Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
1505S5 Coax - RG-59/U Type
For more Information
please call
1-800-Belden1
General Description:
20 AWG solid .032” bare copper conductors, gas-injected foam HDPE insulation, Duofoil® (100%
coverage) plus a tinned copper braid shield (95% coverage), individual PVC jackets.
Usage (Overall)
Suitable Applications:
RGB, VGA, SVGA, XGA, SXGA, UXGA, HDTV, LCD, Plasma, Digital Signage, Component Video, Video
Mult, Animation, Special Effects, Suitable for use in Risers
Physical Characteristics (Overall)
Conductor
AWG:
# Coax AWG Stranding Conductor Material Dia. (in.)
5
Solid
BC - Bare Copper
.032
Total Number of Conductors:
5
Insulation
Insulation Material:
Insulation Material
Dia. (in.)
Gas-injected FHDPE - Foam High Density Polyethylene .145
Inner Shield
Inner Shield Material:
Layer # Inner Shield Trade Name Type Inner Shield Material
1
Duofoil®
Coverage (%)
Tape Aluminum Foil-Polyester Tape-Aluminum Foil 100
2
Braid TC - Tinned Copper
95
Inner Jacket
Inner Jacket Material:
Nom. Dia. (in.)
PVC - Polyvinyl Chloride .235
Inner Jacket Color Code Chart:
Number Color
1
Red
2
Green
3
Blue
4
White
5
Yellow
Outer Jacket
Outer Jacket Material:
Unjacketed
Overall Cable
Overall Cabling Fillers:
Bonded Spline
Overall Nominal Diameter:
0.629 in.
Mechanical Characteristics (Overall)
Operating Temperature Range:
-35°C To +75°C
UL Temperature Rating:
60°C
Non-UL Temperature Rating:
75°C
Bulk Cable Weight:
170 lbs/1000 ft.
Max. Recommended Pulling Tension:
360 lbs.
Min. Bend Radius/Minor Axis:
8 in.
Page 1 of 3
01-05-2017
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
NEC/(UL) Specification:
CMR
CEC/C(UL) Specification:
CMG
EU Directive 2011/65/EU (ROHS II):
Yes
EU CE Mark:
Yes
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
01/01/2004
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
RG Type:
59/U
Applicable Patents:
Country
www.belden.com/p
Flame Test
UL Flame Test:
UL1666 Vertical Shaft
Suitability
Suitability - Indoor:
Yes
Plenum/Non-Plenum
Plenum (Y/N):
No
Electrical Characteristics (Overall)
Nom. Characteristic Impedance:
Impedance (Ohm)
75
Nom. Inductance:
Inductance (µH/ft)
0.107
Nom. Capacitance Conductor to Shield:
Capacitance (pF/ft)
16.2
Nominal Velocity of Propagation:
VP (%)
83
Nominal Delay:
Delay (ns/ft)
1.22
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/1000 ft)
10.0
Nom. Inner Shield DC Resistance:
3.8
Nom. Attenuation:
Freq. (MHz) Attenuation (dB/100 ft.)
1
0.3
3.6
0.6
10
0.9
71.5
2.1
135
2.7
270
3.8
360
4.4
540
5.5
720
6.4
750
6.5
Page 2 of 3
01-05-2017
1000
7.6
1500
9.4
2500
12.4
3000
13.8
Max. Operating Voltage - UL:
Voltage
300 V RMS
Other Electrical Characteristic 1:
Impedance tested in accordance with ASTM D-4566 paragraph 43.2, option 2 using a 75 Ohm fixed bridge
and termination.
Other Electrical Characteristic 2:
Return Loss Tested in Accordance With ASTM D-4566 Paragraph 45.3, Using a 75 Ohm Fixed Bridge and
Termination.
Minimum Return Loss:
Start Freq. (MHz) Stop Freq. (MHz) Min. RL (dB)
5
475
525
15
525
850
4500
15
Sweep Test
Sweep Testing:
Sweep tested 5 MHz to 4.5 GHz.
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
Notes
Item Desc
1505S5 0001000
1,000 FT
182.000 LB
NONE
C
BONDED FILLER COMPOSITE
1505S5 000500
500 FT
93.500 LB
NONE
C
Notes:
C = CRATE REEL PUT-UP.
Revision Number: 0
Revision Date: 02-28-2014
© 2017 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU).
Page 3 of 3
01-05-2017
很抱歉,暂时无法提供与“1505S5 000500”相匹配的价格&库存,您可以联系我们找货
