82729 8771000
82729 8771000
    BELDEN
    CBL 2PR 24AWG SHLD
82729 8771000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 82729 Multi-Conductor - Multi-Pair Snake Cable For more Information please call 1-800-Belden1 General Description: 24 AWG stranded (7x32) TC conductor, plenum, foam FEP insulation, twisted pairs, individually shielded w/Beldfoil (100% coverage), 24 AWG stranded TC drain wire, Flamarrest® jacket. Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material Dia. (in.) 2 24 7x32 TC - Tinned Copper .024 Total Number of Conductors: 4 Insulation Insulation Material: Insulation Material Wall Thickness (in.) FFEP - Foam Fluorinated Ethylene Propylene 0.019 Inner Shield Inner Shield Material: Inner Shield Trade Name Type Inner Shield Material Beldfoil® Coverage (%) Tape Aluminum Foil-Polyester Tape 100 Inner Shield Drain Wire AWG: AWG 24 Inner Shield Drain Wire Stranding: 7x32 Inner Shield Drain Wire Conductor Material: TC - Tinned Copper Outer Jacket Outer Jacket Material: Outer Jacket Trade Name Outer Jacket Material Flamarrest® Nom. Wall Thickness (in.) LS PVC - Low Smoke Polyvinyl Chloride 0.014 Overall Cable Overall Nominal Diameter: 0.255 in. Pair Pair Color Code Chart: Number Color 1 White/Blue & Blue/White 2 White/Orange & Orange/White Mechanical Characteristics (Overall) Operating Temperature Range: 0°C To +75°C Bulk Cable Weight: 24 lbs/1000 ft. Max. Recommended Pulling Tension: 33 lbs. Min. Bend Radius/Minor Axis: 2.750 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMP CEC/C(UL) Specification: CMP EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes Page 1 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 82729 Multi-Conductor - Multi-Pair Snake Cable EU RoHS Compliance Date (mm/dd/yyyy): 10/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: NFPA 262 CSA Flame Test: FT6 Plenum/Non-Plenum Plenum (Y/N): Yes Non-Plenum Number: 9729 Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 100 Nom. Inductance: Inductance (µH/ft) 0.24 Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 13.5 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/ft) 22.5 Nominal Velocity of Propagation: VP (%) 76 Nominal Delay: Delay (ns/ft) 1.3 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 24 Ind. Pair Nominal Shield DC Resistance @ 20 Deg. C: 14.400 Ohm/1000 ft Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) .384 0.74 .7056 0.87 .768 0.89 1.024 0.95 1.4112 1.03 1.536 1.06 2.048 1.17 2.8224 1.37 3.072 1.44 4.096 1.67 5.6448 1.89 6.144 1.96 8.192 2.26 11.2896 2.59 12.288 2.71 24.576 3.73 Max. Operating Voltage - UL: Voltage 300 V RMS Max. Recommended Current: Current 2.0 Amps per conductor @ 25°C Page 2 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 82729 Multi-Conductor - Multi-Pair Snake Cable Notes (Overall) Notes: Teflon® is a registered trademark of E. I. duPont de Nemours and Co. used under license by Belden, Inc. Put Ups and Colors: Item # Putup Ship Weight Color 82729 877U1000 1,000 FT 26.000 LB NATURAL 82729 8771000 1,000 FT 28.000 LB NATURAL Notes Item Desc 2 PR #24 FFEPR FS FLMRST C 2 PR #24 FFEPR FS FLMRST Notes: C = CRATE REEL PUT-UP. Revision Number: 2 Revision Date: 09-25-2012 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 08-26-2016
82729 8771000
物料型号:82729 Multi-Conductor - Multi-Pair Snake Cable
器件简介: - 导体:24 AWG 绞合(7x32)TC导体,锡铜 - 绝缘:FEP泡沫,0.019英寸壁厚 - 屏蔽:Beldfoil®铝箔聚酯带,100%覆盖 - 外护套:Flamarrest® LS PVC,低烟聚氯乙烯,0.014英寸壁厚
引脚分配: - 对1:白/蓝 & 蓝/白 - 对2:白/橙 & 橙/白
参数特性: - 工作温度范围:0°C至+75°C - 电缆重量:24磅/1000英尺 - 最大推荐拉力:33磅 - 最小弯曲半径/次轴:2.750英寸
功能详解: - 特性阻抗:100欧姆 - 标称电感:0.24微亨/英尺 - 标称电容:13.5皮法/英尺(导体间),22.5皮法/英尺(导体到其他导体和屏蔽) - 标称传播速度:76% - 标称延迟:1.3纳秒/英尺 - 直流电阻:24欧姆/1000英尺(导体),14.400欧姆/1000英尺(成对屏蔽)
应用信息: - 适用规范和机构合规性:包括NEC/UL规格CMP、CEC/C(UL)规格CMP等 - 欧洲指令和环保计划:包括RoHS II、CE标志、ELV、WEEE、BFR等 - 火焰测试:UL火焰测试NFPA 262、CSA火焰测试FT6 - 等效于空气介质:是
封装信息: - 总直径:0.255英寸 - 卷装重量:1000英尺重26.000磅(自然色),1000英尺重28.000磅(自然色,CRATE REEL PUT-UP)
82729 8771000 价格&库存
很抱歉,暂时无法提供与“82729 8771000”相匹配的价格&库存,您可以联系我们找货
