Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
37501 Hook-up/Lead - UL AWM Style 3499
For more Information
please call
1-800-Belden1
General Description:
EPDM is naturally corona and more heat resistant than many other rubber compounds and is able to take
longer bake cycles frequently needed for big jobs. EPDM has superior weather resistance and low
temperature pliability.
Physical Characteristics (Overall)
Conductor
AWG:
# Conductors AWG Stranding Conductor Material
1
1
210x24
TC - Tinned Copper
Total Number of Conductors:
1
Insulation
Insulation Material:
Insulation Material
Min. Avg. Wall (in.)
EPDM - Ethylene Propylene Diene Monomer Rubber 0.125
Separator
Separator Material over Conductor:
Y
Overall Insulation
Overall Cable
Overall Nominal Diameter:
0.638 in.
Mechanical Characteristics (Overall)
Operating Temperature Range:
-55°C To +150°C
Bulk Cable Weight:
395 lbs/1000 ft.
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
UL Rating:
7500 V, 150°C
EU Directive 2011/65/EU (ROHS II):
Yes
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
01/01/2004
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
Plenum/Non-Plenum
Plenum (Y/N):
No
Electrical Characteristics (Overall)
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/1000 ft)
0.120
Max. Operating Voltage - UL:
Voltage
Description
7500 VRMS UL AWM 3499
Max. Recommended Current:
Description
Current
Single conductor in free air @ 30C ambient 293 amps
Page 1 of 2
08-26-2016
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
Notes
Item Desc
37501 01050
50 FT
23.050 LB
BLACK
C
#1 EPDM 150C 7.5KV AC
37501 010500
500 FT
214.500 LB
BLACK
CF
Notes:
C = CRATE REEL PUT-UP.
F = MAY CONTAIN MORE THAN 1 PIECE. MINIMUM LENGTH OF ANY ONE PIECE IS 50'
Revision Number: 1
Revision Date: 08-30-2013
© 2016 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Page 2 of 2
08-26-2016
很抱歉,暂时无法提供与“37501 01050”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 50+344.8922950+44.74949
