MachFlex 350 CY Cables
Shielded (CY) PVC Control Cables
Tinned Copper Braid Shield (TCB) Excellent Noise Immunity
Applications
Designed for applications which are installed in occasional flexing and fixed locations. Cable
applications include precision control sensors, multi axis control machines, temperature
controllers, control panels, machine cutting tools, auxiliary equipment, motor speed control,
production machinery and many more.
General Reference Standards
DIN VDE 0295, IEC 60228, BS6360
DIN EN 50290-2-22, DIN VDE 0207-363-4-1
DIN VDE 0482-332-1-2, DIN EN 60332-1-2, IEC 60332-1-2
RoHS & REACH & CE Directives
Construction and Performance
1.
Conductor Material
Stranded bare copper (DIN VDE 0295 Class 5)
2.
Insulation Material & Color
Insulation Material & Color PVC (polyvinyl chloride).
A) All black color with number coding = without protective conductor. B) Black
color with number coding plus 1 green & yellow = with protective conductor.
3.
Braid Shield Material
4.
Jacket / Sheath Material
5.
Flame Retardancy
6.
Voltage Rating (Uo/U)
300 / 500 V
7.
Oil Resistant
DIN EN 50290-2-22 (TM54)
8.
Temperature Range
-30 °C TO +70 °C (Occasional movement)
-40 °C TO +80 °C (Fixed installation)
9.
Bending Radius
20 x OD (Occasional movement)
6 x OD (Fixed installation)
10.
Other Properties
Good UV resistance, chemical resistance & flexibility
MachFlex 350 CY Shielded (CY) PVC Control Cables
TINNED COPPER BRAID SHIELDED CABLE WITH (G) PROTECTIVE GROUND
5
4
3
2
1
Conductor 0.50 mm2
No. of
Cores
3
4
5
7
12
Nom. Overall
Diameter (mm)
7.2
7.7
8.3
9.1
11.4
13.7
1 = Conductor
2 = Insulation
3 = Inner Sheath
4 = Tinned Copper Braid Shielded
5 = Outer Sheath
Conductor 0.75 mm2
Copper Weight
(kg/km)
45.08
53.90
64.68
78.40
135.73
226.25
EMEA
Part Code
3GACY
4GACY
5GACY
7GACY
12GACY
20GACY
APAC
Part Code
3G0.5CY
4G0.5CY
5G0.5CY
7G0.5CY
12G0.5CY
20G0.5CY
Conductor 1.00 mm2
No. of
Cores
3
4
5
7
12
Nom. Overall
Diameter (mm)
7.7
8.3
9.2
9.9
12.4
15.0
Copper Weight
(kg/km)
55.86
62.72
75.46
99.96
173.46
289.10
EMEA
Part Code
3GBCY
4GBCY
5GBCY
7GBCY
12GBCY
20GBCY
APAC
Part Code
3G0.75CY
4G0.75CY
5G0.75CY
7G0.75CY
12G0.75CY
20G0.75CY
Conductor 1.50 mm2
No. of Nom. Overall
Copper Weight
Cores Diameter (mm)
(kg/km)
3
8.2
63.70
4
9.1
76.44
5
9.8
87.22
7
10.5
110.74
12
13.3
184.34
307.23
Conductor 2.50 mm2
EMEA
Part Code
3GCCY
4GCCY
5GCCY
7GCCY
12GCCY
20GCCY
APAC
Part Code
3G1.0CY
4G1.0CY
5G1.0CY
7G1.0CY
12G1.0CY
20G1.0CY
No. of Nom. Overall
