7892A Z4B1000
7892A Z4B1000
    BELDEN
    12 #26 FHDPE FS PRPVC FS 1-1000'
7892A Z4B1000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7892A Multi-Conductor - Multi-Pair Cable For more Information please call 1-800-Belden1 General Description: 26 AWG stranded tinned copper conductor, Datalene® insulation, pairs individually shielded with bonded Beldfoil® with a drain wire and have numbered and color-coded PVC jackets, overall Beldfoil® shield/drain wire + overall PVC jacket with nylon rip cord Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material Dia. (in.) 12 26 7x34 TC - Tinned Copper .019 Total Number of Conductors: 24 Insulation Insulation Material: Insulation Trade Name Insulation Material Datalene® Dia. (in.) FHDPE - Foam High Density Polyethylene .054 Inner Shield Inner Shield Material: Inner Shield Trade Name Type Inner Shield Material Beldfoil® Coverage (%) Tape Bonded Aluminum Foil-Polyester Tape 100 Inner Shield Drain Wire AWG: AWG 26 Inner Shield Drain Wire Stranding: Stranded Inner Shield Drain Wire Conductor Material: TC - Tinned Copper Inner Jacket Inner Jacket Material: Inner Jacket Material Nom. Dia. (in.) PVC - Polyvinyl Chloride .136 Inner Jacket Color Code Chart: Number Color 1 Brown & Numbered 1 2 Red & Numbered 2 3 Orange & Numbered 3 4 Yellow & Numbered 4 5 Green & Numbered 5 6 Blue & Numbered 6 7 Purple & Numbered 7 8 Gray & Numbered 8 9 White & Numbered 9 10 Black & Numbered 10 11 Tan & Numbered 11 12 Pink & Numbered 12 Outer Shield Outer Shield Material: Outer Shield Trade Name Type Outer Shield Material Beldfoil® Coverage (%) Tape Aluminum Foil-Polyester Tape 100 Outer Shield Drain Wire AWG: AWG Stranding Drain Wire Conductor Material 26 Stranded TC - Tinned Copper Outer Jacket Outer Jacket Material: Outer Jacket Material Page 1 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7892A Multi-Conductor - Multi-Pair Cable PVC - Polyvinyl Chloride Outer Jacket Ripcord: Yes Overall Cable Overall Nominal Diameter: 0.679 in. Pair Pair Color Code Chart: Number Color 1 Red & Black 2 Red & Black 3 Red & Black 4 Red & Black 5 Red & Black 6 Red & Black 7 Red & Black 8 Red & Black 9 Red & Black 10 Red & Black 11 Red & Black 12 Red & Black Pair Lay Length & Direction: Lay Length (in.) 1.000 Mechanical Characteristics (Overall) Operating Temperature Range: -30°C To +80°C Bulk Cable Weight: 150 lbs/1000 ft. Max. Recommended Pulling Tension: 129 lbs. Min. Bend Radius/Minor Axis: 7 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CM CEC/C(UL) Specification: CM EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: UL1685 UL Loading C(UL) Flame Test: FT4 Plenum/Non-Plenum Plenum (Y/N): No Surface Printing (Overall) Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 110 Nom. Inductance: Inductance (µH/ft) .25 Nom. Capacitance Conductor to Conductor: Page 2 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 7892A Multi-Conductor - Multi-Pair Cable Capacitance (pF/ft) 12.5 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/ft) 25.0 Nominal Velocity of Propagation: VP (%) 76 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 37.3 Ind. Pair Nominal Shield DC Resistance @ 20 Deg. C: 25.500 Ohm/1000 ft Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) .384 .84 .7056 1.14 .768 1.18 1.024 1.34 1.4112 1.50 1.536 1.54 2.048 1.69 2.8224 1.86 3.0720 1.92 4.096 2.14 5.6448 2.40 6.144 2.47 8.192 2.75 11.2896 3.09 12.288 3.18 24.576 4.20 Notes (Overall) Notes: Pair jackets and shields are bonded so both strip simultaneously with automatic stripping equipment. Datalene® insulation features include low dielectric constant and a dissipation factor for high-speed, low-distortion data handling. Physical properties include good crush resistance and light weight. Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 7892A Z4B1000 1,000 FT 174.000 LB VIO Z4B C 12 #26 FHDPE FS PR PVC FS PVC Notes: C = CRATE REEL PUT-UP. Revision Number: 1 Revision Date: 04-15-2008 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 08-26-2016
7892A Z4B1000
- 物料型号:BELDEN 7892A - 器件简介:26 AWG的绞合镀锡铜导体,Datalene® 绝缘,成对单独屏蔽,带有排水线,并具有编号和颜色编码的PVC护套,整体Beldfoil® 屏蔽/排水线+整体PVC护套,带尼龙撕裂绳。 - 引脚分配:包含24对导体,绝缘材料为Datalene® FHDPE,内屏蔽材料为Beldfoil® 胶带,外屏蔽材料同样为Beldfoil® 胶带。 - 参数特性:包括操作温度范围、电缆重量、最大推荐拉力、最小弯曲半径等。 - 功能详解:Datalene® 绝缘具有低介电常数和耗散因子,适用于高速、低失真数据处理。 - 应用信息:符合多种环境标准和法规,如EU RoHS、EU LVD等。 - 封装信息:电缆的包装和颜色信息,以及修订号和日期。
7892A Z4B1000 价格&库存
很抱歉,暂时无法提供与“7892A Z4B1000”相匹配的价格&库存,您可以联系我们找货
