76203WS 008100
76203WS 008100
    BELDEN
    CBL 3COND 24 AWG SHLD MACHFLEX
76203WS 008100 数据手册
Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 76203WS Multi-Conductor - 300V Foil/Spiral Shield, Continuous Flexing Data Applications Up to 6 Million Flex Life Cycles For more Information please call 1-800-Belden1 General Description: 24 AWG stranded (10x34) tinned copper conductors, PVC insulation, Aluminum/Polyester Foil Shield, Tinned copper spiral shield, 90% coverage, oil-resistant PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 3 24 10x34 TC - Tinned Copper Insulation Insulation Material: Insulation Material Wall Thickness (mm) PVC - Polyvinyl Chloride 0.254 Insulation Color Code Chart: Number Color 1 Black 2 Red 3 White Outer Shield Outer Shield Material: Layer # Type Outer Shield Material Coverage (%) 1 Tape 2 Serve TC - Tinned Copper Aluminum/Mylar 100.000 90.000 Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (mm) PVC - Polyvinyl Chloride 1.016 Overall Cable Overall Nominal Diameter: 5.055 mm Mechanical Characteristics (Overall) Bulk Cable Weight: 38.693 Kg/Km Max. Recommended Pulling Tension: 61.385 N Min. Bend Radius/Minor Axis: 40.640 mm Min. Bend/Installation: 40.640 mm Min. Bend Radius (Continuous Flexing): 40.640 mm Flex Cycle Rating: 6 Million Flexes Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CM CEC/C(UL) Specification: CMG EU Directive 2011/65/EU (ROHS II): Yes MII Order #39 (China RoHS): Yes Customer Part Number Reference Specification: AWM/STYLE 10002, AWM/STYLE 2661, CSA AWM I/II A/B, EU Directive 2011/65/EU(RoHS2), REACH Regulation (EC 1907/2006), California Proposition 65 Flame Test CSA Flame Test: FT4 Suitability Suitability - Burial: Yes Electrical Characteristics (Overall) Nom. Inductance: Inductance (µH/m) 0.623 Page 1 of 2 10-02-2017 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 76203WS Multi-Conductor - 300V Foil/Spiral Shield, Continuous Flexing Data Applications Up to 6 Million Flex Life Cycles Nom. Capacitance Conductor to Conductor: Freq. (MHz) Capacitance (pF/m) 0.001 104.992 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/km) 95.149 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/km) 21.983 Max. Operating Voltage - UL: Voltage 300V Notes (Overall) Notes: Temperature Range -10 to 105°C(static), +5 to 105°C (dynamic) Put Ups and Colors: Item # Revision Number: 0 Putup Ship Weight Color Notes Item Desc Revision Date: 09-27-2017 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Page 2 of 2 10-02-2017
76203WS 008100
物料型号:BELDEN 76203WS
器件简介: - 24 AWG(美国线规)的导体,由10x34的镀锡铜线组成。 - 聚氯乙烯(PVC)绝缘。 - 铝/聚酯箔屏蔽和镀锡铜螺旋屏蔽,覆盖率为90%。 - 耐油的PVC外护套。
引脚分配: - 导体材料:TC-Tinned Copper(镀锡铜)。 - 绝缘材料:PVC-Polyvinyl Chloride(聚氯乙烯),壁厚0.254毫米。 - 绝缘颜色编码:黑色、红色、白色。
参数特性: - 整体电缆的标称直径:5.055毫米。 - 电缆重量:38.693公斤/公里。 - 最大推荐拉力:61.385牛顿。 - 最小弯曲半径/次轴:40.640毫米。 - 连续弯曲的最小弯曲半径:40.640毫米。 - 弯曲周期评级:6百万次弯曲。
功能详解: - 适用标准和机构合规性:符合NEC/(UL)规范的CM等级,CEC/C(UL)规范的CMG等级,欧盟2011/65/EU指令(ROHS II)和中国RoHS指令。 - 火焰测试:CSA火焰测试FT4等级。 - 适用性:适合埋地使用。
应用信息: - 电缆适用于连续弯曲数据应用,寿命周期可达600万次弯曲。
封装信息: - 电缆的电气特性包括标称电感(0.623微亨/米)、标称电容(0.001兆赫兹时为104.992皮法/米)和导体直流电阻(20°C时为95.149欧姆/公里)。 - 外屏蔽的直流电阻(20°C时为21.983欧姆/公里)。 - 最大工作电压:300伏特。
其他信息: - 温度范围:静态-10至105°C,动态+5至105°C。 - 产品编号参考规范:AWM/STYLE 10002, AWM/STYLE 2661, CSA AWM I/II A/B等。 - 修订号:0,修订日期:2017年9月27日。
76203WS 008100 价格&库存
很抱歉,暂时无法提供与“76203WS 008100”相匹配的价格&库存,您可以联系我们找货
