1533P 004A1000
1533P 004A1000
    BELDEN
    CAT5E 4PR F/UTP CMP RIB
1533P 004A1000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1533P Multi-Conductor - Category 5e Nonbonded-Pair Cable For more Information please call 1-800-Belden1 General Description: CAT5e (100MHz), 4-Pair, F/UTP-Foil shielded, Plenum-CMP, Premise Horizontal Cable, 24 AWG solid bare copper conductors, FEP insulation, overall Beldfoil® shield, Flamarrest® jacket, RJ-45 compatible Usage (Overall) Suitable Applications: Premise Horizontal Cable, Gigabit Ethernet, 100BaseTX, 100BaseVG ANYLAN, 155ATM, 622ATM, NTSC/PAL Component or Composite Video, AES/EBU, Digital Video, RS-422, Noisy Environments, 100MHz Category 5e Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material 4 24 Solid BC - Bare Copper Total Number of Conductors: 8 Insulation Insulation Material: Insulation Material FEP - Fluorinated Ethylene Propylene Outer Shield Outer Shield Material: Outer Shield Trade Name Type Outer Shield Material Beldfoil® Coverage (%) Tape Aluminum Foil-Polyester Tape 100 Outer Shield Drain Wire AWG: AWG Stranding Drain Wire Conductor Material 24 7x32 TC - Tinned Copper Outer Jacket Outer Jacket Material: Outer Jacket Trade Name Outer Jacket Material Flamarrest® LS PVC - Low Smoke Polyvinyl Chloride Outer Jacket Diameter: Nom. Dia. (in.) 0.235 Pair Pair Color Code Chart: Number Color 1 White/Blue Stripe & Blue 2 White/Orange Stripe & Orange 3 White/Green Stripe & Green 4 White/Brown Stripe & Brown Mechanical Characteristics (Overall) Operating Temperature Range: 0°C To +75°C Bulk Cable Weight: 34 lbs/1000 ft. Max. Recommended Pulling Tension: 25 lbs. Min. Bend Radius/Minor Axis: 1 in. Min. Bend/Installation: 2.350 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMP, UL444 CEC/C(UL) Specification: CMP Page 1 of 3 02-01-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1533P Multi-Conductor - Category 5e Nonbonded-Pair Cable EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Telecommunications Standards: Category 5e - TIA 568.C.2 Other Specification: NEMA WC-63.1 Category 5e Flame Test UL Flame Test: NFPA 262 CSA Flame Test: FT6 Plenum/Non-Plenum Plenum (Y/N): Yes Non-Plenum Number: 1533R Electrical Characteristics (Overall) Nom. Mutual Capacitance: Capacitance (pF/ft) 15 Maximum Capacitance Unbalance (pF/100 m): 330 Nominal Velocity of Propagation: VP (%) 70 Maximum Delay: Delay (ns/100 m) 538 @ 100MHz Max. Delay Skew: Delay Skew (ns/100 m) 45 Maximum Conductor DC Resistance: DCR @ 20°C (Ohm/100 m) 9.38 Max. Operating Voltage - UL: Voltage 300 V RMS Maximum DCR Unbalanced: DCR Unbalance @ 20°C (%) 3 Electrical Characteristics-Premise (Overall) Premise Cable Electrical