1817R 010500
1817R 010500
    BELDEN
    8 #22 FS PR PVC FS PVC
1817R 010500 数据手册
Part Number: 1817R Audio Snake Cable, #22-8pr, TC, Indiv. Shielded, CMR Product Description Audio Snake Cable, Riser-CMR, 8-22 AWG tinned copper pairs, polyolefin insulation, individually shielded with Beldfoil® bonded to numbered/color-coded PVC jackets so both strip simulteaneously, PVC jacket Technical Specifications Product Overview Environmental Space: Indoor - Riser Physical Characteristics (Overall) Conductor AWG Stranding 22 7x30 Material Nominal Diameter No. of Pairs TC - Tinned Copper 0.03 in Conductor Count: 16 Total Number of Pairs: 8 AWG Size: 22 8 Insulation Material Nominal Diameter Nominal Wall Thickness PO - Polyolefin 0.05 in 0.010 in Color Chart Number Color 1 Brown 2 Red 3 Orange 4 Yellow 5 Green 6 Blue 7 Purple 8 Gray Pairs Red & Black Inner Shield Material Type Material Material Trade Name Coverage [%] Drainwire Material Tape Aluminum Foil-Polyester Tape Beldfoil® 100 % Drainwire Diameter TC - Tinned Copper 0.030 in Drainwire AWG Drainwire Construction n x D 22 7x30 TC - Tinned Copper Inner Jacket Material Material Nominal Diameter Nominal Wall Thickness PVC - Polyvinyl Chloride 0.133 in 0.015 in Outer Shield Material Type Material Material Trade Name Coverage [%] Drainwire Material Tape Aluminum Foil-Polyester Tape Beldfoil® 100 % Outer Jacket Material Material Drainwire Diameter Drainwire AWG Drainwire Construction n x D TC - Tinned Copper 0.048 in Nominal Diameter Nominal Wall Thickness Ripcord 18 19x30 PVC - Polyvinyl Chloride 0.503 in 0.030 in Yes 0.503 in Electrical Characteristics Conductor DCR Individual Pair Nominal Shield DCR Nominal Conductor DCR Nominal Conductor DCR Conductor Resistance Nominal Outer Shield DCR 14.1 Ohm/1000ft 14.8 Ohm/1000ft 14.8 Ohm/1000ft Capacitance Nom. Capacitance Conductor to Conductor Nom. Capacitance Conductor to Other Conductor to Shield 31 pF/ft 56 pF/ft Inductance Nominal Inductance 0.18 µH/ft Impedance Nominal Characteristic Impedance 50 Ohm Delay Nominal Velocity of Propagation (VP) [%] 66 % Current Max. Recommended Current [A] 1.45 Amps per conductor @ 25°C Voltage UL Voltage Rating 300 V RMS Temperature Range Operating Temp Range: -20°C To +60°C Mechanical Characteristics Bulk Cable Weight: 145 lbs/1000ft Max Recommended Pulling Tension: 243.1 lbs Min Bend Radius/Minor Axis: 5 in Standards NEC/(UL) Specification: CMR CEC/C(UL) Specification: CMG Applicable Environmental and Other Programs EU Directive 2000/53/EC (ELV): Yes EU Directive 2003/11/EC (BFR): Yes EU Directive 2011/65/EU (ROHS II): Yes EU Directive 2012/19/EU (WEEE): Yes EU Directive 2015/863/EU: Yes EU Directive Compliance: EU Directive 2003/11/EC (BFR) EU CE Mark: Yes EU RoHS Compliance Date (yyyy-mm-dd): 2004-01-01 CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Suitability Suitability - Indoor: Yes Flammability, LS0H, Toxicity Testing UL Flammability: UL1666 Riser 11.8 Ohm/1000ft CSA Flammability: FT4 Part Number Plenum (Y/N): No Plenum Number: 1817P Footnote: C - CRATE REEL PUT-UP. Product Notes Notes: Pair jackets and shields are bonded so both strip simultaneously with automatic stripping equipment. Beldfoil® provides high reliability with ease of termination. © 2018 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS(Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be instock at Belden facilities and in our Distributor's inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden's knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC.
1817R 010500 价格&库存
很抱歉,暂时无法提供与“1817R 010500”相匹配的价格&库存,您可以联系我们找货
