3076F 0031000
3076F 0031000
    BELDEN
    CBL 1PR 18AWG SHLD
3076F 0031000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 3076F Multi-Conductor - DataBus® ISA/SP-50 FOUNDATION Fieldbus or PROFIBUS Cable For more Information please call 1-800-Belden1 General Description: 1 pair 18 AWG stranded (7x26) tinned copper conductors, polyolefin insulation, polyolefin filler, Beldfoil® shield (100% coverage), tinned copper drain wire, binder, PVC jacket. Fieldbus Foundation Registered Product. Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material Dia. (in.) 1 18 7x26 TC - Tinned Copper 0.046 Total Number of Conductors: 2 Insulation Insulation Material: Insulation Material PO - Polyolefin Outer Shield Outer Shield Material: Outer Shield Trade Name Type Outer Shield Material Beldfoil® Coverage (%) Tape Aluminum Foil-Polyester Tape 100 Outer Shield Drain Wire AWG: AWG Stranding Drain Wire Conductor Material 20 7x28 TC - Tinned Copper Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Outer Jacket Diameter: Nom. Dia. (in.) 0.280 Overall Cable Overall Cabling Fillers: Polypropylene Overall Cabling Lay Length & Direction: Length (in.) Twists (twist/ft) 2.250 5.300 Mechanical Characteristics (Overall) Operating Temperature Range: -40°C To +105°C UL Temperature Rating: 105°C Bulk Cable Weight: 38 lbs/1000 ft. Max. Recommended Pulling Tension: 60 lbs. Min. Bend Radius/Minor Axis: 2.500 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CM, CMX-Outdoor, PLTC-ER NEC Articles: 725, 727, 800 CEC/C(UL) Specification: CMG EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 3076F Multi-Conductor - DataBus® ISA/SP-50 FOUNDATION Fieldbus or PROFIBUS Cable EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Other Specification: ITC-ER Flame Test UL Flame Test: UL1666 Riser C(UL) Flame Test: FT4 IEEE Flame Test: 1202, IEEE 383 Vertical Tray Flame Test (70,000 BTU) Suitability Suitability - Indoor: Yes Suitability - Outdoor: Yes Suitability - Burial: Yes - UL Sunlight Resistance: Yes Oil Resistance: Yes Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Unaveraged Impedance: Freq. (MHz) Impedance (Ohm) 0.031 100.000 Nom. Inductance: Inductance (µH/ft) .19 Nom. Capacitance Conductor to Shield: Capacitance (pF/ft) 45.0 Nom. Mutual Capacitance: Capacitance (pF/ft) 24.0 Maximum Capacitance Unbalance: Capacitance (pF/ft) 1.200 Nominal Velocity of Propagation: VP (%) 66 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 5.86 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 7.500 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 0.039 0.080 Max. Attenuation: () Freq. (MHz) Attenuation (dB/100 ft.) .091 0.039 0.091 Max. Operating Voltage - UL: Voltage 300 V RMS Max. Recommended Current: Description Current Page 2 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 3076F Multi-Conductor - DataBus® ISA/SP-50 FOUNDATION Fieldbus or PROFIBUS Cable Per Conductor 5.2 Amps Other Electrical Characteristic 1: Max Propagation Delay Change From 7.812 kHz to 39.06 kHz: 518 pS/ft Other Electrical Characteristic 2: 31.25 KBits/sec Notes (Overall) Notes: Fieldbus: Orange jacket. Profibus PA: Intrinsically Safe Blue jacket. Jacket diameter tolerance: +/- .010 Related Documents: FieldbusCertificate-3076F.pdf - This is a Foundation H1 Cable Registration Certification for 3076F. Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 3076F 0031000 1,000 FT 48.000 LB ORANGE C TW PR #18 PP FS PVC 3076F 00310000 10,000 FT 510.000 LB ORANGE CN TW PR #18 PP FS PVC 3076F 003250 250 FT 14.000 LB ORANGE C TW PR #18 PP FS PVC 3076F 0032500 2,500 FT 120.000 LB ORANGE C TW PR #18 PP FS PVC 3076F 003500 500 FT 25.500 LB ORANGE C TW PR #18 PP FS PVC 3076F 0035000 5,000 FT 240.000 LB ORANGE CN TW PR #18 PP FS PVC 3076F 0061000 1,000 FT 48.000 LB BLUE, LIGHT C TW PR #18 PP FS PVC Notes: C = CRATE REEL PUT-UP. N = FINAL PUT-UP LENGTH MAY VARY -0% TO +10% FROM LENGTH SHOWN. Revision Number: 7 Revision Date: 06-18-2014 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 01-05-2017
3076F 0031000 价格&库存
很抱歉,暂时无法提供与“3076F 0031000”相匹配的价格&库存,您可以联系我们找货
3076F 0031000
  • 1+52.079011+6.76870
  • 50+41.2980450+5.36750
  • 100+36.86394100+4.79120
  • 305+32.60372305+4.23750
库存:305