Table 1: Freq. (MHz) Max. Attenuation (dB/100 m) Min. NEXT (dB) Min. PSNEXT (dB) Min. ACR (dB) Min. PSACR (dB) Min RL (dB) Min. SRL (dB) 1 2.0 65.3 62.3 60.3 60.3 20.0 23.0 4 4.1 56.3 53.3 49.2 49.2 23.0 23.0 8 5.8 51.8 48.8 43.0 43.0 24.5 24.5 10 6.5 50.3 47.3 40.8 40.8 25.0 25.0 16 8.2 47.3 44.3 36.0 36.0 25.0 25.0 20 9.3 45.8 42.8 33.5 33.5 25.0 25.0 25 10.4 44.3 41.3 30.9 30.9 24.3 24.3 31.25 11.7 42.9 39.9 28.2 28.2 23.6 23.6 62.5 17.0 38.4 35.4 18.4 18.4 21.5 21.5 100 22.0 35.3 32.3 10.3 10.3 20.1 20.1 Premise Cable Electrical Table 2: Freq. (MHz) Input (Unfitted) Imp. (Ohms) Fitted Impedance Min. ELFEXT (dB) Min. PSELFEXT (dB) 1 100 ± 15 100 ± 15 63.8 60.8 Page 2 of 3 02-01-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1533P Multi-Conductor - Category 5e Nonbonded-Pair Cable 4 100 ± 15 100 ± 15 51.7 48.7 8 100 ± 15 100 ± 15 45.7 42.7 10 100 ± 15 100 ± 15 43.8 40.8 16 100 ± 15 100 ± 15 39.7 36.7 20 100 ± 15 100 ± 15 37.7 34.7 25 100 ± 15 100 ± 15 35.8 32.8 31.25 100 ± 15 100 ± 15 33.9 30.9 62.5 100 ± 15 100 ± 15 27.8 24.8 100 100 ± 15 100 ± 15 23.8 20.8 Notes (Overall) Notes: Shield is bonded to jacket inner wall for electrical stability. RJ-45 Compatible. Jacket sequentially marked at 2 ft. intervals. Third party verfied to TIA/EIA-568-C.2, Category 5e. Put Ups and Colors: Item # Putup Ship Weight Color 1533P D15A1000 1,000 FT 37.000 LB BLUE Notes 1533P D151000 1,000 FT 35.000 LB BLUE 1533P 002A1000 1,000 FT 37.000 LB RED 1533P 0021000 1,000 FT 35.000 LB RED 1533P 003A1000 1,000 FT 37.000 LB ORANGE 1533P 0031000 1,000 FT 35.000 LB ORANGE 1533P 004A1000 1,000 FT 37.000 LB YELLOW 1533P 0041000 1,000 FT 35.000 LB YELLOW 1533P 005A1000 1,000 FT 37.000 LB GREEN, DARK 1533P 0051000 1,000 FT 35.000 LB GREEN, DARK 1533P 008A1000 1,000 FT 37.000 LB GRAY 1533P 0081000 1,000 FT 35.000 LB GRAY 1533P 010A1000 1,000 FT 37.000 LB BLACK 1533P 0101000 1,000 FT 35.000 LB BLACK 1533P 877A1000 1,000 FT 37.000 LB NATURAL 1533P 8771000 1,000 FT 35.000 LB NATURAL Item Desc CAT5E 4PR F/UTP CMP RIB C CAT5E 4PR F/UTP CMP REEL CAT5E 4PR F/UTP CMP RIB C CAT5E 4PR F/UTP CMP REEL CAT5E 4PR F/UTP CMP RIB C CAT5E 4PR F/UTP CMP REEL CAT5E 4PR F/UTP CMP RIB C CAT5E 4PR F/UTP CMP REEL CAT5E 4PR F/UTP CMP RIB C CAT5E 4PR F/UTP CMP REEL CAT5E 4PR F/UTP CMP RIB C CAT5E 4PR F/UTP CMP REEL CAT5E 4PR F/UTP CMP RIB C CAT5E 4PR F/UTP CMP REEL CAT5E 4PR F/UTP CMP RIB C CAT5E 4PR F/UTP CMP REEL Notes: C = CRATE REEL PUT-UP. Revision Number: 3 Revision Date: 08-14-2013 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 02-01-2017
1533P 004A1000 价格&库存
很抱歉,暂时无法提供与“1533P 004A1000”相匹配的价格&库存,您可以联系我们找货
1533P 004A1000
  • 1+11734.549111+1516.81500
  • 2+10779.211692+1393.32750
