Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
1671J Coax - 50 Ohm Microwave Cable
For more Information
please call
1-800-Belden1
General Description:
RG-405/U type, 24 AWG solid .020" silver-plated copper-covered steel conductor, TFE Teflon® insulation,
copper-tin composite shield (100% coverage), PVC jacket.
Physical Characteristics (Overall)
Conductor
AWG:
# Coax AWG Stranding Conductor Material
1
24
Solid
Dia. (in.)
SPCCS - Silver Plated Copper Covered Steel .020
Total Number of Conductors:
1
Insulation
Insulation Material:
Insulation Trade Name Insulation Material
Teflon®
Dia. (in.)
TFE - Tetrafluoroethylene .062
Outer Shield
Outer Shield Material:
Layer # Type Outer Shield Material Coverage (%)
1
Tape Copper Foil
100
2
Braid Tin-Filled Composite
100
Outer Jacket
Outer Jacket Material:
PVC - Polyvinyl Chloride
Overall Cable
Overall Nominal Diameter:
0.127 in.
Mechanical Characteristics (Overall)
Operating Temperature Range:
-40°C To +105°C
UL Temperature Rating:
105°C (UL AWM Style 10245)
Non-UL Temperature Rating:
105°C
Bulk Cable Weight:
16 lbs/1000 ft.
Max. Recommended Pulling Tension:
26 lbs.
Min. Bend/Installation:
0.125 in.
Min. Flexing Radius:
0.375 in.
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
AWM Specification:
UL Style 10245 (30 V 105°C)
EU Directive 2011/65/EU (ROHS II):
Yes
EU CE Mark:
No
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
01/01/2005
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
RG Type:
405/U
Page 1 of 3
01-05-2017
Flame Test
Other Flame Test:
Horizontal Wire
Suitability
Suitability - Indoor:
Yes
Suitability - Outdoor:
Yes
Plenum/Non-Plenum
Plenum (Y/N):
No
Electrical Characteristics (Overall)
Nom. Characteristic Impedance:
Impedance (Ohm)
50
Nom. Inductance:
Inductance (µH/ft)
.07
Nom. Capacitance Conductor to Shield:
Capacitance (pF/ft)
29.5
Nominal Velocity of Propagation:
VP (%)
69.5
Nominal Delay:
Delay (ns/ft)
1.46
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/1000 ft)
64.2
Nominal Outer Shield DC Resistance:
10.2
Maximum VSWR:
Freq. (MHz) Max. VSWR
500
1.1:1
20000
1.3:1
Nom. Attenuation:
Freq. (MHz) Attenuation (dB/100 ft.)
500
15.0
1000
22.2
2000
32.8
3000
41.2
5000
54.9
7000
66.4
10000
81.2
15000
102
18000
113
20000
120
Max. Power Rating:
Freq. (MHz) Rating (W)
500
180
1000
119
2000
79
3000
62
5000
46
7000
37
10000
30
15000
24
18000
21
20000
Max. Operating Voltage - UL:
Voltage
30 V RMS (UL AWM Style 10245)
Max. Operating Voltage - Non-UL:
Page 2 of 3
01-05-2017
Voltage
1500 V RMS
Misc. Information (Overall)
Notes (Overall)
Notes: Teflon® is a registered trademark of E. I. duPont de Nemours and Co. used under license by Belden, Inc.
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
1671J 010100
100 FT
2.400 LB
BLACK
Notes
Item Desc
1671J 0101000
1,000 FT
17.000 LB
BLACK
V
#24 TFE BRD TINNED COAX PVC
1671J 010500
500 FT
9.500 LB
BLACK
V
Notes:
V = 250' PUT-UP EXACT LENGTH MAXIMUM OF 3 PIECESMINIMUM LENGTH 50'500' PUT-UP EXACT LENGTH MAXIMUM OF 5 PIECESMINIMUM LENGTH 50'
Revision Number: 5
Revision Date: 01-15-2014
© 2017 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Page 3 of 3
01-05-2017
很抱歉,暂时无法提供与“1671J 0101000”相匹配的价格&库存,您可以联系我们找货