Copper Weight
Cores Diameter (mm)
(kg/km)
3
9.0
77.42
4
9.7
95.06
5
10.5
113.68
7
11.3
146.02
12
14.4
274.40
457.33
Conductor 4.00 mm2
EMEA
Part Code
3GDCY
4GDCY
5GDCY
7GDCY
12GDCY
20GDCY
APAC
Part Code
3G1.5CY
4G1.5CY
5G1.5CY
7G1.5CY
12G1.5CY
20G1.5CY
No. of Nom. Overall
Copper Weight
Cores Diameter (mm)
(kg/km)
3
11.0
143.08
4
11.9
163.66
5
12.9
196.00
7
14.0
282.24
12
18.2
467.75
779.58
Conductor 6.00 mm2
EMEA
Part Code
3GECY
4GECY
5GECY
7GECY
12GECY
20GECY
APAC
Part Code
3G2.5CY
4G2.5CY
5G2.5CY
7G2.5CY
12G2.5CY
20G2.5CY
No. of Nom. Overall
Copper Weight
Cores Diameter (mm)
(kg/km)
3
12.6
174.20
4
13.7
232.26
5
14.9
274.40
7
16.2
384.16
9
20.0
493.92
12
21.5
658.56
Conductor 10.00 mm2
EMEA
Part Code
3GFCY
4GFCY
5GFCY
7GFCY
9GFCY
12GFCY
APAC
Part Code
3G4CY
No. of
Cores
3
4
5
7
9
EMEA
Part Code
3GGCY
4GGCY
5GGCY
7GGCY
9GGCY
APAC
Part Code
3G6CY
4G6CY
5G6CY
7G6CY
9G6CY
No. of
Cores
3
4
5
7
9
EMEA
Part Code
3GHCY
4GHCY
5GHCY
7GHCY
9GHCY
APAC
Part Code
3G10CY
4G10CY
5G10CY
7G10CY
9G10CY
EMEA
Part Code
3GJCY
4GJCY
5GJCY
7GJCY
APAC
Part Code
3G25CY
4G25CY
5G25CY
7G25CY
Nom. Overall
Diameter (mm)
14.6
16.0
17.5
19.1
23.6
Copper Weight
(kg/km)
233.73
311.64
432.18
519.40
667.80
Conductor 16.00 mm2
No. of
Cores
3
4
5
7
Nom. Overall
Diameter (mm)
21.5
23.6
26.0
28.5
Copper Weight
(kg/km)
594.86
787.92
916.30
1,282.82
Nom. Overall
Diameter (mm)
17.8
19.8
21.7
23.8
29.2
Copper Weight
(kg/km)
355.15
507.64
583.10
780.08
1,004.24
4G4CY
5G4CY
7G4CY
9G4CY
12G4CY
Conductor 25.00 mm2
EMEA
Part Code
3GICY
4GICY
5GICY
7GICY
APAC
Part Code
3G16CY
4G16CY
5G16CY
7G16CY
No. of
Cores
3
4
5
7
Nom. Overall
Diameter (mm)
25.9
28.6
31.5
34.2
• Putup length & tolerance of the cables will vary depending on the construction of the cable
• MOQ will vary depending on the construction of the cable & provided at the time of quotation
• Cable requested outside the above design criteria can be reviewed and quoted
Copper Weight
(kg/km)
853.33
1,137.78
1,372.00
1,920.80
TINNED COPPER BRAID SHIELDED CABLE WITHOUT (G) PROTECTIVE GROUND
5
4
3
2
1
Conductor 0.50 mm2
No. of
Cores
3
4
5
7
12
Nom. Overall
Diameter (mm)
7.2
7.7
8.3
9.1
11.4
13.7
1 = Conductor
2 = Insulation
3 = Inner Sheath
5 = Outer Sheath
Conductor 0.75 mm2
Copper Weight
(kg/km)
45.08
53.90
64.68
78.40
135.73
226.25
EMEA
Part Code
3XACY
4XACY
5XACY
7XACY
12XACY
20XACY
APAC
Part Code
3X0.5CY
4X0.5CY
5X0.5CY
7X0.5CY
12X0.5CY
20X0.5CY
Conductor 1.00 mm2
No. of
Cores
3
4
5
7
12
