8212 010U1000
8212 010U1000
    BELDEN
    75 OHM COAX
8212 010U1000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8212 Coax - 75 Ohm Coax For more Information please call 1-800-Belden1 General Description: 20 AWG solid .032" bare copper-covered steel conductor, foam polyethylene insulation, bare copper braid shield (95% coverage), polyethylene jacket. Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material 1 20 Solid Dia. (in.) BCCS - Bare Copper Covered Steel .032 Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Dia. (in.) FPE - Foam Polyethylene .143 Outer Shield Outer Shield Material: Type Outer Shield Material Coverage (%) Braid BC - Bare Copper 95 Outer Jacket Outer Jacket Material: Outer Jacket Material PE - Polyethylene Overall Cable Overall Nominal Diameter: 0.242 in. Mechanical Characteristics (Overall) Operating Temperature Range: -55°C To +80°C Non-UL Temperature Rating: 80°C Bulk Cable Weight: 30 lbs/1000 ft. Max. Recommended Pulling Tension: 107 lbs. Min. Bend Radius/Minor Axis: 2.500 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: No EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes RG Type: 59/U Suitability Suitability - Outdoor: Yes Suitability - Aerial: Yes - When supported by a messenger wire. Suitability - Burial: Yes Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8212 Coax - 75 Ohm Coax Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 75 Nom. Inductance: Inductance (µH/ft) .097 Nom. Capacitance Conductor to Shield: Capacitance (pF/ft) 17.3 Nominal Velocity of Propagation: VP (%) 78 Nominal Delay: Delay (ns/ft) 1.3 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 44.5 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 2.6 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 1 .6 10 1.0 50 2.1 100 3.0 200 4.5 400 6.6 700 8.9 900 10.1 1000 10.9 Max. Operating Voltage - Non-UL: Voltage 300 V RMS Minimum Structural Return Loss: Description Freq. (MHz) Start Freq. (MHz) Stop Freq. (MHz) Min. SRL (dB) 5 450 23 Put Ups and Colors: Item # Putup Ship Weight Color 8212 010U1000 1,000 FT 31.000 LB BLACK Notes Item Desc 8212 010U500 500 FT 16.500 LB BLACK 8212 0101000 1,000 FT 33.000 LB BLACK C 75 OHM COAX 8212 010500 500 FT 16.500 LB BLACK C 75 OHM COAX 75 OHM COAX 75 OHM COAX Notes: C = CRATE REEL PUT-UP. Revision Number: 3 Revision Date: 05-14-2007 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 2 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8212 Coax - 75 Ohm Coax Page 3 of 3 01-05-2017
8212 010U1000 价格&库存
很抱歉,暂时无法提供与“8212 010U1000”相匹配的价格&库存,您可以联系我们找货
