70030.01100
70030.01100
    BELDEN
    BELDEN - 70030.01100 - Multicore Cable, Screened, 2 Core, 24 AWG, 0.22 mm², 328 ft, 100 m
70030.01100 数据手册
Part Number: 70030 AUDIO ANALOG 1 PAIR, 24AWG, ISTP, LSZH Product Description ANALOG AUDIO 1 PAIR, 24AWG/0.22mm², ISTP, LSZH Technical Specifications Product Overview Environmental Space: Indoor - Euroclass Dca Suitable Applications: Single pair 24 AWG halogen free screened pair cable for analog audio; For analogue audio Physical Characteristics (Overall) Conductor AWG Stranding 24 7x32 Material Construction n x D No. of Pairs BOFC - Bare Oxygen free Copper 7x0.20 mm Conductor Count: 2 Total Number of Pairs: 1 1 Insulation Type Material Nominal Diameter Diameter +/- Tolerance Insulation Polyethylene 1.02 mm 0.05 mm Color Chart Number Pair 1 Color Red & Black Outer Shield Material Type Foil Material Coverage [%] Aluminum/Polyester 100 % Drainwire Material Drainwire AWG Drainwire Construction n x D Drainwire Position Stranded tinned copper 24 7x0.20 mm Outer Jacket Material Material Nominal Diameter Diameter +/- Tolerance LSZH / FRNC 3.1 mm 0.1 mm Construction and Dimensions Cabling Description 1 Pair + Stranded tinned copper drainwire (AWG 24)(7x0.20) Electrical Characteristics Conductor DCR Nominal Conductor DCR Nominal Outer Shield DCR 88.5 Ohm/km 52 Ohm/km Capacitance Nom. Capacitance Conductor to Conductor Nom. Capacitance Conductor to Shield Under shielding foil 92 pF/m 180 pF/m Inductance Nominal Inductance 0.75 µH/m Temperature Range Other Temp Range: -30-+70 °C Mechanical Characteristics Max Recommended Pulling Tension: 70 N Min Bend Radius During Installation: 31 mm Min Setting Radius: 15.5 mm Standards CPR Euroclass: Dca-s2,d1,a1 Applicable Environmental and Other Programs EU RoHS Compliance Date (yyyy-mm-dd): 2013-07-05 Flammability, LS0H, Toxicity Testing ISO/IEC Flammability: IEC 60332-1-2 LOI of Jacket: 34 % Amount of Halogen acc. to IEC 60754-1 & EN50267-1: Zero Part Number Variants Item # Color Length 70030.01100 Black 100 m 70030.01500 Black 500 m 70030.00100 Gray 100 m 70030.00500 Gray 500 m History Update and Revision: Revision Number: 0.120 Revision Date: 08-22-2019 © 2019 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product.
70030.01100 价格&库存
很抱歉,暂时无法提供与“70030.01100”相匹配的价格&库存,您可以联系我们找货
  • 1+1135.14990
库存:800
