Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
7201A Multi-Conductor - 300V Flex Data Cables
For more Information
please call
1-800-Belden1
General Description:
24 AWG stranded (41x40) bare copper conductors, twisted pairs, foam polyethylene insulation with skin,
overall Beldfoil® (100% coverage), tinned copper braid shield (85% coverage), oil-resistant PVC jacket.
Usage (Overall)
Suitable Applications:
Flex Data, RS232, RS485
Physical Characteristics (Overall)
Conductor
AWG:
# Pairs AWG Stranding Conductor Material
2
24
41x40
BC - Bare Copper
Total Number of Conductors:
4
Insulation
Insulation Material:
Insulation Material
FPE - Foam Polyethylene
PE - Polyethylene
Insulation Resistance:
6.1 Megohms/1000 ft. minimum
Outer Shield
Outer Shield Material:
Layer # Outer Shield Trade Name Type Outer Shield Material
1
Beldfoil®
Coverage (%)
Tape Aluminum Foil-Polyester Tape 100
2
Braid TC - Tinned Copper
85
Outer Shield Drain Wire AWG:
AWG Stranding Drain Wire Conductor Material
24
41x40
TC - Tinned Copper
Outer Jacket
Outer Jacket Material:
PVC - Polyvinyl Chloride
Overall Cable
Overall Cabling Color Code Chart:
Number Color
1
White/Blue & Blue/White
2
White/Orange & Orange/White
Overall Nominal Diameter:
0.322 in.
Mechanical Characteristics (Overall)
Operating Temperature Range:
-20°C To +60°C
UL Temperature Rating:
60°C
Bulk Cable Weight:
43.500 lbs/1000 ft.
Max. Recommended Pulling Tension:
68 lbs.
Min. Bend Radius/Minor Axis:
3.200 in.
Min. Bend Radius (Continuous Flexing):
4.500 in.
Flex Cycle Rating:
1 Million
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
NEC/(UL) Specification:
CM
CEC/C(UL) Specification:
CM
Page 1 of 2
01-05-2017
CM
EU Directive 2011/65/EU (ROHS II):
Yes
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
10/01/2005
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
Other Specification:
RS Type: 232/485
Flame Test
UL Flame Test:
UL1685 UL Loading
Suitability
Oil Resistance:
Yes
Plenum/Non-Plenum
Plenum (Y/N):
No
Electrical Characteristics (Overall)
Max. Capacitance Conductor to Conductor:
Capacitance (pF/ft)
15
Nominal Velocity of Propagation:
VP (%)
72
Max. Operating Voltage - UL:
Voltage
300 V RMS
Differential Impedance @ 1 MHz:
120 +/-15
Notes (Overall)
Notes: 1 million flex cycles based on proper installation techniques in a C-track cable guide.
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
Notes
Item Desc
7201A X4P1000
1,000 FT
60.000 LB
GREEN X4P
C
2 PR #24 FHDPE/HDPE SH PVC
7201A X4P500
500 FT
31.000 LB
GREEN X4P
C
Notes:
C = CRATE REEL PUT-UP.
Revision Number: 1
Revision Date: 05-14-2007
© 2017 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Page 2 of 2
01-05-2017
很抱歉,暂时无法提供与“7201A X4P500”相匹配的价格&库存,您可以联系我们找货
