735A1 008500
735A1 008500
    BELDEN
    #26 LDPE/FHDPE SH PVC
735A1 008500 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 735A1 Coax - 735A* Series For more Information please call 1-800-Belden1 General Description: 26 AWG solid .016" (.40mm) silver-plated copper conductor(s), foam HDPE insulation, Beldfoil® + tinned copper braid shield (95% coverage), PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material 1 26 Solid Dia. (in.) SPC - Silver Plated Copper .016 Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Dia. (in.) FHDPE - Foam High Density Polyethylene .077 Outer Shield Outer Shield Material: Layer # Outer Shield Trade Name Type Outer Shield Material 1 Beldfoil® 2 Coverage (%) Tape Aluminum Foil-Polyester Tape 100.000 Braid TC - Tinned Copper 95.000 Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Overall Cable Overall Nominal Diameter: 0.129 in. Mechanical Characteristics (Overall) Operating Temperature Range: -40°C To +75°C Bulk Cable Weight: 12 lbs/1000 ft. Max. Recommended Pulling Tension: 25 lbs. Min. Bend Radius/Minor Axis: 1.250 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMR CEC/C(UL) Specification: CMG EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Other Specification: Telcordia Specification GR-139-CORE. Flame Test UL Flame Test: UL1666 Vertical Shaft Page 1 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 735A1 Coax - 735A* Series CSA Flame Test: FT4 Suitability Suitability - Indoor: Yes Plenum/Non-Plenum Plenum (Y/N): No Plenum Number: 735A1P Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 75 Nom. Inductance: Inductance (µH/ft) .19 Nom. Capacitance Conductor to Shield: Capacitance (pF/ft) 17.7 Nominal Velocity of Propagation: VP (%) 76 Nominal Delay: Delay (ns/ft) 1.34 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 41 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 5.3 Max. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 1.000 0.600 1.024 0.610 4.224 1.100 5.000 1.200 10.000 1.700 17.184 2.200 22.368 2.500 25.920 2.700 44.736 3.600 50.000 3.800 69.632 4.500 77.760 4.800 100.000 5.500 200.000 7.800 Max. Operating Voltage - UL: Voltage 300 V RMS Other Electrical Characteristic 1: Impedance tested in Accordance with ASTM D-4566 Paragraph 48.2, Option 2 using a 75 Ohm Fixed Bridge and Termination. Other Electrical Characteristic 2: RL tested in accordance with ASTM D-4566 Paragraph 50.3, using a 75 Ohm Fixed Bridge and Termination. Other Electrical Characteristic 3: 100% Sweep tested. Minimum Return Loss: Description Freq. (MHz) Start Freq. (MHz) Stop Freq. (MHz) Min. RL (dB) 15 90 30 Put Ups and Colors: Item # Putup Ship Weight Color 735A1 0081000 1,000 FT 13.000 LB GRAY #26 LDPE/FHDPE SH PVC 735A1 008500 500 FT 6.500 LB GRAY #26 LDPE/FHDPE SH PVC Page 2 of 3 Notes Item Desc 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 735A1 Coax - 735A* Series Revision Number: 5 Revision Date: 08-05-2013 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 08-26-2016
735A1 008500 价格&库存
很抱歉,暂时无法提供与“735A1 008500”相匹配的价格&库存,您可以联系我们找货
