1807A B59500
1807A B59500
    BELDEN
    2 #30 FHDPE SRV PVC DUAL
1807A B59500 数据手册
Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 1807A Coax - High-Flex S-Video Cable For more Information please call 1-800-Belden1 General Description: 30 AWG stranded (7x38) .012" tinned copper conductors, foam HDPE insulation, tinned copper serve shield (90% coverage), PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material Dia. (mm) 2 30 7x38 TC - Tinned Copper 0.3302 Total Number of Conductors: 2 Insulation Insulation Material: Insulation Material FHDPE - Foam High Density Polyethylene Inner Shield Inner Shield Material: Type Inner Shield Material Coverage (%) Spiral Serve (each coax) TC - Tinned Copper 90 Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Overall Cable Overall Nominal Diameter: 2.794 x 5.842 mm Mechanical Characteristics (Overall) Operating Temperature Range: -40°C To +75°C Non-UL Temperature Rating: 75°C Bulk Cable Weight: 20.835 Kg/Km Max. Recommended Pulling Tension: 52.044 N Min. Bend Radius/Minor Axis: 25.400 mm Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: No EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes Page 1 of 3 04-30-2013 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 1807A Coax - High-Flex S-Video Cable CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Suitability Suitability - Indoor: Yes Suitability - Outdoor: Yes Plenum/Non-Plenum Plenum (Y/N): No Plenum Number: 7700A Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 75 Nom. Inductance: Inductance (µH/m) 0.318257 Nom. Capacitance Conductor to Shield: Capacitance (pF/m) 56.7613 Nominal Velocity of Propagation: VP (%) 78 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/km) 328.1 Nom. Inner Shield DC Resistance: DCR @ 20°C (Ohm/km) 24.6075 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100m) 1 1.9686 5 4.5934 10 6.8901 30 12.4678 50 16.7331 100 24.9356 200 37.0753 400 55.4489 700 76.4473 900 88.2589 1000 93.8366 Max. Operating Voltage - Non-UL: Voltage 300 V RMS Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 1807A B59U1000 305 MT 6.804 KG BLACK, MATTE C 2 #30 FHDPE SRV PVC DUAL 1807A B59U500 152 MT 3.629 KG BLACK, MATTE 1807A B591000 305 MT 6.804 KG BLACK, MATTE 1807A B59500 152 MT 3.402 KG BLACK, MATTE 2 #30 FHDPE SRV PVC DUAL C 2 #30 FHDPE SRV PVC DUAL 2 #30 FHDPE SRV PVC DUAL Notes: C = CRATE REEL PUT-UP. Page 2 of 3 04-30-2013 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 1807A Coax - High-Flex S-Video Cable C = CRATE REEL PUT-UP. Revision Number: 2 Revision Date: 04-11-2008 © 2013 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 3 of 3 04-30-2013
1807A B59500 价格&库存
很抱歉,暂时无法提供与“1807A B59500”相匹配的价格&库存,您可以联系我们找货
