20.000 4 3.700 65.3 63.3 61.6 59.6 23.000 8 5.300 60.3 58.8 55.5 53.5 24.500 10 5.900 59.3 57.3 53.4 51.4 25.000 16 7.500 56.3 54.3 48.7 46.7 25.000 20 8.400 54.8 52.8 46.4 44.4 25.000 25 9.500 53.4 51.4 43.9 41.9 24.300 31.25 10.600 51.9 49.9 41.2 39.2 23.600 62.5 15.400 47.4 45.4 32.0 30 21.500 100 19.800 44.3 42.3 24.5 22.5 21.000 155 25.100 41.5 39.5 16.3 14.3 21.000 200 29.000 39.9 37.9 10.8 10.0 21.000 250 32.800 38.3 36.3 5.5 3.5 18.000 300 35.200 37.2 34.2 0.7 0 18.000 Page 2 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 11872A Multi-Conductor - Category 6 DataTuff® Twisted Pair Cable 310 37.100 36.9 34.9 350 39.800 36.2 34.2 0 18.000 17.000 400 43.000 35.3 33.3 14.000 500 49.000 33.8 31.8 14.000 Premise Cable Electrical Table 2: Freq. (MHz) Input (Unfitted) Imp. (Ohms) Fitted Impedance Min. ELFEXT (dB) Min. PSELFEXT (dB) 1 100 ± 12 100 ± 15 67.8 64.8 4 100 ± 12 100 ± 15 55.7 52.7 8 100 ± 12 100 ± 15 49.7 46.7 10 100 ± 12 100 ± 15 47.8 44.8 16 100 ± 12 100 ± 8 43.7 40.7 20 100 ± 12 100 ± 8 41.7 38.7 25 100 ± 15 100 ± 8 39.8 36.8 31.25 100 ± 15 100 ± 8 37.9 34.9 62.5 100 ± 15 100 ± 8 31.8 28.8 100 100 ± 15 100 ± 8 27.8 24.8 155 100 ± 15 100 ± 8 23.9 20.9 200 100 ± 15 100 ± 8 21.7 18.7 250 100 ± 20 100 ± 8 19.8 16.8 300 100 ± 20 100 ± 8 18.2 15.2 310 100 ± 20 100 ± 8 17.9 14.9 350 100 ± 22 100 ± 8 16.9 13.9 400 100 ± 32 100 ± 8 15.7 12.7 500 100 ± 32 100 ± 8 13.8 10.8 Notes (Overall) Notes: **Values above 350 MHz are information only Notes (Cont'd.): Operating temperatures are subject to length de-rating. Cable passes -25C Cold Bend per UL 1581. T568A Plug Compatible Part Number: R301603 T568B Plug Compatible Part Number: R301604 Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 11872A 0081000 1,000 FT 66.000 LB GRAY C 4 PR #23 PP PVC PVC 11872A 0101000 1,000 FT 66.000 LB BLACK C 4 PR #23 PP PVC PVC Notes: C = CRATE REEL PUT-UP. Revision Number: 8 Revision Date: 07-19-2016 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 3 of 3 08-26-2016
11872A 0101000 价格&库存
很抱歉,暂时无法提供与“11872A 0101000”相匹配的价格&库存,您可以联系我们找货
