Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
49725A Molded Cable Assemblies - D-Subminiature Assembly
For more Information
please call
1-800-Belden1
General Description:
15 position shielded D-Sub, for any 15-pin application exposed to high-noise enviroment, S-R PVC
insulation, foil shield (general purpose), PVC jacket.
Physical Characteristics (Overall)
Conductor
AWG:
# Conductors AWG Stranding Conductor Material Dia. (in.)
15
24
7x32
TC - Tinned Copper .024
Total Number of Conductors:
15
Number of Pins:
15
Insulation
Insulation Material:
Insulation Material
Wall Thickness (in.)
S-R PVC - Semi-Rigid Polyvinyl Chloride 0.01
Connector Characteristics
Connector Characteristics - First End # of
Connector Contacts/positions:
15
Connector Characteristics - First End Connector Male
Gender:
Connector Characteristics - First End Connector Metal Backshell
Shielding Type:
Connector Characteristics - First End Connector D-Sub
Type:
Connector Characteristics - First End Overmold
Color:
Chrome
Compound Material:
PVC
Type:
15 Position D-Sub
Connector Characteristics - First End Retention
Hardware:
Thumbscrew
Connector Characteristics - Second End # of
15
Connector Gender:
Female
Connector Shielding Type:
Metal Backshell
Connector Type:
D-Sub
Overmold Color:
Chrome
Overmold Compound Material:
PVC
Page 1 of 3
10-14-2013
Overmold Type:
15 Position D-Sub
Retention Hardware:
Thumbscrew
Outer Shield
Outer Shield Material:
Outer Shield Trade Name Type Outer Shield Material
Beldfoil®
Coverage (%)
Tape Aluminum Foil-Polyester Tape 100
Outer Shield Drain Wire AWG:
AWG Stranding Drain Wire Conductor Material
24
7x32
TC - Tinned Copper
Outer Jacket
Outer Jacket Material:
Nom. Wall Thickness (in.)
PVC - Polyvinyl Chloride 0.032
Overall Cable
Overall Nominal Diameter:
0.284 in.
Assembly Dimensional
Assembly Dimensional Length:
5
Wiring
Wiring:
Point to Point. Pin #1 on end 1 to Pin #1 on end 2, Pin #2 to Pin #2, etc. Cable
shield connected to connector shell.
Mechanical Characteristics (Overall)
UL Temperature Rating:
80°C (UL AWM Style 2464)
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
NEC/(UL) Specification:
CM (cable only)
AWM Specification:
UL Style 2464 (300 V 80°C) (cable only)
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
04/01/2005
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
Plenum/Non-Plenum
Plenum (Y/N):
No
Electrical Characteristics (Overall)
Max. Operating Voltage - UL:
Voltage
300 V RMS (UL AWM Style 2464)
Notes (Overall)
Notes: Molded handles are 100% shielded to assist in FCC compliance and guard against EMI/RFI. All connectors tin-plated and
male connectors have detents for positive ground connection. Wiring is point-to-point with the shield to connector shell.
Notes (Cont'd.):
Jack screw retention on both connectors.
Put Ups and Colors:
Page 2 of 3
10-14-2013
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
49725A 060S2
1 EA
0.500 LB
CHROME
Revision Number: 1
Notes
Item Desc
15 POS SHD D-SUB 9541
Revision Date: 09-19-2008
© 2013 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications
described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not
ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express,
statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or
exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract,
negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the
compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and
the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge,
information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide
for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not
to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for
determining the applicability of legislation and regulations based on their individual usage of the product.
Page 3 of 3
10-14-2013
很抱歉,暂时无法提供与“49725A 060S2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+4225.915491+542.05861
