1856A 0041000
1856A 0041000
    BELDEN
    #20 PE/GIFHDPELDPE PVC TRIAX
1856A 0041000 数据手册
Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 1856A Coax - RG-59/U Type For more Information please call 1-800-Belden1 General Description: 20 AWG solid .032" bare copper conductor, gas-injected foam HDPE insulation, bare copper braid shields (95% coverage), Belflex® jacket. Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material Dia. (mm) 1 20 Solid BC - Bare Copper 0.8128 Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Dia. (mm) Gas-injected FHDPE - Foam High Density Polyethylene 3.683 Inner Shield Inner Shield Material: Type Inner Shield Material Coverage (%) Braid BC - Bare Copper 95 Inner Jacket Inner Jacket Material: Inner Jacket Material Nom. Dia. (mm) PE - Polyethylene 5.4864 Outer Shield Outer Shield Material: Type Outer Shield Material Coverage (%) Braid BC - Bare Copper 95 Outer Jacket Outer Jacket Material: Outer Jacket Trade Name Outer Jacket Material Belflex® PVC Blend - Polyvinyl Chloride Blend Overall Cable Overall Nominal Diameter: 9.144 mm Mechanical Characteristics (Overall) Operating Temperature Range: -35°C To +75°C Non-UL Temperature Rating: 75°C Bulk Cable Weight: 113.103 Kg/Km Max. Recommended Pulling Tension: 551.577 N Min. Bend Radius/Minor Axis: 95.250 mm Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: No EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes Page 1 of 3 01-09-2015 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 1856A Coax - RG-59/U Type CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes RG Type: 59/U Suitability Suitability - Indoor: Yes Suitability - Outdoor: Yes - Black for permanent installations. All colors for field deployable use. Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 75 Nom. Inductance: Inductance (µH/m) 0.318257 Nom. Capacitance Conductor to Shield: Capacitance (pF/m) 53.1522 Nominal Velocity of Propagation: VP (%) 83 Nominal Delay: Delay (ns/m) 4.00282 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/km) 33.1381 Nom. Inner Shield DC Resistance: DCR @ 20°C (Ohm/km) 8.2025 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/km) 5.2496 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100m) 1 0.9843 3.6 1.9686 10 2.6248 71.5 7.2182 135 9.843 270 13.7802 360 15.7488 540 19.3579 720 22.6389 750 23.2951 1000 28.8728 1500 39.372 2250 53.8084 3000 66.9324 Max. Operating Voltage - Non-UL: Voltage 300 V RMS Minimum Structural Return Loss: Start Freq. (MHz) Stop Freq. (MHz) Min. SRL (dB) 5 850 21 851 3000 15 Sweep Test Sweep Testing: 100% Sweep tested 5 MHz to 3 GHz. Notes (Overall) Notes: Permanent indent printing for field identification. Page 2 of 3 01-09-2015 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 1856A Coax - RG-59/U Type Notes: Permanent indent printing for field identification. Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 1856A B591000 1,000 FT 83.000 LB BLACK, MATTE C #20 PE/GIFHDPELDPE PVC TRIAX 1856A 0021000 1,000 FT 83.000 LB RED C #20 PE/GIFHDPELDPE PVC TRIAX 1856A 0041000 1,000 FT 83.000 LB YELLOW C #20 PE/GIFHDPELDPE PVC TRIAX 1856A 0051000 1,000 FT 83.000 LB GREEN, DARK C #20 PE/GIFHDPELDPE PVC TRIAX 1856A 0061000 1,000 FT 83.000 LB BLUE, LIGHT C #20 PE/GIFHDPELDPE PVC TRIAX Notes: C = CRATE REEL PUT-UP. Revision Number: 2 Revision Date: 09-19-2012 © 2015 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 3 of 3 01-09-2015
1856A 0041000 价格&库存
很抱歉,暂时无法提供与“1856A 0041000”相匹配的价格&库存,您可以联系我们找货
