Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
6504FE Multi-Conductor - Commercial Applications
For more Information
please call
1-800-Belden1
General Description:
Security & Alarm Cable, Plenum-CMP, 6-22 AWG stranded bare copper conductors with Flamarrest®
insulation, Beldfoil® shield and Flamarrest® jacket with ripcord
Physical Characteristics (Overall)
Conductor
AWG:
# Conductors AWG Stranding Conductor Material
6
22
7
BC - Bare Copper
Total Number of Conductors:
6
Insulation
Insulation Material:
Insulation Trade Name Insulation Material
Flamarrest®
Wall Thickness (in.)
LS PVC - Low Smoke Polyvinyl Chloride 0.009
Outer Shield
Outer Shield Material:
Outer Shield Trade Name Type Outer Shield Material
Beldfoil®
Coverage (%)
Tape Aluminum Foil-Polyester Tape 100
Outer Shield Drain Wire AWG:
AWG Stranding Drain Wire Conductor Material
24
(7x32)
Tinned Copper
Outer Jacket
Outer Jacket Material:
Outer Jacket Trade Name Outer Jacket Material
Flamarrest®
Nom. Wall Thickness (in.)
LS PVC - Low Smoke Polyvinyl Chloride .015
Outer Jacket Ripcord:
Yes
Overall Cable
Overall Cabling Color Code Chart:
Color
Black
Red
White
Green
Brown
Blue
Overall Nominal Diameter:
0.175 in.
Mechanical Characteristics (Overall)
Installation Temperature Range:
0°C To +75°C
Operating Temperature Range:
-10°C To +75°C
Bulk Cable Weight:
24.400 lbs/1000 ft.
Max. Recommended Pulling Tension:
60.100 lbs.
Min. Bend Radius/Minor Axis:
1.800 in.
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
NEC/(UL) Specification:
CMP
CEC/C(UL) Specification:
CMP
EU Directive 2011/65/EU (ROHS II):
Yes
EU CE Mark:
Yes
Page 1 of 3
08-26-2016
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
04/01/2005
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
Flame Test
UL Flame Test:
NFPA 262
CSA Flame Test:
FT6
Suitability
Suitability - Indoor:
Yes
Plenum/Non-Plenum
Plenum (Y/N):
Yes
Non-Plenum Number:
5504FE
Electrical Characteristics (Overall)
Nom. Capacitance Conductor to Conductor:
Capacitance (pF/ft)
33
Nom. Capacitance Cond. to Other Conductor & Shield:
Capacitance (pF/ft)
59
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/1000 ft)
16.2
Nominal Outer Shield DC Resistance:
15.3
Max. Operating Voltage - UL:
Voltage
300 V RMS
Max. Recommended Current:
Description
Current
10C Temperature Rise 2 Amps per conductor @ 25°C ambient
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
6504FE 003U1000
1,000 FT
25.000 LB
ORANGE
Notes
Item Desc
6 #22 FLRST FS FLRST
6504FE 0031000
1,000 FT
26.000 LB
ORANGE
6504FE 004U1000
1,000 FT
26.000 LB
YELLOW
6504FE 0041000
1,000 FT
26.000 LB
YELLOW
6504FE 0071000
1,000 FT
26.000 LB
VIOLET
6504FE 877C500
500 FT
12.000 LB
NATURAL
6504FE 877U1000
1,000 FT
26.000 LB
NATURAL
6504FE 877U250
250 FT
7.250 LB
NATURAL
6504FE 877U500
500 FT
13.500 LB
NATURAL
6504FE 8771000
1,000 FT
26.000 LB
NATURAL
C
6504FE 877500
500 FT
13.500 LB
NATURAL
C
Notes:
C = CRATE REEL PUT-UP.
Revision Number: 2
Revision Date: 01-20-2015
© 2016 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
Page 2 of 3
08-26-2016
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU).
Page 3 of 3
08-26-2016
很抱歉,暂时无法提供与“6504FE 877500”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+33.412241+4.31660
- 50+26.4149150+3.41260
- 100+23.70345100+3.06230
- 152+20.72958152+2.67810
