66247.
    BELDEN
    BELDEN - 66247. - Sensor Connector, PROFIBUS Series, M12, Female, 5 Positions, Screw Socket, Straigh...
66247. 数据手册
M12 Field Attachable Connectors Male, 4-, 5-, and 8-Pole RSCS | 0976 PMC 101 | RKCS | 0976 PFC 101 RSCS | 0976 PMC 101 Field attachable connector, M12 male connector 4-, 5-, and 8-pole with threaded joint, shieldable, assembling with screw terminals. – 0976 PMC 101: 5 poles, B coding, especially suitable for Profibus signal cable 0975 254 000/... M – Female, 4-, 5-, and 8-Pole RKCS | 0976 PFC 101 Field attachable connector, M12 female connector 4-, 5-, and 8-pole with threaded joint, shieldable, assembling with screw terminals. – 0976 PFC 101: 5 poles, B coding, especially suitable for Profibus signal cable 0975 254 000/... M – Pin Assignments Face Views / M12, Male / Female 4 pole 320 5 pole 5 pole B coding 1-717-217-2299 8 pole www.lumberg-automationusa.com Field Attachable Connectors Be Certain with Belden M12 Field Attachable Connectors RSCS | 0976 PMC 101 | RKCS | 0976 PFC 101 Technical Data Environmental Degree of protection Operating temperature range IP 67 / NEMA 6P -25°C (-13°F) / +90°C (+194°F) Mechanical Housing / Molded body Insert Contact Receptacle shell Shield sleeve O-ring Mode of connection Connectable conductor GD-ZnAl, pre-coppered and nickel-plated PBT, RSCS 8/9: PA CuZn, pre-coppered, CuSnZn CuZn, nickel-plated CuBe, tin-plated FKM Screw terminals max. 0.75 mm2 Electrical Contact resistance ≤ 5 mΩ Nominal current at 40°C 3–5 poles 4 A, 8 poles 2 A Nominal voltage 3–4 poles 120 V 5 poles 60 V 8 poles 30 V Rated voltage 3–4 poles 125 V 5 poles 63 V 8 poles 36 V Test voltage 3–4 poles 1.5 kV eff. / 60 s 5–8 poles 1.0 kV eff. / 60 s Insulation resistance > 109 Ω Pollution degree 3 Part Number Pins Cable Diameter Range Female RSCS 4/9 RKCS 4/9 4 Ø 4.0-9.0 mm RSCS 5/9 RKCS 5/9 5 Ø 4.0-9.0 mm 0976 PMC 101 0976 PFC 101 5B Ø 4.0-9.0 mm RSCS 8/9 RKCS 8/9 8 Ø 4.0-9.0 mm www.lumberg-automationusa.com 1-717-217-2299 Field Attachable Connectors Male Characteristics 321
66247. 价格&库存
很抱歉,暂时无法提供与“66247.”相匹配的价格&库存,您可以联系我们找货
