1279P 0101000
1279P 0101000
    BELDEN
    5 #25 FFEP SH FLRST FLRST
1279P 0101000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1279P Coax - Mini Hi-Res Component Video Cable For more Information please call 1-800-Belden1 General Description: 25 AWG solid .018” tinned copper conductors, FFEP insulation, Duobond® foil plus a tinned copper interlocked serve shield (95% coverage), PVC inner jackets, PVC jacket. Usage (Overall) Suitable Applications: RGB Projectors, LCD Projectors, Video Distribution, Component Video, Graphic Displays, Special Effects Editing, Animation, Video Post Production, Home Theater, Offices, Boardrooms, Auditoriums, Teleconferencing, Theaters Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material Dia. (in.) 5 25 Solid TC - Tinned Copper .018 Total Number of Conductors: 5 Insulation Insulation Material: Insulation Material Dia. (in.) FFEP - Foam FEP 0.074 Inner Shield Inner Shield Material: Layer # Inner Shield Trade Name Type Inner Shield Material 1 Aluminum Foil-Poly Tape-AluminumLightly bonded to dielectric 100 Duobond® Tape 2 Coverage (%) Interlocked Serve TC - Tinned Copper 95 Inner Jacket Inner Jacket Material: Inner Jacket Material Nom. Dia. (in.) PVC - Polyvinyl Chloride 0.111 Inner Jacket Color Code Chart: Number Color 1 Red 2 Green 3 Blue 4 Yellow 5 Black Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Overall Cable Overall Nominal Diameter: 0.330 in. Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +75°C UL Temperature Rating: 60°C Non-UL Temperature Rating: 75°C Bulk Cable Weight: 60 lbs/1000 ft. Max. Recommended Pulling Tension: 83 lbs. Min. Bend Radius (Each Coax): 1.100 in. Min. Bend Radius (Overall): 3.250 in. Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1279P Coax - Mini Hi-Res Component Video Cable Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMP CEC/C(UL) Specification: CMP EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: No EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 04/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: NFPA 262 CSA Flame Test: FT6 Suitability Suitability - Indoor: Yes Plenum/Non-Plenum Plenum (Y/N): Yes Non-Plenum Number: 1279R Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 75 Nom. Inductance: Inductance (µH/ft) .087 Nom. Capacitance Conductor to Shield: Capacitance (pF/ft) 16.8 Nominal Velocity of Propagation: VP (%) 81 Nominal Delay: Delay (ns/ft) 1.26 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 34 Nom. Inner Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 5.4 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 1 0.50 5 1.2 50 3.8 100 5.2 200 7.1 400 10.0 750 14.3 1000 16.9 2250 25.5 3000 33.9 Max. Operating Voltage - UL: Page 2 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1279P Coax - Mini Hi-Res Component Video Cable Voltage 300 V RMS Max. Operating Voltage - Non-UL: Voltage 300 V RMS Minimum Return Loss: Description Freq. (MHz) Start Freq. (MHz) Stop Freq. (MHz) Min. RL (dB) 5 850 20 Sweep Test Sweep Testing: 5 - 850 MHz Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 1279P 0081000 1,000 FT 66.000 LB GRAY C 5 #25 FFEP SH FLRST FLRST 1279P 008250 250 FT 18.250 LB GRAY C 5 #25 FFEP SH FLRST FLRST 1279P 008500 500 FT 33.500 LB GRAY C 5 #25 FFEP SH FLRST FLRST 1279P 0101000 1,000 FT 66.000 LB BLACK C 5 #25 FFEP SH FLRST FLRST 1279P 010250 250 FT 18.250 LB BLACK C 5 #25 FFEP SH FLRST FLRST 1279P 010500 500 FT 33.500 LB BLACK C 5 #25 FFEP SH FLRST FLRST Notes: C = CRATE REEL PUT-UP. Revision Number: 5 Revision Date: 08-01-2013 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 3 of 3 01-05-2017
1279P 0101000 价格&库存
很抱歉,暂时无法提供与“1279P 0101000”相匹配的价格&库存,您可以联系我们找货