Nom. Overall
Diameter (mm)
7.7
8.3
9.2
9.9
12.4
15.0
Copper Weight
(kg/km)
55.86
62.72
75.46
99.96
173.46
289.10
EMEA
Part Code
3XBCY
4XBCY
5XBCY
7XBCY
12XBCY
20XBCY
APAC
Part Code
3X0.75CY
4X0.75CY
5X0.75CY
7X0.75CY
12X0.75CY
20X0.75CY
Conductor 1.50 mm2
No. of Nom. Overall
Copper Weight
Cores Diameter (mm)
(kg/km)
3
8.2
63.70
4
9.1
76.44
5
9.8
87.22
7
10.5
110.74
12
13.3
184.34
307.23
Conductor 2.50 mm2
EMEA
Part Code
3XCCY
4XCCY
5XCCY
7XCCY
12XCCY
20XCCY
APAC
Part Code
3X1.0CY
4X1.0CY
5X1.0CY
7X1.0CY
12X1.0CY
20X1.0CY
No. of Nom. Overall
Copper Weight
Cores Diameter (mm)
(kg/km)
3
9.0
77.42
4
9.7
95.06
5
10.5
113.68
7
11.3
146.02
12
14.4
274.40
457.33
Conductor 4.00 mm2
EMEA
Part Code
3XDCY
4XDCY
5XDCY
7XDCY
12XDCY
20XDCY
APAC
Part Code
3X1.5CY
4X1.5CY
5X1.5CY
7X1.5CY
12X1.5CY
20X1.5CY
No. of Nom. Overall
Copper Weight
Cores Diameter (mm)
(kg/km)
3
11.0
143.08
4
11.9
163.66
5
12.9
196.00
7
14.0
282.24
12
18.2
467.75
779.58
Conductor 6.00 mm2
EMEA
Part Code
3XECY
4XECY
5XECY
7XECY
12XECY
20XECY
APAC
Part Code
3X2.5CY
4X2.5CY
5X2.5CY
7X2.5CY
12X2.5CY
20X2.5CY
No. of Nom. Overall
Copper Weight
Cores Diameter (mm)
(kg/km)
3
12.6
174.20
4
13.7
232.26
5
14.9
274.40
7
16.2
384.16
9
20.0
493.92
12
21.5
658.56
Conductor 10.00 mm2
EMEA
Part Code
3XFCY
4XFCY
5XFCY
7XFCY
9XFCY
12XFCY
APAC
Part Code
3X4CY
4X4CY
5X4CY
7X4CY
9X4CY
12X4CY
No. of
Cores
3
4
5
7
9
EMEA
Part Code
3XGCY
4XGCY
5XGCY
7XGCY
9XGCY
APAC
Part Code
3X6CY
4X6CY
5X6CY
7X6CY
9X6CY
No. of
Cores
3
4
5
7
9
EMEA
Part Code
3XHCY
4XHCY
5XHCY
7XHCY
9XHCY
APAC
Part Code
3X10CY
4X10CY
5X10CY
7X10CY
9X10CY
EMEA
Part Code
3XJCY
4XJCY
5XJCY
7XJCY
APAC
Part Code
3X25CY
4X25CY
5X25CY
7X25CY
Nom. Overall
Diameter (mm)
14.6
16.0
17.5
19.1
23.6
Copper Weight
(kg/km)
233.73
311.64
432.18
519.40
667.80
Conductor 16.00 mm2
No. of
Cores
3
4
5
7
Nom. Overall
Diameter (mm)
21.5
23.6
26.0
28.5
Copper Weight
(kg/km)
594.86
787.92
916.30
1,282.82
Nom. Overall
Diameter (mm)
17.8
19.8
21.7
23.8
29.2
Copper Weight
(kg/km)
355.15
507.64
583.10
780.08
1,004.24
Conductor 25.00 mm2
EMEA
Part Code
3XICY
4XICY
5XICY
7XICY
APAC
Part Code
3X16CY
4X16CY
5X16CY
7X16CY
No. of
Cores
3
4
5
7
Nom. Overall
Diameter (mm)
25.9
28.6
31.5
34.2
Copper Weight
(kg/km)
853.33
1,137.78
1,372.00
1,920.80
很抱歉,暂时无法提供与“4GDCY-KC50”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+52.132781+6.75740
- 25+43.0662125+5.58220
- 50+38.5329250+4.99460
- 100+33.99964100+4.40700
- 国内价格
- 1+1756.08535
- 5+1685.84401
