1520A 0101000
1520A 0101000
    BELDEN
    3 #30 FHDPE BRD PVC FS PVC
1520A 0101000 数据手册
Part Number: 1520A RGB Video, Mini #30-3 Coax Stranded TC, CL2 Product Description RGB Video Coax, CL2-Rated, 3-30 AWG stranded tinned copper conductors, foam HDPE insulation, Duofoil® +90% tinned copper braid shield, overall Beldfoil® shield, inner PVC jackets, PVC jacket Technical Specifications Product Overview Environmental Space: Indoor (Not Riser or Plenum) Physical Characteristics (Overall) Conductor AWG Stranding 30 7x38 Material Nominal Diameter No. of Coax TC - Tinned Copper 0.013 in 3 Conductor Count: 3 AWG Size: 30 Insulation Material Nominal Diameter FHDPE - Foamed High Density Polyethylene 0.056 in Color Chart Number Color 1 Red 2 Green 3 Blue Inner Shield Material Type Layer Material Material Trade Name Coverage [%] Tape 1 Aluminum Foil-Polyester Tape-Aluminum Foil Duofoil® 100 % Braid 2 TC - Tinned Copper 90 % Inner Jacket Material Material Nominal Diameter PVC - Polyvinyl Chloride 0.102 in Outer Shield Material Type Material Material Trade Name Coverage [%] Tape Aluminum Foil-Polyester Tape Beldfoil® 100 % Outer Jacket Material Material Nominal Diameter PVC - Polyvinyl Chloride 0.283 in Electrical Characteristics Conductor DCR Nominal Conductor DCR 100 Ohm/1000ft Nominal Conductor DCR Conductor Resistance Nominal Inner Shield DCR Outer Conductor DCR 100 Ohm/1000ft 9.5 Ohm/1000ft 9.5 Ohm/1000ft Capacitance Nom. Capacitance Conductor to Other Conductor to Shield 17.3 pF/ft Impedance Nominal Characteristic Impedance 75 Ohm Return Loss (RL) Frequency [MHz] Minimum Return (RL) 10-40 MHz 25 dB High Frequency (Nominal/Typical) Frequency [MHz] Nom. Insertion Loss 1 MHz 0.8 dB/100ft 5 MHz 1.5 dB/100ft 10 MHz 2.2 dB/100ft 30 MHz 4 dB/100ft 50 MHz 5.4 dB/100ft 100 MHz 8.2 dB/100ft 200 MHz 12.5 dB/100ft 400 MHz 18.9 dB/100ft 700 MHz 26.5 dB/100ft 900 MHz 30.8 dB/100ft 1000 MHz 32.8 dB/100ft Delay Nominal Delay Nominal Velocity of Propagation (VP) [%] 1.3 ns/ft 78 % Voltage UL Voltage Rating Voltage Rating [V] 300 V RMS 30 V RMS 300 V RMS (CL2) Electrical Characteristics Notes: 30 V RMS (UL AWM Style 1354); 300 V RMS (CL2) Temperature Range UL Temp Rating: 60°C Operating Temp Range: -40°C To +60°C Mechanical Characteristics Bulk Cable Weight: 46 lbs/1000ft Max Recommended Pulling Tension: 42 lbs Min Bend Radius/Minor Axis: 3 in Standards NEC/(UL) Specification: CL2 UL AWM Style: UL Style 1354 (each coax); UL Style 2688 (overall) RG Type: Sub-miniature RG-59/U Type Series Type: Sub-miniature 59 Applicable Environmental and Other Programs EU Directive 2000/53/EC (ELV): Yes EU Directive 2003/11/EC (BFR): Yes EU Directive 2011/65/EU (ROHS II): Yes EU Directive 2012/19/EU (WEEE): Yes EU Directive 2015/863/EU: Yes EU Directive Compliance: EU Directive 2003/11/EC (BFR) EU CE Mark: No EU RoHS Compliance Date (yyyy-mm-dd): 2004-01-01 CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Suitability Suitability - Indoor: Yes Part Number Plenum (Y/N): No Suggested Connectors: Kings # 2065-5-9 individual coaxes Footnote: C - CRATE REEL PUT-UP. © 2018 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS(Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be instock at Belden facilities and in our Distributor's inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden's knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC.
1520A 0101000 价格&库存
很抱歉,暂时无法提供与“1520A 0101000”相匹配的价格&库存,您可以联系我们找货
